RZr bogging down when you press the gas - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Denver
post #1 of 6 Old July 21st, 2019, 09:09 PM Thread Starter
logan.baldwin's Avatar
Member #270900
View logan.baldwin's Photo Gallery(0)
My rzr is acting up. It will idle perfectly fun but when you give it gas it dies out. Hereís what Iíve checked so far
Check valves
Check timing
Check fuel pressure at rail
Check fuel pressure at pump
Replace spark plugs and set at proper gap
Check grounds
Cleaned intake plenum
Swapped coil
Swapped map sensor
Swapped crank position sensor
Cleaned throttle body
Checked compression
Checked voltage to fuel pump while running
Fixed loose wires on fuse box.
Checked to make sure fuel filter was clean.
logan.baldwin is offline
post #2 of 6 Old July 21st, 2019, 10:54 PM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Re: RZr bogging down when you press the gas
Trade in for a new one, let dealer shop throw money at it!
442raceRZR likes this.
Denver is offline
post #3 of 6 Old July 22nd, 2019, 04:42 AM Thread Starter
Member #270900
Haha nah I donít have the money for all that
post #4 of 6 Old July 22nd, 2019, 07:46 AM
Wolfhound
Wolfhound's Avatar
First Name: ROBERT
My RZR: 2019 Turbo S
Member #270810
View Wolfhound's Photo Gallery(0)
Seatbelt sensor does that same thing . . .
Robert and Betty
Polaris Turbo S Dynamix
Wolfhound is offline
post #5 of 6 Old July 24th, 2019, 07:37 AM
RussT's Avatar
Member #248770
View RussT's Photo Gallery(0)
Also when the engine goes into safe mode.
RussT is offline
post #6 of 6 Old July 24th, 2019, 04:50 PM
Jtoor43's Avatar
Member #268676
View Jtoor43's Photo Gallery(0)
Have you checked fuel injectors?
Jtoor43 is online now
