when to use HI and LO gear - Polaris RZR Forum - RZR Forums.net
post #1 of 15 Old December 9th, 2011, 04:54 AM Thread Starter
hmfman91's Avatar
My RZR: 2012 S LE O.Madness
Member #31955
View hmfman91's Photo Gallery(0)
Is there certain times u should hi and lo? Any certain speeds?
hmfman91 is offline
post #2 of 15 Old December 9th, 2011, 05:00 AM
medik418's Avatar
First Name: Tom
My RZR: 2009 RZR
Member #14212
Re: when to use HI and LO gear
You'll get lots of opinions on this but I've learned with mine that any climbing is lo gear only unless you're riding dunes or high speed runs. It saves on belt wear and you can, on a steep hill stall out if it's a long hill and you're loaded two up. Shortly after that you can smell burning rubber and that never turns out good.
medik418 is offline
post #3 of 15 Old December 9th, 2011, 05:00 AM
BAMA-S's Avatar
First Name: LEE
My RZR: RZR XP1K voo doo blue
Member #9351
View BAMA-S's Photo Gallery(0)
I use low for 15 mph and less, then high for any riding above 15 mph. I've had good luck with my belts since I started this.
Riding and fishing
BAMA-S is offline
post #4 of 15 Old December 9th, 2011, 05:26 AM
Caveman
MWSartain's Avatar
Member #306
View MWSartain's Photo Gallery(0)
As a rule of thumb, anytime I use 4wd, it's in low gear. Otherwise mine always stays hi gear.
2012 RZR XP- Epic Lights 30" LED Bar, Hiper beadlocks,Gibson Exhaust, MB Products cage, Walker Evans Shocks, UTV Inc. Bumper, heat shield and extinguisher,Bighorns, TS Seats,Pro-Armor doors
08 RZR -LoneStar +4, Afco shocks, Holz hood Grill, Kenwood Excelon CD speakers and amps, 1800 watts, 3-12" woofers, Holz Airbox fix, MB Racing cage, UMP airbox
MWSartain is offline
post #5 of 15 Old December 9th, 2011, 08:04 AM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
View jerrzr's Photo Gallery()
I never use low gear running the trails. The only time I use low is if I come to a trouble spot or climbing on the rocks... I just wish you could switch from low to high while moving.
post #6 of 15 Old December 9th, 2011, 09:59 AM
Craig_c's Avatar
Member #11066
View Craig_c's Photo Gallery(0)
I only use low when climbing or crawling like Jerr said. Ive burnt two belts that could have been avoided 100% by a pull of the shifter.
Craig_c is offline
post #7 of 15 Old December 9th, 2011, 10:06 AM
dmax61's Avatar
First Name: Tom
My RZR: 2010 RZR-S White
Member #10609
View dmax61's Photo Gallery(0)
I too wish we could switch hi lo on the fly
dmax61 is offline
post #8 of 15 Old December 9th, 2011, 10:46 AM
clemson726's Avatar
My RZR: 2010 RZR S
Member #11797
View clemson726's Photo Gallery(0)
the threshold is about 15mph for me. some places i ride its high most of the time but some places i ride its too much trouble to stop and shift so i just stay in low.
2010 RZR "S" SOLD
2015 RZR 900 S
clemson726 is offline
post #9 of 15 Old December 9th, 2011, 11:47 AM
Sxsperformance's Avatar
My RZR: 17 XP4 Turbo
Member #32193
View Sxsperformance's Photo Gallery(0)
I think these are all really good suggestions. We try to use low as much as possible when we are in technical sections or doing any climbing.
Sxsperformance is offline
post #10 of 15 Old December 9th, 2011, 11:49 AM
King of crash!
Member #787
x2 on this way
johnnycat8 is offline
post #11 of 15 Old December 9th, 2011, 11:50 AM
King of crash!
Member #787
me too.... did try it once...never try that again
post #12 of 15 Old December 9th, 2011, 11:57 AM
Baditude's Avatar
My RZR: 2011 RZR XP
Member #1091
View Baditude's Photo Gallery(18)
agree with whats is said above, also use low on steep declines to get more effective engine braking
Baditude is offline
post #13 of 15 Old December 9th, 2011, 11:59 AM
Tiorum3's Avatar
First Name: Al
Member #10509
X100 Thats why I dont use low more... When climbing a hill or crawling over something its low all the way but on trails its in High 2wd.
Tiorum3 is offline
post #14 of 15 Old December 9th, 2011, 12:56 PM
Leveldrummer's Avatar
Member #24907
View Leveldrummer's Photo Gallery(0)
Keep it in high, keep the gas pedal on the floor, you never have to worry about it.
Leveldrummer is offline
post #15 of 15 Old December 10th, 2011, 07:19 PM
6skinner
Orangemadness12's Avatar
First Name: Dave
My RZR: 2012 rzr s orange madness
Member #30843
View Orangemadness12's Photo Gallery(0)
In the bush, low if it's twisty and full of hills. High if it's wide open. Haven't smelled a burnt belt in almost 2000 soooooooo seems to working!
If I have to give it more than 1/3-1/2 throttle to get it moving, low range.
14 scrambler 1000, 28 mega mayhems on 14" sixr wheels, qsc clutched on hardest setting
14 Ace, 26" pro comp extremes on 14" msa m17 elixer wheels, total blast!
And a 600rwhp 03 powerstroke on 37" mud grapplers to haul it all
13 fx4 a/p on 35"grapplers, 6.2l
Orangemadness12 is offline
Rzr will not go in any gear ?? skeeter67 Engine and Drivetrain 25 March 13th, 2013 07:42 PM
Fast in Low Gear or Slow in High Gear? WARPARTY36 General RZR Discussion 9 February 28th, 2010 05:25 PM
Low Gear mrwizardd83 General RZR Discussion 8 September 11th, 2009 09:33 AM
won't go into geaR pszutiak Engine and Drivetrain 2 July 10th, 2009 09:04 PM
