Rapid Reaction clutch? - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old November 2nd, 2015, 09:06 PM Thread Starter
WillRide's Avatar
First Name: Will
My RZR: S 900 EPS
Member #36159
View WillRide's Photo Gallery(0)
On my 2015 900-S EPS, does it have the 'Rapid Reaction' clutch? I'm about to replace my belt with a Gates, and I've reviewed several videos. I just want to know which one it is.
WillRide is offline
post #2 of 9 Old November 3rd, 2015, 03:48 AM
Larsonator's Avatar
My RZR: 2015 900S
Member #73551
View Larsonator's Photo Gallery(0)
Re: Rapid Reaction clutch?
Yes, it looks like this
Larsonator is offline
post #3 of 9 Old November 3rd, 2015, 04:56 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
The clutch will not determine which belt you get but you do have the rapid reaction style.
Todd
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #4 of 9 Old November 3rd, 2015, 08:42 AM Thread Starter
WillRide's Avatar
First Name: Will
My RZR: S 900 EPS
Member #36159
Todd
I know but it looks like the method for removing the old belt might be a little easier. In the video, the guy doesn't use the tool to spread the plates, he just squeezes the belt with his hand. I'll try that technique on mine and see if it works.
WillRide is offline
post #5 of 9 Old November 3rd, 2015, 08:45 AM
Larsonator's Avatar
My RZR: 2015 900S
Member #73551
Yeah, there's nothing "easy" about it...
I've read that the right sized oil filter wrench used on the hub of the secondary works to rotate the outer sheave and separate them, but I have not tried it.
When you're walking the belt off and on, make sure the primary clutch doesn't rotate clockwise.
post #6 of 9 Old November 3rd, 2015, 12:22 PM
TheJamesGang's Avatar
First Name: Huey
My RZR: 2015 900 S
Member #81282
View TheJamesGang's Photo Gallery(1)
Same setup as you here. Replaced my OEM belt with the Gates.
1. Remove the driver side rear grease zerk (way easier to remove the belt cover).
2. Remove the belt cover (8mm socket with extension).
3. Squeeze the upper and lower parts of the belt in the middle. This should release the spindles enough to remove the belt. If you can't squeeze it enough, tie a thin rope over the upper and lower and tie into a loop. Then place the socket extension into the rope and twist until the belt squeezes fully.
4. The OEM belt (for me at least) got stuck around the rear clutch wheel. I had to really work it to get it to come off.
5. The Gates belt goes on easier than removing the OEM.
6. Reverse the process from there.
7. Winner Winner Chicken Dinner!
TheJamesGang is offline
post #7 of 9 Old November 6th, 2015, 08:55 AM
apexx616's Avatar
First Name: Dave
My RZR: 2015 S 900 EPS
Member #72860
View apexx616's Photo Gallery(0)
I use an oil filter wrench like this one to help with rotating the clutch as I walk it off. Works great.
http://www.amazon.com/TEKTON-5866-12-Inch-Filter-Pliers/dp/B000NPR33O/ref=sr_1_1?s=automotive&ie=UTF8&qid=1446828926&sr=1-1&keywords=oil+filter+wrench
apexx616 is offline
post #8 of 9 Old November 6th, 2015, 11:05 AM
RVSPERFORMANCE's Avatar
Member #84162
View RVSPERFORMANCE's Photo Gallery(0)
Just remove the retaining bolt on the rapid reaction and it will fall right open and let you roll the belt right off.
RVSPERFORMANCE is offline
post #9 of 9 Old January 10th, 2016, 03:36 PM
Midnight.Sun's Avatar
First Name: Kevin
My RZR: 2011 Razor 4 800 Robby Gordon
Member #63818
View Midnight.Sun's Photo Gallery(0)
This thread had some good suggestions - get a piece of rubber or wood cut to the same angle as the secondary sheaves in the driven clutch to wedge open the secondary and make it easier to get the belt on (or off, though off is much easier -- just pull up or push down on the belt when it's in to loosen up the secondary).
https://www.rzrforums.net/general-rzr...en-clutch.html
Last edited by Midnight.Sun; January 10th, 2016 at 03:37 PM. Reason: forgot the link...
Midnight.Sun is offline
Rapid response clutch 1fastmofo RZR XP 900 2 May 3rd, 2014 06:21 PM
Video: Rapid Reaction secondary disassembly Hunterworks Hunterworks 0 February 8th, 2013 08:12 AM
Team rapid reaction helix UTV Inc. UTV Inc 1 July 11th, 2012 06:24 PM
08 non rapid reaction secondary dr.vacation Polaris RZR Parts For Sale 2 July 29th, 2011 10:15 AM
rapid reaction clutch dr.vacation Polaris RZR Parts For Sale 2 July 29th, 2011 10:14 AM
