Carrier Bearing - Polaris RZR Forum - RZR Forums.net
post #1 of 21 Old March 4th, 2017, 09:43 PM Thread Starter
Dro727RZR's Avatar
Member #104969
View Dro727RZR's Photo Gallery(0)
Carrier Bearing
Anyone running the sandcraft carrier bearing or any other style carrier bearing?
I only have 400 miles on my 900s and the stock carrier bearing is shot.
I'm looking to replace it with something better and can't find what I want to know about the sandcraft one or any other types of carrier bearing replacements besides the stock one.
I've read good and bad about the sandcraft one being the only bad I've read was it rubbing the coolant lines? Is sandcraft the only supplier of this style carrier bearing?
Ive also read that guys are using pillow block bearings or an automotive equivalent to stock. Does anyone have part numbers or suggest these over the sandcraft?
Thanks in advance for your input.
Dro727RZR is offline
post #2 of 21 Old March 5th, 2017, 04:13 AM
penguins87's Avatar
My RZR: 2015 Rzr 900 S Havasu Red
Member #42918
View penguins87's Photo Gallery(0)
Re: Carrier Bearing
Mine went at 1500 miles. I replaced my OEM with a Timken HB31 on advice from this forum. Or you can use a Timken HB26 but you'll have to remove two tabs. They're used on a Tacoma pickup but are exact fit for the RZR shaft and bolt pattern. Search them and you'll see they look just like OEM but the HB31 has two o rings that helps seal on the shaft. Better than OEM IMHO.
2015 Rzr 900 S Havasu Red- EMP aluminum roof, EMP Hard Coat Cab Back and a Polaris Poly Windshield, Viper Elite 3000 lb winch and mount, 72" Denalli Plow, PRP Lower Doors, Hawk Eng. VR, VR relocated to front, Parking Brake installed, A2Z Canvas Upper Doors, R2C Air Filter.
penguins87 is offline
post #3 of 21 Old March 5th, 2017, 11:07 AM Thread Starter
Dro727RZR's Avatar
Member #104969
Re: Carrier Bearing
Penguins87, I did read about those and have seen those but I was wondering more about a pillow block solid mount verses the rubber dampened bearing. Was curious if anyone has done the solid mount bearing like the sandcraft one on a 900s and if it really helps driveline angle and vibration? And is there another alternative or another company that sells a bearing like sandcraft?
I will probably end up buying the sandcraft one because I won't to go away from the rubber dampened style factory ones. I'm not a fan of the rubber ones allowing the driveline to spin untrue instead spinning true being mounted solid. I've eliminated the rubber carried bearings on trucks and ran a 1 piece driveshaft instead of a 2 piece with carrier bearing.
I'm not afraid to spend money on a quality part but sandcraft sure is proud of that thing. One thing that would be a big selling point is if they made it grease able or a greaser for it like the wheel bearing greasers.
post #4 of 21 Old March 5th, 2017, 11:16 AM
GJJack's Avatar
Member #111545
View GJJack's Photo Gallery(0)
Re: Carrier Bearing
I have a sandcraft on my 4 seater and its much better than stock. If i had to do it again id go with their complete driveshaft even though its rather pricey.
GJJack is offline
post #5 of 21 Old March 5th, 2017, 11:38 AM Thread Starter
Dro727RZR's Avatar
Member #104969
Re: Carrier Bearing
GJJack, did you have any issues with the bearing interfering with your coolant tubes? Does it improve the angle better? Eventually I'll take the driveshaft to get re-phased the correct way. The vibration hasn't been bad in my rzr in 4x4 but heard a clunking on the last ride and my carrier bearing fell apart.
post #6 of 21 Old March 5th, 2017, 12:42 PM Thread Starter
Dro727RZR's Avatar
Member #104969
Re: Carrier Bearing
Also guys, doing some more searching I came across a place in Charleston,WV called Drive Line Service. They make a pretty cool carrier bearing setup. I'm waiting to give them a call when they open tomorrow to ask them about their carrier bearing setup. Check them out if your interested Drive Line Service ? DRIVESHAFTS AND DIFFERENTIALS
They also do driveshaft mods too, re-phase, re-tube etc.
post #7 of 21 Old March 5th, 2017, 01:09 PM
zac692069's Avatar
My RZR: 2015 XP1K
Member #51483
View zac692069's Photo Gallery(0)
Re: Carrier Bearing
I have a Sandcraft in my 2015 XP1K 2 seater. Had 2000 miles on OEM when I replaced it. Honestly the only difference I can tell is on initial take off when hard on the throttle. Other than that I just feel more driveline vibration than I did before.
zac692069 is offline
post #8 of 21 Old March 5th, 2017, 01:25 PM Thread Starter
Dro727RZR's Avatar
Member #104969
Re: Carrier Bearing
Zac692069, that's what I'm worried about driveline vibration being excessive and causing other problems, either way with the stock carrier bearing it's just like a bandaid absorbing the vibration and the sandcraft or equivalent is trying to hold an unbalanced and not phased correctly driveshafts is what I gather from information you guys have posted and what I've watched on YouTube videos and read online. I'll prolly end up buying the driveline service one, install it, and go from there if I need to send the driveshaft to a shop and re-phase it and balance it.
post #9 of 21 Old March 6th, 2017, 11:44 AM
zac692069's Avatar
My RZR: 2015 XP1K
Member #51483
Re: Carrier Bearing
I wouldnt get too caught up with the yoke phasing. I used to build drivelines, your main importance is straightness and balance. On these units balancing is a challenge due to limited people having mock up yokes to put in a balancer. Im really not sure why everyone gets so caught up on phasing. There are plenty of manufactures that have lots of money and build oem shafts 90 to 180 out of phase, usually to help with balance and joint lubrication when run at very slight angles.
And im not getting enough vibration to worry about, you just feel more of the rotation of the driveline. Much like running solid motor mounts.
If i were to do it over again i woukd have went with a more durable bearing in the oem carrier.
post #10 of 21 Old March 6th, 2017, 02:31 PM
rzrboba's Avatar
First Name: Bob
My RZR: 2015 S 900 EPS
Member #80381
View rzrboba's Photo Gallery(0)
Re: Carrier Bearing
What is the best way to tell if you need a new carrier bearing?
rzrboba is offline
post #11 of 21 Old March 6th, 2017, 02:33 PM Thread Starter
Dro727RZR's Avatar
Member #104969
Zac692069, I know exactly what your talking about with the phasing/clocking of the driveshafts and balancing them. I figured if worse came to worst I'd send it down to that place in west virginia I mentioned in previous post called Drive Line Service because they can do it if a shop near me can't do them.
I also ordered the carrier bearing assembly they sell today so I will keep you guys updated when I receive it and install it.
post #12 of 21 Old March 6th, 2017, 02:38 PM Thread Starter
Dro727RZR's Avatar
Member #104969
Rzrboba, the way I found mine was excessive vibration in 4x4 and clunking when starting from a stop in forward or reverse. Physical inspection of it by removing center console or skid plate underneath can show you also if the rubber around the bearing is coming out or the bearing has rust powder coming out of it. You could also put it on jack stands and removed center console, spin driveshaft by hand to feel if it's loose/tight or run it in 4x4 on jack stands at an idle. Many different ways to go about it. From what I've read online guys have just found it bad during a ride like myself.
post #13 of 21 Old March 8th, 2017, 06:01 PM
zac692069's Avatar
My RZR: 2015 XP1K
Member #51483
post #14 of 21 Old March 8th, 2017, 06:02 PM
zac692069's Avatar
My RZR: 2015 XP1K
Member #51483
Re: Carrier Bearing
If you try this seup out, red loctite the shit outa it and keep an eye on it.
post #15 of 21 Old March 8th, 2017, 06:38 PM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
Re: Carrier Bearing
Wow I was thinking of buying that sand raft bearing carrier, after seeing that video I am thinking I will save my money.
Dstew619 is offline
How to replace Carrier Bearing? XP4 1000 Metatrox Engine and Drivetrain 5 February 20th, 2017 05:10 PM
12 XP4 900 Carrier Bearing Install WV23RZR4 RZR XP 4 900 Specific Discussion 3 October 27th, 2016 05:22 PM
Carrier Bearing Replacement - 900 Trail Ignorance RZR 900 - 50'' Trail Models 2 September 12th, 2016 08:18 AM
We sell Sandcraft Carrier Bearing $240 Free Shipping and 48 RZR Giveaway entries UTV Family Engine and Drivetrain 0 July 14th, 2016 10:00 AM
