2012 800s pinion fail, new diff ? - Polaris RZR Forum - RZR Forums.net
post #1 of 11 Old May 3rd, 2019, 12:35 PM Thread Starter
hillbilyRZR's Avatar
Member #67313
View hillbilyRZR's Photo Gallery(0)
Usa 2012 800s pinion fail, new diff ?
hello all, I have a 2012 800s and had the dreaded pinion nut fail. So I decided to buy a whole new diff. My question is did they fix the problem with the nut backing out with new units? Or do I need to replace the nut and locktite? I did buy the solid nut and new seal but was not sure if I had too. Also I have looked but has anyone ever just tacked the nut in place? Use a fire blanket to keep slag out of the bearing or maybe double nut? I will have to make a tool to get the nut out but only way to hold it is with the axle. Any thoughts?
thanks all
Jeremy
hillbilyRZR is offline
post #2 of 11 Old May 3rd, 2019, 05:28 PM
dajo's Avatar
First Name: Dave
Member #19884
View dajo's Photo Gallery(0)
Re: 2012 800s pinion fail, new diff ?
They did not fix the problem an new one needs the nut procedure.
Some peen the nut, I did not but wish I did.
There are tools you can borrow from pullerguy (his forum name)
https://www.rzrforums.net/rzr-800-sp...pullerguy.html
dajo is offline
post #3 of 11 Old May 4th, 2019, 06:14 AM
Clothier's Avatar
First Name: Brian
Member #65577
thanks all
Jeremy
Yes you need to change the nut. Where are you located?
Clothier is offline
post #4 of 11 Old May 22nd, 2019, 05:41 PM Thread Starter
Member #67313
update:
thanks for the help guys. After ordering a coupler from ebay fairly cheap, a freebie help from a friend that let me destroy a 1 3/4 socket and alittle bit of metal and the tools are made. I received a new diff from rocky mountain and disassembled it. I reassembled the pinion with a thin layer of Polaris ADF then steel pinion nut with red locktite and tools worked as it should. I rotated the pinion every 50lbs up to my last bit. I made it to 280lbs before my socket tool started to fail. It started to bent and tear in the middle of the socket tool. so i made it to atleast 280lbs. Now should there be some drag on the pinion when turning free hand? I always thought there had to be some free play? im still considering tacking the nut to the pinion...what do u all think
thanks again
post #5 of 11 Old May 23rd, 2019, 03:56 AM
HawkEng's Avatar
First Name: Jason
My RZR: Turbo Apex RZR & Z1 RZR
Member #747
View HawkEng's Photo Gallery(0)
The diffs come from Polaris set up way too tight sometimes. That is why we take them apart and set up the clearances again before we lock down the nut and ship em out.
I specialize in APEX and Z1 conversion kits for the 800. Z1 kits for the 900xp, XP1000, and 1k Turbo. We have a Z1 waterproof belt cover too.
573-579-8295. Check out our custom coach builds too. www.hawkengineering.com.
HawkEng is offline
post #6 of 11 Old May 23rd, 2019, 06:46 PM Thread Starter
Member #67313
Wish I would have done more research on here. You live and learn.
Only problem is as I put the last diff mount bolt in I found a .010 shim under my lift! Only reason I didn't yank it out yet is b.c it was really tight when I first got it. Couldn't turn it by hand and the shim came off the opposite ring gear side. So now im conflicted on saying send it or pull it and redo.
what u guys think
Jeremy
post #7 of 11 Old May 24th, 2019, 07:54 AM
Pullerguy's Avatar
First Name: Les
My RZR: 2012 800 50"
Member #61901
View Pullerguy's Photo Gallery(0)
Jeremy:
The shim you are talking about, is it about the size of a 3/8 flat washer, stainless? If it is it came out off of the bolt that is next to the crank position sensor, between the trans/diff bracket and the adapter tube housing.
The Loctite 272 or Permatex 27200 should be used, it tolerates oil, 271 or 277 do not like oil. The new nut can be staked with a center punch at the top after if is torqued. The pinion shaft threads and nut should be oil free for the threadlok to work properly.
Les
Pullerguy is offline
post #8 of 11 Old May 24th, 2019, 06:35 PM Thread Starter
Member #67313
what u guys think
Jeremy
Awsome...i used 271...i cleaned with brake clean several times and used a scotch brite pad on the nut and thread and let dry for 2 day. When i looked up the red 271at first it didnt say much about the application then after reading this post i found more data..has anyone ever used 271 with success?
Jeremy
post #9 of 11 Old May 27th, 2019, 05:35 AM
HawkEng's Avatar
First Name: Jason
Member #747
We have had 3 customers use red loctite 272 and didn't hold in time. Had to do it again. I know lots have used it, but it has failed too.
HawkEng is offline
post #10 of 11 Old May 27th, 2019, 05:48 AM
dajo's Avatar
First Name: Dave
Member #19884
OK what do you mean by lock down the nut?
dajo is offline
post #11 of 11 Old May 27th, 2019, 11:47 AM
HawkEng's Avatar
First Name: Jason
Member #747
We have done over 300 of these since 2008 and no issues. This is a service we do in our shop and I don't want to give out our secrets. Sorry.
HawkEng is offline
RZR "RACE" rack and pinion Shock Therapist Shock Therapy 7 September 1st, 2017 07:35 PM
RZR "RACE" rack and pinion Shock Therapist General RZR Discussion 3 February 3rd, 2017 11:01 AM
2012 Polaris RZR 800S with EPS tmanracing Polaris RZRs For Sale 1 March 11th, 2016 06:25 AM
Selling my 2012 800S. Tons of extras. Central PA coltonharris15 Polaris RZRs For Sale 2 January 25th, 2016 08:00 PM
wtb, rear diff 2012 800s rooter1975 Want to Buy 1 July 3rd, 2014 09:19 AM
