Need Help. 2015 900s hard to shift into gear - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Hunterworks
post #1 of 6 Old July 21st, 2019, 11:02 AM Thread Starter
Ashman63097's Avatar
Member #271378
View Ashman63097's Photo Gallery(0)
Recently put a new skid plate on and took my rzr for one ride at a mud bog and never hit any mud hole just cruised around the edges. 2 weeks later I get in it and I can barely shift it out of park . It is very hard to shift but once you go from park through all the gears several times, it gets easier to shift. I let it sit for about a month and now I can barely get it out of park and it im afraid if i pull harder something will break. Any ideas?
Ashman63097 is offline
post #2 of 6 Old July 22nd, 2019, 04:43 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Re: Need Help. 2015 900s hard to shift into gear
Will it move easy with engine off?
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is online now
post #3 of 6 Old July 22nd, 2019, 07:53 AM Thread Starter
Member #271378
It is just as hard with it off.
post #4 of 6 Old July 22nd, 2019, 07:57 AM
First Name: Todd
Member #47437
Then that is shifter, shifter cable (linkage) or internal tranny issues
To eliminate the first two, remove cable from tranny on passenger side, see if you can manually put in park easily or not.
Todd
PhilCod likes this.
www.hunterworks.com
Todd
post #5 of 6 Old July 22nd, 2019, 12:29 PM
jamlam1's Avatar
Member #121713
View jamlam1's Photo Gallery(0)
You might try looking at my post. https://www.rzrforums.net/rzr-s-900/...g-problem.html I just experienced a problem that pretty much had the same symptons. VERY hard shifting even not running. I too felt like I was going to break something. No grinding and no sounds when Driving once you got it in gear. I solved my issue and explained in my post...good luck!
jamlam1 is offline
post #6 of 6 Old July 22nd, 2019, 12:34 PM Thread Starter
Member #271378
Thank you, I will check it out!
