High Clearance Offset A-arms - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 40 Old February 9th, 2016, 07:20 AM Thread Starter
w.wood's Avatar
First Name: Bill
My RZR: 2015 S 900
Member #76672
View w.wood's Photo Gallery(0)
Been looking for high clearance A-arms for my 2015 S 900 to get more ground clearance and fit 30" tires. While reading a bunch of threads I made some notes which might help others so I am posting them up here.
I’m pretty new to UTVs and learned a few things along the way..... arched A-arms do not increase overall ground clearance. They only provide more ground clearance under the arms themselves because they are bent up and will clear rocks, etc that might have hit the factory arms because they are straight and hang lower. To increase overall ground clearance, you need bigger tires or a lift.
Some aftermarket A-arms are offset to the front and rear compared to the factory arms to increase wheelbase and clear bigger tires, others are not offset at all and maintain factory dimensions. As to offset arms, the fronts are offset forward and the rears are offset rearward. So if the front and rear arms are both offset 1.5", the wheelbase would be increased by 3".
Increasing wheelbase supposedly makes the vehicle more stable in certain situations like hill climbs or riding fast in the desert. But a longer wheelbase makes it harder to handle tight turns so there is a trade off.
Some companies also sell lifts along with high clearance A-arms. But lifts are another trade off. The taller the car, the higher the center of gravity which could make it more unstable in turns, off camber, etc. Longer A-arms are also possible but extra width is another trade off, a wider vehicle can be more stable but it might not fit between obstacles or squeeze on your trailer. Some A-arm kits require 4+3 offset wheels for clearance which also increases vehicle width, an important factor to check out.
So for me here in the AZ desert (I ride mostly on tight trails, some open fast trails, hills and rocks, no mud) I feel that offset arched arms and 30" tires will give me enough overall ground clearance without any lift and will help in ruts and rocks. I don't want any additional width since there are lots of tight spots on the trails. Most importantly offset arms will give me more room to fit 30" tires.
I found 10 companies that sell aftermarket A-arms. Here is a list with some details about their products. Only the first 5 companies sell kits with front and rear offset A-arms with no lift that fit the S 900.
1) Super ATV - Front and rear offset high clearance A-arm kits for the S 900.
Front kit: $299.95
Rear kit: $299.95
Front offset: 1.5” forward
Rear offset: 1.5” rearward
1.25” DOM steel tubing
Adjustable camber
Uses factory ball joints and bushings
Works with factory wheels/tires
Company says Rhino axles required with rear kit - extra cost $399.90
2) Highlifter - Front and rear offset high clearance A-arm kits for the S 900
Front kit: $429.95
Rear kit: $389.95
1.0625” DOM steel tubing
No camber adjustment
Works with factory wheels/tires/axles
3) Off Road Beast (ORB) - Front and rear offset high clearance A-arm kits for the S 900 with Heim joints
Front kit: $760 w/color, $700 raw
Rear kit: $610 w/color, $550 raw
Front offset: 2”
Rear offset: 1.5”
Adjustable camber
Uses factory bushings
Chromoly Heims are used in place of ball joints
Company says must use a spacer with factory wheels or
14” 4-3 offset aftermarket wheels
4) HCR Racing - Front and rear offset high clearance A-arm kits for the S 900
Front and rear kit sold as one item: $1,990 raw, $200 extra for powder coat
Front offset: 1”
Rear offset: 1”
Tig welded 4130 steel box construction
5) RacerTech - Front and rear offset high clearance A-arm kits for the S 900
Kit: $2,495
Front offset: 1”
Rear offset: ??
Adjustable camber/caster
Heim joints
Chromoly tubing
Build to order 3-4 weeks
6) Outcast Fab Works - 5” lift kit with 8 control arms, lowers arched for S 900
Kit $875
Front offset: 1.5”
Rear offset: 0.0”
Lift brackets require aftermarket axles
7) Rage Customs - Arched front/rear lowers and 4” lift kit for the S 900
Front lowers: $449.99
Rear lowers: $449.99
Full lift kit: $999.99
No offset arms, all direct factory replacement
Lift kit includes front shock relocation bracket and hardware
8) Special Carrier - Heim jointed 2” offset high clearance A-arm kit for the 2011-2014 900XP
Kit: $730 powdercoated
Chromoly Heim joints in place of ball joints
Adjustable camber
Works with factory axles
9) Zbros - No A-arms for Rzr S 900
10) Cognito - No A-arms for Rzr S 900
If I left any vendors out or messed up the details on any of these vendors, please post corrections.
Also any comments or recommendations on any of these products would be great. The more I can learn the better!
Mao® likes this.
w.wood is offline
post #2 of 40 Old February 9th, 2016, 07:25 AM
duramaxx866's Avatar
Member #85212
View duramaxx866's Photo Gallery(0)
Re: High Clearance Offset A-arms
I have the super atv a arms love them only thing is voided my warranty and when my from diff blew they would not cover anything. On the other hand i was riding this weekend and slide into a huge rock didn't move lol and smashed my whole side and only bent the T joint on the end of the a arms if i had stock a arms would of been destroyed. Called them up Monday its under warranty and having a new only hopefully tom no charge thats how awesome they are!!
2015 rzr 900s
super ATV a-arms,dragon fire bumper, cage wrx roll cage, sti hd rims, moto hammer tires, bmp clutch kit, pro amour harness,Gorrlia axles,
duramaxx866 is offline
post #3 of 40 Old February 9th, 2016, 07:43 AM
apexx616's Avatar
First Name: Dave
My RZR: 2015 S 900 EPS
Member #72860
View apexx616's Photo Gallery(0)
I run the SATV, and I run the factory axles in the rear. No popping or problems, haven't broken an axle. I figured if Highlifter could to a 1.5 rear offset without new axles, I probably could keep my stock axles. I just tweaked my alignment to my preference this past weekend, which was easy to do as well. For the price I think they can't be beat. Don't forget to get the forum discount as well.
They also offer a lifetime no-questions-asked warranty. I called and confirmed - if I wrap it around a tree, I can send back any damaged arms and get them replaced for the cost of shipping the broken ones back. They've performed great for me, and I would buy them all over again.
As you can see, I'm also running big heavy tires. 30" outback max, about 55lbs each, and having no problems.
Also forgot to mention - I've called and talked to them about many different things, very knowledgeable team every time I call, they get me the answer. I've had them take my number and they always call me back. Great company.
apexx616 is offline
post #4 of 40 Old February 9th, 2016, 07:50 AM
Contact: 855-743-3427
SuperATV's Avatar
First Name: SuperATV
Member #7943
Thanks for chiming in with you good experiences guys, greatly appreciated. We stand behind all our products 110% percent. Anyone wanting a great deal on any of our products don't hesitate to send me over a PM for a great deal.
4sstew likes this.
SuperATV Official Website
SuperATV is offline
post #5 of 40 Old February 9th, 2016, 04:54 PM
RzrriderX's Avatar
My RZR: 16 900s
Member #104105
View RzrriderX's Photo Gallery(0)
When you buy the super atv arms do they include upper and lower? And also if apexx616 is running the rears on stock axles,do you have to run the rhino axles or is it more of a precaution?
RzrriderX is offline
post #6 of 40 Old February 9th, 2016, 05:36 PM
switchman8's Avatar
Member #82408
View switchman8's Photo Gallery(0)
Hopefully you do get them, they sure as hell havent sent me my rear A-arms for my scrambler, its been two years since they said they would, more than once.
2015 popo rzr 900s, Mammoth mayhems, highlifter 2-5" lift, Cobra axles, QSC clutch kit, and super atv arched a arms to install, new proper secondary on order
2014 can am outlander - PPSM built, 31" OLs, muzzy exhaust, PCV, xmr rad relocate, PPSM snorkels
2013 popo scrambler 850 - Monster mayhems, aaen exhaust, triangle snorkels, 2" super atv lift, highlifter dhts
switchman8 is offline
post #7 of 40 Old February 9th, 2016, 05:49 PM
kylemcmahon1's Avatar
Member #85924
View kylemcmahon1's Photo Gallery(0)
I ordered Sunday front and rear arched and raked a arms with the 3 inch lift. When I get them on will let u know what I think of them.
kylemcmahon1 is offline
post #8 of 40 Old February 9th, 2016, 05:56 PM Thread Starter
w.wood's Avatar
First Name: Bill
My RZR: 2015 S 900
Member #76672
If you buy a kit that is offset forward or rearward you have to get uppers and lowers, no way to offset the wheel hubs without changing both.
Some of these kits only include arched lowers but they have no offset. You would use that type kit if you don't want to increase your wheelbase but do want the extra clearance of the arched arms.
Pretty sure SATV does sell front A-arms with no offset but I think that kit does include uppers and lowers. Definitely check with them to make sure you get the right kit.
w.wood is offline
post #9 of 40 Old February 9th, 2016, 06:36 PM
RzrriderX's Avatar
My RZR: 16 900s
Member #104105
I didn't fully read the details about the arms on there website. It is a complete kit with 4 arms. That's my bad
Now I'm just curious about the axles for the rear.
post #10 of 40 Old February 10th, 2016, 04:20 AM Thread Starter
w.wood's Avatar
First Name: Bill
My RZR: 2015 S 900
Member #76672
Yes, the issue with axles for the rear is a tough one for me too because SATV says you need the aftermarket axles (they sell Rhino) but many guys here on the forum run the rear kit with factory axles and say they have no problems.
If you watch the Video labled "How to Check for Axle bind" on this link, I think you will see the answer:
Polaris RZR S 900 High Clearance Rear Offset A-Arms : Polaris : RZR S 900 : A-Arms
The video shows that the factory axles definitely bind at full droop, which is obviously bad. BUT, you can also see when the guy in the video lifts the hub a couple of inches, the factory axles turn free. Therefore when the car is on the ground at ride height, the axles will not be binding. The axles will only bind at full droop so if you never (or rarely and briefly) get full droop, you should be fine based on what other guys have said.
If I had the SATV rear kit with factory axles I would definitely not be jumping the car but I would like to know what happens if one side gets in full droop as in rock crawling and that axle gets bound up. Does it break immediately and if so are other parts also damaged like the diff or hub? That could get real expensive.
w.wood is offline
post #11 of 40 Old February 10th, 2016, 07:52 AM
TheJamesGang's Avatar
First Name: Huey
My RZR: 2015 900 S
Member #81282
View TheJamesGang's Photo Gallery(1)
That would be the same question for me. I'm not a Rally type driver. But rock crawling is not uncommon. At what point is axle bind an issue?
TheJamesGang is offline
post #12 of 40 Old February 10th, 2016, 08:00 AM
SuperATV's Avatar
Member #7943
Yes kit comes with both upper and lower a-arms.
I am unsure how he is getting away using stock axles in the rear check out this video showing a stock axle is in a bind before hooking shock back up:
SuperATV is offline
post #13 of 40 Old February 10th, 2016, 08:02 AM
SuperATV's Avatar
Member #7943
That sure does not sound like us. We take great pride in customer service and stand behind our word and products. Sending you over a PM now to get more info on your situation.
SuperATV is offline
post #14 of 40 Old February 10th, 2016, 11:50 AM
superjunior's Avatar
First Name: Dan
My RZR: 2015 900S
Member #74479
So who sells arched a arms that do NOT change the offset or factory geometry?
superjunior is online now
post #15 of 40 Old February 10th, 2016, 12:15 PM
rockrig's Avatar
First Name: Jim
My RZR: 2015 900S
Member #83413
View rockrig's Photo Gallery(0)
Just to be clear: the SATV doesn't change the width at all?
rockrig is offline
Rzr 1000 UTV-Works high clearance radius rods Vanwilder Polaris RZR Parts For Sale 18 March 29th, 2016 07:50 AM
Team Alba Racing / High Clearance Radious Arms - Made in Taiwan RWTDCT General RZR Discussion 10 January 19th, 2016 11:15 AM
