2017 s900 Itp Delta Rim Fitment? - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old January 28th, 2018, 02:37 PM Thread Starter
HOONIGAN1988's Avatar
Member #194121
View HOONIGAN1988's Photo Gallery(0)
Hey guys,
I would like to get a set of ITP Delta rims for my '17 s900 eps. I currently have a itp delta rim that was
a spare rim for my 2013 s800. The bolt pattern matches, 4-156?. But the center bore on the 2017 is 4" i believe and the itp delta i have is a 5" bore. Does anyone know the lug diameter off hand on the 2017 models?
Also i had to drill out the lug holes slightly to make it fit on my 2017. The backspacing and offset is perfect.
1: can i safely use these rims if i have to drill the lug holes slightly? Shouldnt cause a vibration as the lugs should still be
centered?
2: Is it ok that the center bore doesnt match? ive read that most aftermarket rims have larger center bores.
Thanks for any help!
HOONIGAN1988 is offline
post #2 of 5 Old January 28th, 2018, 04:48 PM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Re: 2017 s900 Itp Delta Rim Fitment?
I have read where other people have drilled out their holes a little bit and put 800 rims on a 900.
Sent from my SAMSUNG Note 5 using Tapatalk
Denver is offline
post #3 of 5 Old January 28th, 2018, 05:42 PM Thread Starter
Member #194121
i suppose it cant be any worse than adding wheel spacers.. then the hub is then ignored as well. if i make the holes for the lugs fit
snug, and put a good lug nut on, shouldnt be a problem?
post #4 of 5 Old January 28th, 2018, 05:50 PM
Denver's Avatar
First Name: Denver
Member #41951
Proper torque is a must. If you plan on jumping, I wouldn't trust it. If was me, I'd only use those on smooth fire roads.
Denver is offline
post #5 of 5 Old January 28th, 2018, 05:56 PM Thread Starter
Member #194121
definately no jumping, im a very careful rider, payed too much for this thing, dont want to break it!
2017 XP1K Timing Chain Tensioner - I Think Polaris Fixed It! Sshsjd10 RZR XP 1000 89 September 28th, 2018 01:12 PM
Motor Vibration After Lift Kit install 2017 rzr s900 HOONIGAN1988 RZR S 900 2 August 30th, 2017 07:16 PM
Spare Tire Rim for 2017 RZR 4 900 midironman Want to Buy 0 August 25th, 2017 01:26 PM
Any pics of ITP 30x10x14 on a 6" rim?? LadderLogicLloyd Wheels and Tires 2 March 14th, 2017 04:13 PM
