Power upgrade - Polaris RZR Forum - RZR Forums.net
 8Likes
post #1 of 24 Unread April 11th, 2019, 07:48 AM Thread Starter
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
View kleake's Photo Gallery(0)
Power upgrade
The S1000 has 100hp, the XP has 110hp. I'm trying to remember what the differences were that made up that 10hp difference, and curious if there are any simple upgrades to gain a little out of the S model. I'm not looking for huge gains, but if I can gain 10-20hp with some tuning and such it would be nice.
2017 RZR 1000 S EPS with some goodies
2015 Grizzly 700 Special Edition
2013 Grizzly 700 Special Edition
2006 Kawasaki Prairie 360
kleake is online now
post #2 of 24 Unread April 11th, 2019, 09:34 AM
CrispySmurf's Avatar
First Name: Crispy
My RZR: 2016 RZR 1000 S
Member #267780
View CrispySmurf's Photo Gallery(0)
Re: Power upgrade
Iím interested to see the responses to this. Though Iím new to the SXS world, with cars, outside of air intake and a slip-on exhaust (muffler) we should probably look a ďpackagesĒ or ďstagesĒ. As you modify things it changes the overall stresses and dynamics. So, it very well could be that the recommendation would be a flashed ecu and clutch kit paired with exhaust and intake.
As I mentioned, I could totally be wrong. I also think this is the lie I tell myself to buy more than one item at a time.
So, anyone else feel free to speak to the exact changes in the motor from the S to the XP, and also my comments above are open for agreement or disagreement.
2016 RZR 1000 S
SATV Front Bumper
SATV High Clearance Front & Rear A-Arms
SATV Nerf Bars / Rock Sliders
Lower Doors
HMF Rear Bumper
GPS Beadlock Wheels
27" GPS Gravity 650 tires
CrispySmurf is offline
post #3 of 24 Unread April 11th, 2019, 06:36 PM Thread Starter
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
Re: Power upgrade
I do agree that all of those things play a part, but i'm mostly looking at the engine. It's like a car, you increase power from the engine, but to fully get it's max you gear it for your intended needs. A jeep you can increase power, but you also gear it for the type of driving and such you will be doing. I am looking for the same. I am pretty happy with my setup, and will likely change some gearing to be able to "crawl" the rocks better, but first I want to see if there is a relatively low cost improvement we can get out of the engine. Is the ECU the difference in the XP or is there some internal changes to the engine as well? Once I see where the engine stands, then i'll look at gearing and clutches to apply that power as needed.
post #4 of 24 Unread April 12th, 2019, 05:51 AM
Contact: 855-743-3427
SuperATV's Avatar
First Name: SuperATV
Member #7943
Re: Power upgrade
The clutching is a little different, and the motor has more limitations on it from the factory because its a trail machine. Same with the 900 models. An ECU tune to get rid of the limiters and a little clutch kit can go a long way on the 1000 S.
SuperATV Official Website
SuperATV is offline
post #5 of 24 Unread April 12th, 2019, 08:11 AM
TRT221's Avatar
My RZR: 2018 XP1K EPS
Member #260614
View TRT221's Photo Gallery(0)
Re: Power upgrade
"An ECU tune to get rid of the limiters and a little clutch kit can go a long way"
Does this apply to the XP1K also?
SuperATV likes this.
TRT221 is online now
post #6 of 24 Unread April 12th, 2019, 08:35 AM
RickRou56's Avatar
My RZR: 2017 XPT Velocity Blue
Member #28887
View RickRou56's Photo Gallery(0)
Re: Power upgrade
Bikeman, AA, Evolution will get you some added HP with Tune and clutch.
There will be a noticeable increase.
900-1000ís XPís and Turbos.
Want more spend more.
Joey Strub Bmp likes this.
RickRou56 is offline
post #7 of 24 Unread April 12th, 2019, 09:33 AM Thread Starter
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
Re: Power upgrade
Clutch doesnt add HP, it does add better performance and response. I'm looking mostly at engine only to start with. Is it possible, for example to get 110-120hp from the S1000 engine?
Sent from my SM-G960U1 using Tapatalk
post #8 of 24 Unread April 12th, 2019, 01:06 PM
RickRou56's Avatar
Member #28887
Re: Power upgrade
Added HP is minimized if the clutch isnít tuned to use it. AKA the Sweet Spot.
And actually some units will benefit from a clutch kit only. Putting HP to the ground more effectively.
xrracrron likes this.
post #9 of 24 Unread April 12th, 2019, 01:59 PM Thread Starter
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
Re: Power upgrade
I definitely agree, but am looking for engine first, then see how the clutch can maximize that. If the xp has 110hp, and the S only has 100hp with the same engine, there should be a simple 10hp increase hidden in there somewhere. I'm thinking it's just ecm tuning.
post #10 of 24 Unread April 12th, 2019, 02:35 PM
RickRou56's Avatar
Member #28887
Re: Power upgrade
If I recall some of the differences are Cam, head, throttle bodies.
But yes ECU will likely get some of that HP.
Good luck.
post #11 of 24 Unread April 12th, 2019, 04:11 PM Thread Starter
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
Re: Power upgrade
Good luck.
I wouldn't think Polaris would have that many separate components when they could just de-tune the ecm if they want to drop 10hp. But this is the type of info I am looking for.
post #12 of 24 Unread April 12th, 2019, 06:05 PM
Jake ND's Avatar
First Name: jacob
My RZR: 2019 XP 1000
Member #266248
View Jake ND's Photo Gallery(0)
Re: Power upgrade
I think a person could compare the xp and 1000s by looking up the schematics parts list to narrow down the different parts.
Jake ND is offline
post #13 of 24 Unread April 12th, 2019, 08:31 PM
ljrat's Avatar
My RZR: RS1
Member #83394
View ljrat's Photo Gallery(0)
Re: Power upgrade
Bingo! Get the ECU tune and a clutch job! AA will do you right.
RS1: Full cage, Shck Ther, AA tune, De-CAT, PRP Seat, Pro Armor harness & bumpers,
XTR billet switch plate, street legal kit, custom tool storage, Warn/Axon in nose,
LED fog/light bar/backup/rock lights, race graphics
ljrat is offline
post #14 of 24 Unread April 13th, 2019, 07:58 AM Thread Starter
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
Re: Power upgrade
Per the AA website, with their tuner ~$500 it is a 7-8hp gain with the tuner alone. That still doesn't get it to the 110 of the xp? Sure with a clutch kit it will put it to the ground better, but again I am looking at raw engine HP only at this point. Clutch kits do nothing but change the ratio and timing of how the power is applied to the wheels, primarily by keeping the RPM in a higher range (lower overall gear ratio) which is not what I am after.
To be clear, I like to rock crawl and ride wooded trails usually below 15mph. I like the RPM to stay relatively low for these things (most clutch kits increase RPMs here), but if I can increase my HP a little bit, then I can also have a little more fun when I hit the dunes. I'm not racing, have no need to make my my machine scream on the top end. I am looking to keep the low end where it's at, just have a few more ponys when I do crank it up.
post #15 of 24 Unread April 13th, 2019, 08:05 AM
RickRou56's Avatar
Member #28887
Re: Power upgrade
RESEARCH. Add at Tune youíll get 10-12 HP out of an XP!
Not the same motor.
UTV INC RZR Under Hood 12V Power Terminal Kit UTV Inc. UTV Inc 129 December 6th, 2017 08:12 AM
Loss of power of power while driving, 2014 RZR S, stop and restart it power back Fay Dog RZR-S Specific Discussion 6 December 19th, 2015 07:39 PM
Best power upgrade for my 2010 rzr? Turbo? Big bore? jcbowtie General RZR Discussion 11 September 17th, 2012 07:05 AM
Alba Stage II cam and Power Commander V results. Kinda long... roguedriver RZR XP 900 38 August 27th, 2012 04:12 PM
safest power upgrade for the buck hawaiirzrs RZR-S Specific Discussion 1 July 8th, 2010 10:06 AM
