29 inch Carnivores? - Polaris RZR Forum - RZR Forums.net
 5Likes
  • 1 Post By Martic22
  • 2 Post By Martic22
  • 1 Post By wjcorey
post #1 of 13 Old October 6th, 2019, 09:22 PM Thread Starter
wjcorey's Avatar
First Name: Wes
My RZR: 2017 RZR 900 S White Lightning
Member #273698
View wjcorey's Photo Gallery(0)
29 inch Carnivores?
I'm new to the RZR world, just bought our first RZR this spring. We picked up a 2017 900 S with lows miles. Looking at a wheel and tire upgrade. I'm trying to decide between Maxxis Carnivores 28x10x14's or 29x9.5x15's. I want to put the biggest tire on that I reasonably can with out running into power and rubbing problems. I know the 28's are the safe choice. But, you know, ground clearance with the 29's is tempting. Just wonder what people are running for tires and how they're working out.
I know I can add a tune and gain a few more hp. I'll probably do that eventually. I want ground clearance but don't want something that will bog it down too much. Thanks in advance.
wjcorey is offline
post #2 of 13 Old October 7th, 2019, 02:22 PM
Dirt-Monger's Avatar
My RZR: 17 RZR 900s
Member #211761
View Dirt-Monger's Photo Gallery(0)
Re: 29 inch Carnivores?
I ran into a lot of clearance issues where we ride, lots of rutted out trails that would swallow up your tires and grind my A-arms so def needed more clearance so I added
SATV forward offset high clearance A-arms
32"EFX Motoclaws
Those 2 made a huge difference clearance wise with no tire rub but wanted a bit more so added
SATV 3" lift kit
With the lift the RZR has awesome clearance now ....big rocks, rivers, stumps, logs, huge ruts no problem now
So if you want max clearance (without portal hubs) def consider some forward offfset A-arms then 29"- 33" is easily possible
Dirt-Monger is offline
post #3 of 13 Old October 7th, 2019, 07:15 PM
Reno15xc's Avatar
Member #272888
View Reno15xc's Photo Gallery(0)
I put 29” bighorns on my 900 xc and had rubbing up front when I made my turns I eventually had to go with satv conversion kit.
Reno15xc is offline
post #4 of 13 Old October 8th, 2019, 06:42 AM Thread Starter
wjcorey's Avatar
First Name: Wes
Member #273698
Thanks for the info. I think I may go with the 29's and add the off-set arms if I have to. Not too expensive and sound easy to install. I found a few posts where guys are running 29's and they barely clear, other have some rubbing.
wjcorey is offline
post #5 of 13 Old October 20th, 2019, 06:35 PM
Martic22's Avatar
My RZR: 2017 RZR S 900
Member #269008
View Martic22's Photo Gallery(0)
I put 30X10X14 Carnivores on mine. Stock suspension with zero rub.
CAMPMEAT1 likes this.
Martic22 is offline
post #6 of 13 Old October 20th, 2019, 10:03 PM Thread Starter
wjcorey's Avatar
First Name: Wes
Member #273698
Any other upgrades? Clutch kit. I'm actually thinking of putting the same tires on 14" bead-locks. I figured I'd buy the offest A-arms if I had to. Thanks
wjcorey is offline
post #7 of 13 Old October 20th, 2019, 10:04 PM Thread Starter
wjcorey's Avatar
First Name: Wes
Member #273698
Any pictures? I'd love to see how those 30" carnivores look on a 900 S. Thanks
wjcorey is offline
post #8 of 13 Old October 20th, 2019, 10:27 PM
Martic22's Avatar
Member #269008
Here you go. They are mounted on STI HD bead locks. No clutch work yet as I havenít really needed it yet. Iím sure I will upgrade it this winter.
Feldhege and wjcorey like this.
Martic22 is offline
post #9 of 13 Old October 21st, 2019, 06:29 AM
Feldhege's Avatar
First Name: Robb
My RZR: 2017 Polaris RZR S 900
Member #268354
View Feldhege's Photo Gallery(0)
So no clutch work and you can turn those big tires fine? Wow. I think I just found my next upgrade. That looks soooooooo much better than the 28 inch tires I have on mine.
Feldhege is offline
post #10 of 13 Old October 21st, 2019, 08:20 AM
Martic22's Avatar
Member #269008
No issues turning them at all. I havenít done anything crazy with them only trail riding. 45mph and below seems to work just fine. Iím not riding in the dunes or rock crawling. AA tune is all sheís got right now.
Martic22 is offline
post #11 of 13 Old October 21st, 2019, 11:43 AM
BAMAWHISTLER's Avatar
My RZR: 2016 900S
Member #226706
View BAMAWHISTLER's Photo Gallery(0)
I run 30s, and if I had the chance I'd do offset front A arms and 32s!
2016 900 S White Lightening, 4500lb winch, ProBox top, front and rear windshields, spring brake thingy, full doors, Kemimoto door bags, brush guards, rock sliders, SuperATV rear cab frame bars, fire extinguisher, sway bar deleted, Bandit Springs, 30" Kahunas, 15" Quadboss Scovilles, AA S2 clutch kit, SS250 filter magnet, and lots of zip ties!!!
BAMAWHISTLER is offline
post #12 of 13 Old October 21st, 2019, 05:32 PM Thread Starter
wjcorey's Avatar
First Name: Wes
Member #273698
Looks awesome. That really helps. I'm definitely going with the 30's. What wheel off-set are your running? I'm pretty sure stock is 5+2 (6+2 rear). I was thinking of going with 4+3 to get a little wider stance. Thanks!
Feldhege likes this.
wjcorey is offline
post #13 of 13 Old October 21st, 2019, 07:40 PM
Martic22's Avatar
Member #269008
STI HD5 14x7 5 +2.
wjcorey likes this.
Martic22 is offline
