Typical Maintenance/ Bushings - Polaris RZR Forum - RZR Forums.net
post #1 of 14 Old March 22nd, 2017, 10:53 AM Thread Starter
Ding's Avatar
Member #144809
View Ding's Photo Gallery(0)
I've had my 900 for about a year now, and haven't had to fix anything yet. I put on a new belt and a RCR filter, but they weren't needed.
What are the things I should start checking after some mixed riding of rocks and mud. I've been greasing everything I can, including the wheel bearings. But at around 1100 miles, I'm just starting to be concerned about things like wheel bearings and ball joints. I'm going to Moab next week and just wanted to get an idea.
Once I get it back from this brake recall, I'm going to check my pads and do a shake down on the suspension. Let me know what you think.
Ding is offline
post #2 of 14 Old March 22nd, 2017, 11:03 AM
old skool kracker's Avatar
Member #137777
View old skool kracker's Photo Gallery(0)
Re: Typical Maintenance/ Bushings
What's the brake recall?
Sent from my VS987 using Tapatalk
old skool kracker is offline
post #3 of 14 Old March 22nd, 2017, 11:43 AM
olomas02's Avatar
First Name: MudBeaner
My RZR: 900s
Member #78097
View olomas02's Photo Gallery(0)
grab your tire and move it up and down side to side. Watch ball joints, tie rod ends, & bushings for movement.
I replaced all my bushings at about 1100 miles. and I've done 1 ball joint and 1 tie rod end also.
Sent from my SAMSUNG-SM-G891A using Tapatalk
olomas02 is offline
post #4 of 14 Old March 22nd, 2017, 11:48 AM
Metki's Avatar
Member #164697
View Metki's Photo Gallery(0)
Brake master cylinder recall on rzr and generals
Metki is offline
post #5 of 14 Old March 22nd, 2017, 11:52 AM
deblas's Avatar
First Name: Steve
Member #33923
View deblas's Photo Gallery(0)
https://www.cpsc.gov/Recalls/2017/Po...hway-Vehicles#
2014 XP4 1000 Titanium
deblas is offline
post #6 of 14 Old March 22nd, 2017, 12:01 PM
sburrell's Avatar
First Name: Shane
My RZR: RZR S 1000
Member #42586
View sburrell's Photo Gallery(0)
Wrench Re: Typical Maintenance/ Bushings
Check wheel play, replace bearings as needed. I would recommend removing, cleaning/inspecting your bushings. I've done it every year and usually glad I did, especially the bolts. They tend to get gritty which causes wear quickly.
sburrell is offline
post #7 of 14 Old March 22nd, 2017, 12:08 PM Thread Starter
Ding's Avatar
Member #144809
Any particular brand that is recommended for ball joints, bearings and bushings?
Ding is offline
post #8 of 14 Old March 22nd, 2017, 12:14 PM
sburrell's Avatar
First Name: Shane
My RZR: RZR S 1000
Member #42586
Honestly when I've needed one I usually goto amazon. On an older 800 50 inch went thru several bushings and snagged some UHMW bushings and they lasted till I sold it. My 800 S I only had one wheel bearing which I caught few days before riding and snagged first prime option on amazon for it. My 1000 S I haven't had to replace anything but I still check it all each season and clean/inspect factory bushings. I've actually seen more of them wear the tube and bolt vs actual bushings wear. Grease is good till it does't push the grit out so thats why I'm a believer in cleaning them vs just greasing them. The UHMW infused bushings seem to work well and are dry.
sburrell is offline
post #9 of 14 Old March 22nd, 2017, 12:51 PM
Member #137777
Ok thanks, it doesn't apply to mine. I have a 2015 900 s. I was curious because here lately my pedal will goto the floor on me.
post #10 of 14 Old March 22nd, 2017, 03:23 PM
Burnt Orange's Avatar
First Name: Richard
My RZR: 2015 900 Trail
Member #83480
View Burnt Orange's Photo Gallery(2)
I suggest you have that checked out or do it yourself. Pedal going to the floor, not a good thing. You might start by checking the master cylinder brake fluid level and check all brake lines and calipers. You may have already done that. If it was mine I wouldn't drive it until I got it figured out.
Good luck, hope it is just a minor thing.
Burnt Orange is offline
post #11 of 14 Old March 22nd, 2017, 03:58 PM
Member #137777
It doesn't do it all the time. But when it goes to the floor I let off and push again and the pedal is back to normal. The fluid level is fine and I've never had the system apart for anything. I've only changed the pads. I've never seen any leaking or anything. But it is happening more frequently though.
post #12 of 14 Old March 22nd, 2017, 08:06 PM
southern's Avatar
My RZR: RZR XP900
Member #77297
View southern's Photo Gallery(0)
Sounds like you have a good grasp on checking things for wear and tear.
On the greasing, I used to go through I dont know how many tubes of grease on my bushings.
I got a set of bushings from performancesxsbushings and around 700 miles ago was the last times I greased it and that was when I put them in. I have tried to grease them a couple times but they will not take any because of the seal in the bushing.
southern is offline
post #13 of 14 Old March 23rd, 2017, 03:32 AM
Larsonator's Avatar
My RZR: 2015 900S
Member #73551
View Larsonator's Photo Gallery(0)
Lots of good bushing options. I use garage products.
Keep an eye on your rear lower outer a-arm bolts. The longs ones that hold the hub to the a-arm. Some of us with 2015's have had the bolt shear. Mine was on it's way. I replaced it with a stronger bolt and I had to weld washers to the a-arm due to the bolt egging the hole out.
You should be blowing the primary and secondary clutches out with compressed air every few hundred miles. Take apart the secondary and inspect it. The 2016 models have an improved secondary, but not by much. Look closely at the square pucks and where they ride. Hunterworks makes an upgrade that's a roller made from a better material.
Larsonator is offline
post #14 of 14 Old March 23rd, 2017, 09:19 PM
southern's Avatar
My RZR: RZR XP900
Member #77297
Good tips in that one. My 800 I had was bad about breaking the lower hub bolts.
southern is offline
Bushings for rear radius rods Mikecinak High Lifter Products 0 November 28th, 2016 07:04 AM
Not Stock Bushings TNWoodie Suspension 1 October 30th, 2016 02:56 PM
Installed Hunterworks Bushings... Zbugsii General RZR Discussion 2 July 11th, 2016 05:23 AM
Central CA Oakhurst Trail Maintenance & Free BBQ dmax61 General RZR Discussion 1 April 18th, 2016 10:17 AM
Maintenance Down Time PDS00 General RZR Discussion 2 February 23rd, 2016 06:30 PM
