Spark plugs - Polaris RZR Forum - RZR Forums.net
 4Likes
post #1 of 26 Old July 18th, 2019, 02:08 AM Thread Starter
logan.baldwin's Avatar
Member #270900
View logan.baldwin's Photo Gallery(0)
Spark plugs
Iíve got a 2016 rzr 900s and had some issues I changed spark plugs but they are not the ones from the Polaris dealer they are from advance would this cause it to only run on one cylinder?
logan.baldwin is offline
post #2 of 26 Old July 18th, 2019, 02:17 AM
CGturba's Avatar
Member #269918
View CGturba's Photo Gallery(0)
Did you gap the new plugs? If you put old plugs back in does the problem go away?
CGturba is offline
post #3 of 26 Old July 18th, 2019, 02:28 AM Thread Starter
Member #270900
Re: Spark plugs
My brother put them in Iím not 100% sure he gapped them or not. It will crank up fine but when you press the gas it dies out
post #4 of 26 Old July 18th, 2019, 02:32 AM
CGturba's Avatar
Member #269918
If you know it was running fine before the plug swap I’d. Pull them an gap them. Not that it matters as much as people think but I gotta ask what plugs did he put in there?
CGturba is offline
post #5 of 26 Old July 18th, 2019, 02:38 AM Thread Starter
Member #270900
Re: Spark plugs
Originally Posted by CGturba View Post
If you know it was running fine before the plug swap Iíd. Pull them an gap them. Not that it matters as much as people think but I gotta ask what plugs did he put in there?
The fuel pump went out and I replaced the fuel pump and it was still not running right so we put the new plugs in and now itís idling better but when you give it gas it dies out like I said. They are ngk
post #6 of 26 Old July 18th, 2019, 02:46 AM
CGturba's Avatar
Member #269918
Well that changes the scenario. I would say prolly fuel related more than the new spark plugs. But I would still gap the plugs to see if it helps “unless they are the NGK Irridium, don’t gap those”
CGturba is offline
post #7 of 26 Old July 18th, 2019, 02:50 AM Thread Starter
Member #270900
Re: Spark plugs
Yeah Iím stumped on it I will see about gapping those plugs.
post #8 of 26 Old July 18th, 2019, 02:52 AM Thread Starter
Member #270900
Re: Spark plugs
Well that changes the scenario. I would say prolly fuel related more than the new spark plugs. But I would still gap the plugs to see if it helps ďunless they are the NGK Irridium, donít gap thoseĒ
Iíve changed the whole fuel pump assembly Iíll try the plugs but other than that I have no clue what it could be.
post #9 of 26 Old July 18th, 2019, 02:53 AM
CGturba's Avatar
Member #269918
Keep us posted. I hope that’s it, and I’m sure today people will chime in who know a hell of a lot more about RZRs than me lol
logan.baldwin likes this.
CGturba is offline
post #10 of 26 Old July 18th, 2019, 02:56 AM Thread Starter
Member #270900
Re: Spark plugs
I will thanks man!
post #11 of 26 Old July 18th, 2019, 09:50 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Re: Spark plugs
What is fuel pressure, both at idle and when you fed gas? Should be 58, give or take a couple psi.
Denver is online now
post #12 of 26 Old July 18th, 2019, 09:52 AM
Denver's Avatar
First Name: Denver
Member #41951
Re: Spark plugs
Any possibility of water in the fuel?
post #13 of 26 Old July 18th, 2019, 09:57 AM
Denver's Avatar
First Name: Denver
Member #41951
Re: Spark plugs
From the shop manual troubleshooting:
Engine Idles But Will Not Accelerate
• Spark plug fouled/weak spark
• Obstruction in air intake
• Air box removed (reinstall all intake components)
• Incorrect ignition timing
• Restricted exhaust system
• Cam worn excessively
Want a copy, PM me.
post #14 of 26 Old July 18th, 2019, 11:40 AM Thread Starter
Member #270900
Re: Spark plugs
Denver, I put a whole new fuel pump assembly on it straight from the Polaris dealer so donít think itís that. It was running perfectly fine and then fuel pump went out and ever since itís been giving me trouble and canít get it to run right
post #15 of 26 Old July 18th, 2019, 01:29 PM
Denver's Avatar
First Name: Denver
Member #41951
Re: Spark plugs
Wouldn't be the first time new parts were bad off the shelf...
Sent from my S9+ using Tapatalk Pro
