Rattling sound coming from driveshaft - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 1 Post By RZR800SS
  • 2 Post By superjunior
post #1 of 9 Old July 12th, 2019, 09:11 AM Thread Starter
AndrewHughes's Avatar
Member #271098
View AndrewHughes's Photo Gallery(0)
There is this loud rattling sound coming from my driveshaft around my CB. The drive shaft wobbles a little bit but it does not feel like my CB is going out. It is more like a metal on metal sound. Has anyone else had this problem? And what did you do to fix it?
AndrewHughes is offline
post #2 of 9 Old July 13th, 2019, 07:34 AM
superjunior's Avatar
First Name: Dan
My RZR: 2015 900S
Member #74479
Re: Rattling sound coming from driveshaft
Check your belt. I had a rattling noise coming from the same area, sounded like a bunch of ball bearings rolling around somewhere. Turns out it was my belt slapping around the cover, right before it exploded. Put a new belt on and all was good. This may not be your issue, but easy to check.
superjunior is offline
post #3 of 9 Old July 23rd, 2019, 09:31 AM
RussT's Avatar
Member #248770
View RussT's Photo Gallery(0)
Strongly Agree. Check the belt first. Make sure you roll it around so you can see the whole thing.
RussT is offline
post #4 of 9 Old July 25th, 2019, 08:19 AM
RZR800SS's Avatar
First Name: GORDEN
My RZR: 2018 900 RZR S
Member #214409
View RZR800SS's Photo Gallery(0)
I BET ITM IS THE CARRIER BRG
Fastone110 likes this.
RZR800SS is offline
post #5 of 9 Old July 25th, 2019, 09:01 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Need a little more info, like:
Model and year?
Mileage?
Where and how you ride it?
Denver is online now
post #6 of 9 Old August 8th, 2019, 08:58 PM
Bonz6996's Avatar
Member #231257
View Bonz6996's Photo Gallery(0)
I had the exact same noise and it took me awhile to figure it out, on mine it was the rear yoke on front propshaft and the yoke on rear shaft where it goes onto the trans, the yokes get loose on the splines over time and they will rattle at higher speeds, a temporary fix is grease the yokes, i installed a new yoke on the rear propshaft where it slides onto transmission and yoke on front ahaft where it slides onto rear shaft and noise is gone and has been gone for about 800 miles now
Bonz6996 is offline
post #7 of 9 Old August 10th, 2019, 05:14 AM
First Name: Dan
My RZR: 2015 900S
Member #74479
Exactly this. I thought my noise was the belt slapping the cover and I believe that was part of it, but after a recent ride realized the noise was still there. I checked the rear yoke at the spline and there is a ton of sloppy play, like a LOT and its noisy.. I'm pulling my driveshaft this weekend and got 3 new ujoints and a new carrier barring. Just waiting on the new yokes that will hopefully be here Monday. I figured if I'm going through all the trouble pulling the shaft, might as well put all new components in there and be done with it.
Fastone110 and Eddie-C like this.
post #8 of 9 Old August 10th, 2019, 09:42 PM
DogRunner2's Avatar
Member #137545
All Balls.Phased and balanced drive shaft, front prop shaft,yokes, greasable ujoints and carrier bearing for a little over 300 bucks. Smoother than stock.
2018 XP1K LE
DogRunner2 is offline
post #9 of 9 Old August 24th, 2019, 02:01 PM
First Name: Dan
My RZR: 2015 900S
Member #74479
I shoulda went this route. Just replaced everything but the actual shafts for almost as much. And... noise is still there! So, not in the drive line, not the belt, and not the axles.. The only thing left is the tranny, and the noise is the same rattling sound as if it were to slip out of gear while in motion. Hopefully that's not the op's issue, but I'm convinced my sound is the transmission..
