Catching Air - Polaris RZR Forum - RZR Forums.net
post #1 of 11 Old June 10th, 2019, 05:26 PM Thread Starter
Dave961's Avatar
First Name: Dave
My RZR: 2017 S1000
Member #269832
View Dave961's Photo Gallery(0)
Catching Air
I have a 2017 S1000 with Rhino 2 axles. I think the rest of the suspension is stock (I bought it used). I've been pretty light footed while getting used to the machine, but I know I'm going to start nailing it soon. I don't plan on jumping high on purpose, but if I'm going fast and hit a bump I could see it leaving the ground. I'm just curious with a stock suspension will I break something catching air?
- Dave
Dave961 is offline
post #2 of 11 Old June 10th, 2019, 07:34 PM
superjunior's Avatar
First Name: Dan
My RZR: 2015 900S
Member #74479
Re: Catching Air
Catching some air isn't going to hurt anything. Now if you're going for big air, things can break, and the S tends to nose dive so things can go bad quick. Also the S isn't an xp, not nearly as plush in the suspension department
superjunior is offline
post #3 of 11 Old June 10th, 2019, 08:03 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: Catching Air
Yeah, gonna have to remember that “catching air” is a relative term. You can definitely leave the ground a bit, but a smooth landing will be your friend. If you start going big and landing hard, you will break stuff. That hold true no matter how much suspension you have, the difference is how “big” you can go, before it becomes a hard landing.
And yeah... watch out for that nose dive... it’ll get ya.
2018 XPT4 - Bailey
RWB713 is online now
post #4 of 11 Old June 11th, 2019, 12:29 PM
william_04_x's Avatar
Member #16899
View william_04_x's Photo Gallery(0)
Re: Catching Air
Crank up your shock dials, or you'll bottom out.
2010 800 White LE
2017 S1K Indy Red
william_04_x is offline
post #5 of 11 Old June 12th, 2019, 01:11 PM
RZRRcr's Avatar
First Name: Willy
My RZR: 2016 RZR 1000S and Arctic Cat 700 Wildcat Trail
Member #125969
View RZRRcr's Photo Gallery(0)
Re: Catching Air
Get some Springs, Turn up the Compression and get some Limiter Straps and you are set. If you don't let off the Throttle you wont have any Nose End problems. That works in Whoops too, if you can commit.
RZRRcr is offline
post #6 of 11 Old June 12th, 2019, 03:30 PM
Jtoor43's Avatar
Member #268676
View Jtoor43's Photo Gallery(0)
I’ve never jumped my Rzr but I thought I read somewhere if you stay on the throttle when it lands, there is a increased chance of breaking axles. Is that true?
Jtoor43 is offline
post #7 of 11 Old June 15th, 2019, 02:14 PM Thread Starter
Dave961's Avatar
First Name: Dave
My RZR: 2017 S1000
Member #269832
Re: Catching Air
Thanks for all the great replies!
- Dave
Dave961 is offline
post #8 of 11 Old June 15th, 2019, 03:01 PM
First Name: Dan
My RZR: 2015 900S
Member #74479
Re: Catching Air
Yep, dont wanna be on the gas when landing
post #9 of 11 Old July 6th, 2019, 01:58 AM
RZRRcr's Avatar
First Name: Willy
Member #125969
Re: Catching Air
Being a Dirt Biker all my life I tend to keep it on the gas when I land, I have tried with Throttle off but does not seem to be any difference, they break either way, the throttle off thing is dangerous, just carry extra axles, you will get pretty fast at replacing them. They usually break at the CV Joint so axle diameter is not as important as CV Joint size.
A good rule of thumb is "If you have doubt, pin it" this applies only if you are riding fast, if you are going slow you can stop in time.
RZRRcr is offline
post #10 of 11 Old July 6th, 2019, 04:22 AM
CGturba's Avatar
Member #269918
View CGturba's Photo Gallery(0)
When in doubt, Throttle out!!!!
CGturba is offline
post #11 of 11 Old July 10th, 2019, 05:59 PM
RZRMOMMY's Avatar
Member #263710
View RZRMOMMY's Photo Gallery(0)
When hitting some of the hills at Hatfield McCoy, I bottomed out right away with the shocks set how they came factory, I had to tighten them all the way and had no more trouble. I definitely can see where the xp is definitely better for jumping. Definitely make sure you are on the gas at the top of the jump however this machine always seems to land on the front tires first. It did take everything I could throw at it l, there were some sections I was hitting jumps and whoops at 30 to 40 mph. I should also note most of those jumps are probably in the 4-6 ft range, I wouldn't want to be jumping at a mx track with a rzr s
RZRMOMMY is offline
