14 rzr 800s pinion nut fix - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old June 9th, 2019, 06:53 PM Thread Starter
Marty.z1's Avatar
Member #270190
View Marty.z1's Photo Gallery(0)
Doing the pinion nut fix on a rzr 800s and never found any shims behind the one bolt on the connecting tube to the diff.. Did not all the 800s have the shims... the bracket doest show an impression of one so im sure there was none there
Marty.z1 is offline
post #2 of 4 Old June 9th, 2019, 08:14 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Re: 14 rzr 800s pinion nut fix
They don't all come with the shim.
Many go missing during initial disassembly.
The actual shim is .015".
I suspect that unless the gap between bent steel plate part, and machined boss on aluminum cast part is .050" to .100", that everything will bolt up with out shims.
I would snug the bolt in question first, then tighten the remaing bolts.
2014 800 LE w/EPS 50”
PRO ARMOR trail doors, RYFAB rear windshield, MotoAlliance Fire Storm cab heater, RYFAB cargo rack, WARN PV4500S wide spool winch, POLARIS front windshield and top, 2008 tail lamp assemblies with backup lights, RACERTECH 2” lift, Duraclutch, R2C Air Filter, Garage Products A-arm bushings.
CA 800 is offline
post #3 of 4 Old June 10th, 2019, 07:58 AM
Pullerguy's Avatar
First Name: Les
My RZR: 2012 800 50"
Member #61901
View Pullerguy's Photo Gallery(0)
Exactly what Geoff said
Les
Pullerguy is offline
post #4 of 4 Old June 11th, 2019, 11:42 PM
Zbird's Avatar
First Name: Dan
My RZR: 2014 800
Member #259732
View Zbird's Photo Gallery(0)
We did 2 machines when we did the nut dance and my buddy's the shim was seen easily and is how we knew to look for it on mine. But we didn't think mine had one but then found it stuck to wherever it bolted in.
Zbird is offline
