Rzr help - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old July 21st, 2019, 03:31 PM Thread Starter
logan.baldwin's Avatar
Member #270900
View logan.baldwin's Photo Gallery(0)
Rzr help
So my rzr has been acting up, weíve done just about everything but check wiring harness and the ecu. Have anyone had any problems with these. It will crank up perfectly fine and then you press the gas and it dies out. I just donít see those 2 things being the reason that itís doing that.
logan.baldwin is offline
post #2 of 7 Old July 21st, 2019, 03:35 PM
GPS GURU
702youngbergs's Avatar
My RZR: 2019 XP1000 RC
Member #269632
View 702youngbergs's Photo Gallery(0)
You haven’t given us much, have you checked the fuel filter, fuel pressure , and the throttle position sensor ?
702youngbergs is offline
post #3 of 7 Old July 21st, 2019, 04:15 PM Thread Starter
Member #270900
Re: Rzr help
Originally Posted by 702youngbergs View Post
You havenít given us much, have you checked the fuel filter, fuel pressure , and the throttle position sensor ?
Yes put a brand new fuel pump assembly. Pressure is good. Do the new model RZRs have a tps sensor itís a 16
post #4 of 7 Old July 21st, 2019, 10:02 PM Thread Starter
Member #270900
Re: Rzr help
It will idle perfectly fun but when you give it gas it dies Hereís what Iíve checked so far
Check valves
Check timing
Check fuel pressure at rail
Check fuel pressure at pump
Replace spark plugs and set at proper gap
Check grounds
Cleaned intake plenum
Swapped coil
Swapped map sensor
Swapped crank position sensor
Cleaned throttle body
Checked compression
Checked voltage to fuel pump while running
Fixed loose wires on fuse box.
Checked to make sure fuel filter was clean.
post #5 of 7 Old July 22nd, 2019, 08:00 AM
PhilCod's Avatar
First Name: Phil
My RZR: 2016 RZR 900S
Member #185129
View PhilCod's Photo Gallery(0)
Re: Rzr help
I'm assuming you drained all the gas and used fresh? Or run some Ethanol Free through it?
Looks like you have done a lot of stuff. That is an odd problem. Worst case take it to your local Polaris Stealership.
Hunterworks HD belt & secondary rollers, Super ATV Front bumper, LED light bar, A-Arm guards, rear net. ORB side bars, KFI Winch, EMP Fenders, Samsung Tablet w/Lifetime Trail maps. PRP door bags. Split windshield
2016 Brute Force 750
2014 Kawasaki Teryx
PhilCod is offline
post #6 of 7 Old July 22nd, 2019, 08:29 AM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
Re: Rzr help
Check valves
Check timing
Check grounds
Swapped coil
Swapped map sensor
Checked compression
What type of RZR is it ...turbo , 800 , 900 ?
Max H is online now
post #7 of 7 Old July 22nd, 2019, 11:28 AM
Dirt-Monger's Avatar
My RZR: 17 RZR 900s
Member #211761
View Dirt-Monger's Photo Gallery(0)
Re: Rzr help
Check the vent tube and gas cap on your fuel tank.... they can get plugged up and not vent properly
Dirt-Monger is offline
