Gear Grinding - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 22 Old October 17th, 2012, 10:03 AM
kaiserstatt's Avatar
First Name: Craig
My RZR: 2012RZR 800S , 2012 RZR 800
Member #40874
View kaiserstatt's Photo Gallery(0)
Re: Gear Grinding
My S did the same thing when new, took it back to the dealer and turned out the clutch was out of alignment. Fixed it quickly and easily. Dealer told me that it will grind if rpm's haven't fallen to idle, or if vehicle is moving or on a steep grade and placed into park. Other than that it should not grind. My dealer recognized the problem and fixed it, was easy to work with. Hope yours is the same...
kaiserstatt is offline
post #17 of 22 Old December 4th, 2013, 05:13 AM
john07gt's Avatar
Member #18928
View john07gt's Photo Gallery(0)
Re: Gear Grinding
i also have grinding going into gear,with the belt cover off if both clutches are spinning it grinds. but if i shut it off & put it in gear & start it no grind.brand new belt also in low range will pop out of gear on decell & grind away i think i have two problems i will adjust shifter & see if that helps
john07gt is offline
post #18 of 22 Old April 3rd, 2014, 11:45 AM
devilstower1's Avatar
Member #67380
View devilstower1's Photo Gallery(0)
Re: Gear Grinding
I have over 5000 miles on my 2013 xp900 Ranger and no matter how I shift it half the time when I go into reverse it just sits there and strips the gears. Now it even started doing it when going to low range forward. Yes I have a "feel" for the gears. You still never know when its going to happen. Often after shifting to reverse and backing up a few feet it will make a loud bang and pop out of reverse!
devilstower1 is offline
post #19 of 22 Old April 4th, 2014, 04:15 AM
fonz3482's Avatar
My RZR: 2013 rzr800 S LE
Member #51805
View fonz3482's Photo Gallery(0)
Re: Gear Grinding
I had the same issue with my new 800s. when I called about it, the dealer said to make sure my idle was at proper spec. and that the belt needs to break in. It was very annoying for the handful of rides, but I usually tried shifted it into gear before I started the machine to cut down on trans grinding. After a few rides it shifts awesome with no grinding
fonz3482 is offline
post #20 of 22 Old April 4th, 2014, 05:47 AM
davestrauss's Avatar
First Name: Dave
My RZR: 2013 RZR S
Member #47316
View davestrauss's Photo Gallery(0)
Re: Gear Grinding
Remember it is not a car with a tranny. You MUST stop all the way before shifting.
You will probably hear a clunk when taking off.
davestrauss is offline
post #21 of 22 Old April 5th, 2014, 11:46 AM
Member #67380
Re: Gear Grinding
At 6500 miles I'm purty sure its broke in. Actually if you don't come to a complete stop sometimes it goes in gear better than if you do! It's not me guys its a problem with the design or some component faulty. I bet my tranny is full of steel shavings by now.
post #22 of 22 Old April 5th, 2014, 04:48 PM
jarzr's Avatar
Member #65719
View jarzr's Photo Gallery(0)
Re: Gear Grinding
My gears were grinding in every gear I put it in, I found my primary bearing was locked up, after I had the bearing changed we noticed you had to slightly push in on the clutch spring to get the bearing to rotate freely so I had to change the clutch also. Now its smooth as butter.
jarzr is offline
grinding when trying to get into gear firedude26 General RZR Discussion 8 September 3rd, 2012 12:20 PM
Has any one swaped out the rear gear box for the international gear box? dmax61 RZR XP 900 20 April 29th, 2012 04:26 PM
Belt whining and grinding going in gear smokinsrt Engine and Drivetrain 6 February 20th, 2012 02:31 PM
"grinding from gear box" dezert ratz rzr Engine and Drivetrain 15 April 12th, 2010 08:12 PM
Grinding when going into gear TxHighroller General RZR Discussion 1 September 2nd, 2008 07:55 PM
