Need new tires without increased width - Polaris RZR Forum - RZR Forums.net
 4Likes
post #1 of 18 Old July 21st, 2019, 07:36 PM Thread Starter
Skeld's Avatar
Member #215033
View Skeld's Photo Gallery(0)
Anything I can do for new tires that can get me increased height without changing my overall width? I'm already squeezed tight on 60" gates in stock form. Dirt Commanders are wearing out and I'm going to need to do something eventually.
Skeld is offline
post #2 of 18 Old July 21st, 2019, 07:58 PM
Vandal
Vandal's Avatar
First Name: Richard
My RZR: 2016 RZR 570 EPS Trail
Member #82526
View Vandal's Photo Gallery(0)
Re: Need new tires without increased width
Going up in height isn't going to make you get wider, unless you go up in size and in width. 27x10x14 is going to be the same width as 28x10x14, the tires are just going to be an inch taller which will give you 1/2 inch more increased height
Vandal is offline
post #3 of 18 Old July 21st, 2019, 08:13 PM Thread Starter
Skeld's Avatar
Member #215033
True, but then I will need 14" wheels. Most of the aftermarket wheels seem to have increased offset yes?
Skeld is offline
post #4 of 18 Old July 22nd, 2019, 04:37 AM
Plankk's Avatar
First Name: Tony
My RZR: 2019 RZR XP4 Turbo
Member #246370
View Plankk's Photo Gallery(0)
Get some xp take offs. They will make you taller (29" tires) and narrower (5+1 front and 6.5+1.5 rear offsets) and give you a 14" rim. Can usually be found on used for $400-$500. You can use wheels spacers if you have rub issues or want to push them back out to stock width.
Denver and Skeld like this.
Plankk is offline
post #5 of 18 Old July 22nd, 2019, 05:24 AM Thread Starter
Skeld's Avatar
Member #215033
I've been looking for a set of those but after reading the Shock Therapy stuff about offset and scrub radius now I'm a little gun shy. If I interpret his article correctly, it seems that would give me a negative scrub radius which he says in the article is bad...although he doesn't elaborate much since the main point of the article is to discourage people from going wider, not narrower.
Skeld is offline
post #6 of 18 Old July 22nd, 2019, 07:34 AM
DogRunner2's Avatar
Member #137545
You'll be fine.
2018 XP1K LE
DogRunner2 is offline
post #7 of 18 Old July 22nd, 2019, 07:47 AM Thread Starter
Skeld's Avatar
Member #215033
What about 30x10x12 Blackwaters front and rear? Will that work on the stock wheels?
Skeld is offline
post #8 of 18 Old July 22nd, 2019, 07:57 AM
Rockwerx's Avatar
My RZR: 2015 900S 2016 1000S 2018 XP Turbo
Member #85936
View Rockwerx's Photo Gallery(0)
I installed 30x10x12 Blackwaters on 4 stock front wheels on our 1000S. We loved this combination. I never measured the width but I suspect it is around 62” wide based on narrow bridges we crossed. I have run this combination down to 6 psi for some crawling situations. Usually ran around 8 psi which really helped take a lot of chop out of the ride.
Skeld likes this.
2016 1000S 2018 XPT
Rockwerx is offline
post #9 of 18 Old July 22nd, 2019, 07:58 AM Thread Starter
Skeld's Avatar
Member #215033
Will that tire not work on the stock rear wheel? I know the rear tire stock is 11".
Stock width of mine seems to be 61 to possibly as much as 62, the sidwalls all have to be squished in as I push through a narrow gate.
Skeld is offline
post #10 of 18 Old July 22nd, 2019, 08:03 AM
Rockwerx's Avatar
Member #85936
It may mount on the wider rim but I wanted to be able to rotate my tires so that they wore evenly.
Skeld likes this.
2016 1000S 2018 XPT
Rockwerx is offline
post #11 of 18 Old July 22nd, 2019, 08:06 AM
Rockwerx's Avatar
Member #85936
Also, the deeper offset of the wider rim doesn’t always fit properly without rubbing issues on the front axle on RZRs.
2016 1000S 2018 XPT
Rockwerx is offline
post #12 of 18 Old July 22nd, 2019, 08:08 AM Thread Starter
Skeld's Avatar
Member #215033
I see, well maybe it would look a little wagon wheel-ish on the rear with the 8 inch rim, 10 inch wide tire, and also being 3 inches taller than the stock 27.
Skeld is offline
post #13 of 18 Old July 22nd, 2019, 08:20 AM
Rockwerx's Avatar
Member #85936
ID:	580606Click image for larger version
ID:	580608Click image for larger version
2016 1000S 2018 XPT
Rockwerx is offline
post #14 of 18 Old July 22nd, 2019, 08:30 AM Thread Starter
Skeld's Avatar
Member #215033
Looks pretty good, thanks. Mine is a 4 seater but a lot more traffic in this forum so I figured I would ask here. Should be same principle I think.
Skeld is offline
post #15 of 18 Old July 22nd, 2019, 08:41 AM
vtprairie's Avatar
Member #70416
View vtprairie's Photo Gallery(0)
I don't know were you are located but I have a set of XP take offs that I ran for a year. I used wheel spacers on mine to widen it. I don't have the issue with gates that you have. I ended up buying new rims just so I could take of the spacers. One cap is broke from the place that dismounted my tires but the rims are great shape. I don't know where you are located but I would take like 250 bucks plus shipping for them. They are just sitting in my garage
2016 RZR 900 Trail EPS
2017 RZR 1000S
vtprairie is offline
