Inline Oil Pressure Sending Unit - Install Help - Polaris RZR Forum - RZR Forums.net
post #1 of 19 Old October 5th, 2009, 02:15 PM Thread Starter
temecularanger's Avatar
My RZR: 2015 RZR 1000 XP 4
Member #9098
View temecularanger's Photo Gallery(0)
Wrench Inline Oil Pressure Sending Unit - Install Help
I just purchased the Inline Oil Pressure Sending Unit from UTV Crap:
UTV Crap
There weren't any instructions included, so I thought I'd ask for your opinions. I'd hate to cut a line that I shouldn't have. So, where is the best place to install this? I'm very visual, so pictures would be great
When I installed my temp sending unit, I cut my hose a tad too short...so I ended up having to buy another hose. I'm trying to avoid this. Any help would be very much appreciated.
Thanks,
Gary
2015 RZR 1000 XP 4
temecularanger is offline
post #2 of 19 Old October 5th, 2009, 02:20 PM
Does my sons 170 count?
dirtysidedown's Avatar
First Name: Steve
Member #4404
View dirtysidedown's Photo Gallery(0)
Re: Inline Oil Pressure Sending Unit - Install Help
As close to the engine will minimize any pressure drop
dirtysidedown is offline
post #3 of 19 Old October 5th, 2009, 02:26 PM Thread Starter
Member #9098
Thanks for the reply. I guess my question is more simple than that. Which hose/line am I tapping into? The temp sending unit was obvious, since I tapped it close to the thermostat. With this, I'm just unsure which hose/line to tap into.
Thanks,
Gary
2015 RZR 1000 XP 4
post #4 of 19 Old October 5th, 2009, 02:27 PM
First Name: Steve
Member #4404
ah- you use one of the lines that run to the oil cooler
post #5 of 19 Old October 5th, 2009, 02:34 PM Thread Starter
Member #9098
Thanks - I must be an idiot, cuz I didn't know the stock RZRs had oil coolers. I'll go take a look at my RZR.
Gary
2015 RZR 1000 XP 4
post #6 of 19 Old October 5th, 2009, 02:40 PM
Slated4Greatness's Avatar
Member #10011
View Slated4Greatness's Photo Gallery(0)
How much pressure are you seeing with the razor engines?
-Dan
Slated4Greatness is offline
post #7 of 19 Old October 5th, 2009, 02:41 PM
First Name: Steve
Member #4404
Gary
Your not an idiot- I am! they dont have an oil cooler but John is making a kit to add an oil pressure gauge to the rzr. You made me second guess myself as soon as I posted
post #8 of 19 Old October 5th, 2009, 02:41 PM Thread Starter
Member #9098
So...it looks like I'm not losing my mind. The stock RZRs don't have oil coolers. Is this the only way to install your inline sending unit? I assumed it could be installed on a stock RZR-S.
2015 RZR 1000 XP 4
post #9 of 19 Old October 5th, 2009, 03:38 PM
Johnny's Avatar
First Name: Johnny
My RZR: 2013 RZR XP 1000
Member #318
Feedback Score: 5 reviews
The Rhino oil pressure adapters do not work on a rzr ....... sorry
Johnny is offline
post #10 of 19 Old October 5th, 2009, 03:44 PM Thread Starter
Member #9098
Well crap. The description on your website doesn't say it's for a Rhino. I'm not sure if it's worth sending back (since it was $7 to ship to me...plus $7 to ship it back...for a $29 part).
It's my fault for not thinking this all the way through. I bought a gauge, sending unit and this housing...assuming it would all work (again - my fault).
Do all of you with oil pressure gauges really have an oil cooler installed? Is there any other solution for me to get the oil pressure (without it costing me too much more money)?
Thanks,
Gary
2015 RZR 1000 XP 4
post #11 of 19 Old October 5th, 2009, 04:11 PM
Family Rzr
410fortune's Avatar
First Name: Jamie
My RZR: 2009 RZR S
Member #8045
View 410fortune's Photo Gallery(0)
the oil pressure port is supplied to you by POlaris, There is an oil pressure port in your engine for testing oil pressure.
My oil pressure capillary tube is installed right here:
You can use the same spot for the electronic sensor, but you do not need an inline type sensor for the Rzr or Rzr S,
Did you try searching this forum for your answer? I found the oil pressure port here on this forum and then in the Rzr owners manual to confirm
1988 Bronco II, 5.0L Gt-40p, 4r70w, 35" MTZ, dual ARBs, long travel
2007 FJ cruiser, 3" OME, dual ARBs, 4.56, 33" MTR
2005 (2ea) 900 RMK, 159", modified
2009 Rzr S - way too stock
410fortune is offline
post #12 of 19 Old October 5th, 2009, 06:11 PM Thread Starter
Member #9098
Thanks for the reply. Yea, I did a lot of searching. I did see a picture of the sending unit installed right in the port you mentioned from a previous thread. I also saw the port in the manual. Idiot me, just thought there was an oil line i could tap into...especially since UTV Crap was selling these (I found their adapter in their forum, and thought it was a good idea).
What did you use in this port? Like I said, I saw a picture of someone with the sending unit installed right into the port.
Thanks!
2015 RZR 1000 XP 4
post #13 of 19 Old October 5th, 2009, 06:18 PM
Family Rzr
410fortune's Avatar
First Name: Jamie
My RZR: 2009 RZR S
Member #8045
I have a plastic tube in the port that feeds oil pressure to my mechanical oil pressure gauge.
An electric oil pressure gauge will have a sensor with a wire, no plastic tube.
This is an oil pressure port
post #14 of 19 Old October 5th, 2009, 06:31 PM Thread Starter
Member #9098
Thanks man. I might just bag this whole idea. It's beginning to be more of a pain than it's worth (and a lot more money than I expected). Appreciate your help.
2015 RZR 1000 XP 4
post #15 of 19 Old October 6th, 2009, 09:34 AM
Member #10011
Just a thought: Add an oil cooler (Couldn't hurt) and then you can use your inline adapter.
-Dan
sending unit ThaMule Want to Buy 4 July 20th, 2009 11:38 AM
UPVCRAP 1/8" NPT Inline Radiator Temp Sending Unit Housing Hookie General RZR Discussion 3 March 17th, 2009 06:33 PM
Oil pressure sending unit!!! Davemn41 Engine and Drivetrain 19 February 17th, 2009 09:51 PM
best place for water temp sending unit? megadesertdiesel Engine and Drivetrain 30 June 14th, 2008 09:41 AM
