New 900S upper a-arm too wide? - Polaris RZR Forum - RZR Forums.net
post #1 of 3 Old May 17th, 2016, 06:11 PM Thread Starter
tmanracing's Avatar
First Name: TJ
My RZR: 2015 RZR 900S
Member #71542
View tmanracing's Photo Gallery(0)
Anyone ever replace an upper a-arm on a 900S and have trouble getting the new one to fit into the frame? I Bought a whole set of gently used front a-arms after I tweaked my upper diver side and both the right and left upper seems to be wider and wont fit into the frame. Both of the new to me upper a-arms are the same width and both of my existing uppers are the same width but narrower than the new ones. Does anyone have a loose upper a-arm laying around that they can measure for me without the bushings installed? I am stumped.
tmanracing is offline
post #2 of 3 Old May 17th, 2016, 06:38 PM
Hartman's Avatar
My RZR: 2017 XP 1000 EPS
Member #116577
View Hartman's Photo Gallery(0)
Re: New 900S upper a-arm too wide?
I would think the replacement ones you got are not for a 900 S model and perhaps for the 50 inch trail machine or different model all together considering they are not the same width as your existing ones. Is there a part number on them by chance that you can lookup?
Hartman is offline
post #3 of 3 Old May 17th, 2016, 08:04 PM Thread Starter
tmanracing's Avatar
First Name: TJ
Member #71542
I got it figured out I think. The a-arms are definitely correct, I was not referring to the machine width, I was having trouble with the distance between the two mounting points on the frame. I ended up taking the plate loose below the radiator that forms the forward most mounting point, threw the bolts through the hole and tightened everything back up.
2015 RZR 900S Front Lower Arm txrzr900s Want to Buy 0 February 21st, 2016 07:06 AM
WTB Upper and lower A arm set 1000 XP AzDesertRacer Want to Buy 8 January 31st, 2016 09:02 AM
UTV INC XP 1000 Grills UTV Inc. UTV Inc 7 January 28th, 2016 07:28 AM
WTB- Upper A arm kmc2224 Want to Buy 3 December 16th, 2015 03:20 PM
900xp trailing arm and upper radius rod F/S!!!! travisH3 Polaris RZR Parts For Sale 6 December 13th, 2015 03:38 PM
