Elec issues - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Impact344
post #1 of 9 Old June 23rd, 2019, 08:39 PM Thread Starter
Gigocatcher's Avatar
Member #270610
View Gigocatcher's Photo Gallery(0)
Elec issues
Ok I suck at electrical I have speedo power when key is on but NO other power fuel pump or anything no start no lights there is a little blue led under dash that when it’s dim it’s having issues the battery was tested and good and 100 percent charged when jump cables hooked up after played with long enough all of a sudden the light under dash is bright and it will turn over also it was 100 percent fine until the stupid chain tensioner went out oh btw this is a 15 rzr 900 s I have since replaced the tensioner and have other problems other than the elec issues that’s another post
Gigocatcher is offline
post #2 of 9 Old June 24th, 2019, 10:10 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Re: Elec issues
Wow. Punctuation. Please. My eyes are bleeding just reading that.
Now, your electrical problem. I'd suspect loose battery cables, either at the battery (maybe some corrosion) or the negative cable attachment to the frame might be a bit loose and/or corroded.
The little blue light is just a courtesy lamp for night driving, in case you drop something.
Denver is online now
post #3 of 9 Old June 24th, 2019, 03:46 PM
slant911's Avatar
My RZR: 2019 XP Turbo
Member #269992
View slant911's Photo Gallery(0)
Re: Elec issues
My bet is a bad ground. Make sure all grounds are tight and corrosion free.
slant911 is offline
post #4 of 9 Old June 24th, 2019, 07:46 PM
Impact344's Avatar
Member #268904
yea check all your battery connections and it sounds like you and I need to attend the "Denver school of fine English" he gave me the same punctuation non sense he gave you but idk any better I'm from west virginia
Denver likes this.
Impact344 is offline
post #5 of 9 Old June 25th, 2019, 12:03 AM
Denver's Avatar
First Name: Denver
Member #41951
Re: Elec issues
Hey, at least you can use quotation marks properly! (And I'm from PA, just north of Morgantown.)
post #6 of 9 Old June 25th, 2019, 05:11 AM
Impact344's Avatar
Member #268904
[IMG class=inlineimg]https://www.rzrforums.net/images/rzrforums_toucan/smilies/tango_face_grin.png[/IMG][IMG class=inlineimg]https://www.rzrforums.net/images/rzrforums_toucan/smilies/tango_face_devil.png[/IMG][IMG class=inlineimg]https://www.rzrforums.net/images/rzrforums_toucan/smilies/tango_face_grin.png[/IMG]
lol and do you know much about solemen chevy in masontown pa? I am going to look at a 3/4ton chevy today
post #7 of 9 Old June 26th, 2019, 09:23 AM
Denver's Avatar
First Name: Denver
Member #41951
Re: Elec issues
Not a clue. Left there when I joined the military (1974) and only occasionally visited since then. Sorry,,,
post #8 of 9 Old June 26th, 2019, 09:24 AM
Denver's Avatar
First Name: Denver
Member #41951
Re: Elec issues
Ok I suck at electrical I have speedo power when key is on but NO other power fuel pump or anything no start no lights there is a little blue led under dash that when itís dim itís having issues the battery was tested and good and 100 percent charged when jump cables hooked up after played with long enough all of a sudden the light under dash is bright and it will turn over also it was 100 percent fine until the stupid chain tensioner went out oh btw this is a 15 rzr 900 s I have since replaced the tensioner and have other problems other than the elec issues thatís another post
Back on the OP (original poster), sorry for hijacking your thread. Have you found any answer to your problem? Please let us know.
post #9 of 9 Old June 27th, 2019, 07:17 AM
Threewheel79's Avatar
Member #164161
View Threewheel79's Photo Gallery(0)
I'm having the same exact electrical issue on a 2016 900s. Any luck?
Threewheel79 is offline
