Gear Grinding - Polaris RZR Forum - RZR Forums.net
post #1 of 22 Old October 7th, 2012, 09:25 PM Thread Starter
RazorWire's Avatar
My RZR: 800 S
Member #45950
View RazorWire's Photo Gallery(0)
Gear Grinding
Well i got my 2013 RZR S 800 3 days ago and as i put it into gear at the dealer it grinds. I kinda though to myself oops i must not have had the brake pushed in all the way. So i get it home and start to drive it around and im noticing almost every time i shift it into reverse or any other gear it grinds bad!!
I call the dealer and he said it will do that when there new, give it time to break in and it will stop. Is this true?? He also said shift it hard not slow. Anybody else have this problem? Im not a rocket scientist but when you have a brand new machine its not suppose to be munching metal like that.
Should i take it in and pimp slap the dealer???
RazorWire is offline
post #2 of 22 Old October 7th, 2012, 09:29 PM
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: Gear Grinding
gears grinding means that the CVT is not disengaging at idle.
this can happen with a brand new belt and get better after break in,, but I would say it shouldn't happen on a new stock machine.
perhaps the clutch is out of alignment or the primary bearing isn't working properly.
take a look at the belt change videos (link in my signature) and you will see how the CVT works.
Tuf-Skin is offline
post #3 of 22 Old October 7th, 2012, 09:32 PM
KEN1's Avatar
First Name: Ken
My RZR: 2011 RZR S LE
Member #21675
View KEN1's Photo Gallery(0)
Re: Gear Grinding
Never happened to mine at all.Does not sound good.I would take it back to dealer asap and if it happens again after the dealer tell them you want another new unit......PERIOD!
KEN1 is offline
post #4 of 22 Old October 7th, 2012, 09:37 PM
Tuf-Skin's Avatar
Member #2228
Re: Gear Grinding
in the mean time, turn the engine off to change gears then turn it back on.
Tuf-Skin is offline
post #5 of 22 Old October 7th, 2012, 10:11 PM
DoubleDeXtremeRZR's Avatar
My RZR: 2011 RZR 800 S LE
Member #44360
View DoubleDeXtremeRZR's Photo Gallery(0)
Re: Gear Grinding
This is not normal. I purchased my ride in August and the gears started grinding within the first 5 hours. I called the dealer I bought it from and they gave me the same BS you got about its normal and i must be shifting it wrong. Well its not normal and its not you. I took mine to a different dealer and they gave me the same BS while the mechanic was shifting the gears in my ride (still on the trailer) and they were grinding away. So I told him to show me how another model shifts. He got into a 800 4 seater with 150 hrs on it and it shifted smooth as can be!!! I told him to make my new ride shift like the older one. 2 weeks later and a new primary clutch im good to go. They said my clutch was machined wrong from the factory.
DoubleDeXtremeRZR is offline
post #6 of 22 Old October 8th, 2012, 04:26 AM Thread Starter
RazorWire's Avatar
My RZR: 800 S
Member #45950
Re: Gear Grinding
Thanks for the replies everybody. Im going to take it back to the dealer...
post #7 of 22 Old October 8th, 2012, 07:21 AM
Russell's Avatar
First Name: Russell
My RZR: 2012 RZR-S LE
Member #31256
View Russell's Photo Gallery(0)
Re: Gear Grinding
I bought my 2012 S brand new and it would grind. After probably 200 miles it stopped. Some of the things i did were to always come to a full stop and pause to monitor the RPMs to make sure it was fully at idle before shifting, ensure i was getting it into gear fully and quickly. If I pulled it into gear slow the chance of grinding was greater. Now i have just over 400 miles and no grinding at all. Good luck with the dealer!
2012 RZR-S LE
Russell is offline
post #8 of 22 Old October 8th, 2012, 08:02 AM
5W0P3's Avatar
First Name: Jeff
My RZR: 2012 RZR S LE
Member #42695
View 5W0P3's Photo Gallery(0)
Re: Gear Grinding
Mine does the same thing if you're not at an ABSOLUTE 100% complete stop. If it's moving one tiny bit, it'll grind everytime.
5W0P3 is offline
post #9 of 22 Old October 8th, 2012, 08:14 AM
blazeman's Avatar
My RZR: 2013 900xp turbo
Member #12099
View blazeman's Photo Gallery(0)
Re: Gear Grinding
Check idle rpm, maybe to fast
blazeman is offline
post #10 of 22 Old October 8th, 2012, 08:18 AM
5W0P3's Avatar
First Name: Jeff
Member #42695
Re: Gear Grinding
Is that manually adjustable or is it changed in the computer? what should it be at?
5W0P3 is offline
post #11 of 22 Old October 8th, 2012, 08:39 AM
blazeman's Avatar
Member #12099
Re: Gear Grinding
I think it's 1250
blazeman is offline
post #12 of 22 Old October 8th, 2012, 08:55 AM Thread Starter
RazorWire's Avatar
My RZR: 800 S
Member #45950
Re: Gear Grinding
I always come to a complete stop before shifting. My idle is at 1250. I just dont wanna have to buy a new trans at 30 miles.
post #13 of 22 Old October 8th, 2012, 09:03 AM
blazeman's Avatar
Member #12099
Re: Gear Grinding
Then as posted above it's probably a clutch issue...
blazeman is offline
post #14 of 22 Old October 8th, 2012, 03:55 PM
damonmlime's Avatar
First Name: Damon
My RZR: 2013 S
Member #8819
View damonmlime's Photo Gallery(0)
Re: Gear Grinding
Mine did it for the first few hours. It's improved significantly the more I've driven it. My dealer told me it was normal also. I wouldn't worry about it.
damonmlime is offline
post #15 of 22 Old October 8th, 2012, 05:05 PM
Russell's Avatar
First Name: Russell
Member #31256
Re: Gear Grinding
If it is grinding everytime you shift no matter the gear, then you have a problem.
2012 RZR-S LE
Russell is offline
grinding when trying to get into gear firedude26 General RZR Discussion 8 September 3rd, 2012 11:20 AM
Has any one swaped out the rear gear box for the international gear box? dmax61 RZR XP 900 20 April 29th, 2012 03:26 PM
Belt whining and grinding going in gear smokinsrt Engine and Drivetrain 6 February 20th, 2012 01:31 PM
"grinding from gear box" dezert ratz rzr Engine and Drivetrain 15 April 12th, 2010 07:12 PM
Grinding when going into gear TxHighroller General RZR Discussion 1 September 2nd, 2008 06:55 PM
