Power upgrade - Page 2 - Polaris RZR Forum - RZR Forums.net
 12Likes
post #16 of 25 Old April 14th, 2019, 07:37 AM Thread Starter
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
View kleake's Photo Gallery(0)
Re: Power upgrade
Originally Posted by RickRou56 View Post
RESEARCH. Add at Tune youíll get 10-12 HP out of an XP!
Not the same motor.
Ahhh perfect! So effectively dual throttle bodies, cam, and exhaust are different. Dual throttle bodies and cam should easily get that 10hp. Exhaust may just be different due to chassis since there isn't as much room back there, but may flow about the same. I really wouldn't have expected them to use a different cam between the two, but the rest makes sense.
Thank you!
2017 RZR 1000 S EPS with some goodies
2015 Grizzly 700 Special Edition
2013 Grizzly 700 Special Edition
2006 Kawasaki Prairie 360
kleake is online now
post #17 of 25 Old April 14th, 2019, 07:47 AM
RickRou56's Avatar
My RZR: 2017 XPT Velocity Blue
Member #28887
View RickRou56's Photo Gallery(0)
Re: Power upgrade
Pretty sure .....Itís a different head....as in different valves as well.
More fuel...throttle bodies more flow need different valves and valve train.
Possibly Injectors.
kleake likes this.
RickRou56 is offline
post #18 of 25 Old April 14th, 2019, 08:46 AM
Jake ND's Avatar
First Name: jacob
My RZR: 2019 XP 1000
Member #266248
View Jake ND's Photo Gallery(0)
Re: Power upgrade
A lot of times when companies add more horsepower they rob peter to pay paul if u get what im saying. They may be adding more power on top end for bragging rights and taking it away on bottom end usually. Ive noticed this in a couple of trucks and 4 wheelers ive had. Seems like the older models with less hp had more low end torque.
kleake likes this.
Jake ND is offline
post #19 of 25 Old April 16th, 2019, 05:44 PM
Mudplay's Avatar
First Name: Ron
My RZR: 2016 RZR S 1000 EPS
Member #75747
View Mudplay's Photo Gallery(0)
Re: Power upgrade
I will say I was looking at doing a tune and a clutch kit. I figured I’d go with the cheaper of the two first so I went with the bike man clutch kit on my 1000 S. I am so happy with the responsiveness that I have no need for any additional horse power on the trail. That’s $600+ saved. Also while you’re in there if you do change your clutch kit make sure you put a new belt on and switch your square pucks out to the round ones.
Rubydoobie, Rockwerx and texmich like this.
Would rather be right now! until then
Mudplay is offline
post #20 of 25 Old April 16th, 2019, 08:53 PM Thread Starter
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
Re: Power upgrade
Originally Posted by Mudplay View Post
I will say I was looking at doing a tune and a clutch kit. I figured Iíd go with the cheaper of the two first so I went with the bike man clutch kit on my 1000 S. I am so happy with the responsiveness that I have no need for any additional horse power on the trail. Thatís $600+ saved. Also while youíre in there if you do change your clutch kit make sure you put a new belt on and switch your square pucks out to the round ones.
Hood to know. I already changed out my pucks when I had about 100 miles on the machine. I'm not looking for more power on the trails, but wouldn't mind a few more ponys when I hit the dunes. The little S does pretty good already, but it never hurts to have a little more.
Sent from my SM-G960U1 using Tapatalk
post #21 of 25 Old April 16th, 2019, 09:21 PM
Mudplay's Avatar
First Name: Ron
Member #75747
Re: Power upgrade
Gotcha, sorry must have missed it was dunes, then i would most definitely tune it, my buddy has a 900s with a Bikeman tuned ECU and he gained a solid 10hp.
kleake and Joey Strub Bmp like this.
Mudplay is offline
post #22 of 25 Old April 17th, 2019, 07:19 PM
Rubydoobie's Avatar
My RZR: 2014 RZR S Le
Member #69972
View Rubydoobie's Photo Gallery(0)
Re: Power upgrade
Ive got a 17 1kS. Ive added a dalton clutch kit, pwrtune velocity intake tube, stage 1 tune from AA and an evo magnum slip on...it really turns this S into a trail monster
17 1kS
2014 RZR S Le Stealth Black / Voodoo Blue
Superwinch Terra 35S, Lock-n-ride roof, Dalton clutch / carbon belt, Airraid intake, Pro Armour rock sliders, Custom soft doors, Homebrew windshield, Dfr bash bumper, 2" RT lift, 29" Traxion Grippers, RT chassis brace, 14" blue hd 6's, satv rear bush guard, TA 1/2" UHMW main skid, Biggun eco slip on
Rubydoobie is offline
post #23 of 25 Old April 18th, 2019, 08:19 AM
Joey Strub Bmp's Avatar
First Name: Joey
My RZR: All models
Member #208601
View Joey Strub Bmp's Photo Gallery(0)
Re: Power upgrade
Originally Posted by kleake View Post
The S1000 has 100hp, the XP has 110hp. I'm trying to remember what the differences were that made up that 10hp difference, and curious if there are any simple upgrades to gain a little out of the S model. I'm not looking for huge gains, but if I can gain 10-20hp with some tuning and such it would be nice.
We are here to help you get your missing power out of your 1000. The main differences that limit the power on the S vs the XP is smaller valves, smaller lift/duration cams and intake design. The 1000 XP has dual throttle body with a huge intake plenum with the TB's between plenum and head. The 1000s has a smaller volume intake plenum and a single throttle body pre plenum. We can tune and get great gains I will attach dyno sheets of each set up.
Call us up and we can help you get the most out of your machine 715-483-3003
Name:	Polaris RZR 1000s.JPG
ID:	575506   Click image for larger version
Name:	Polaris RZR 1000 1065 build.JPG
ID:	575508   Click image for larger version
Name:	Polaris RZR 2015 1000 BuildUP.JPG
I welcome any comments or questions regarding Bikeman Performance Products. I am the guy behind the scenes at Bikeman that can answer just about any question you have. Please contact our sales department if you are looking to buy products. I am not online as much as I would like to be but I will try to be when I have time. You can also email me for support.
[email protected]
Joey Strub Bmp is offline
post #24 of 25 Old April 18th, 2019, 09:43 AM Thread Starter
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
Re: Power upgrade
Thank you Joey, this is great info!
Joey Strub Bmp likes this.
post #25 of 25 Old May 11th, 2019, 01:06 AM
RZRRcr's Avatar
First Name: Willy
My RZR: 2016 RZR 1000S and Arctic Cat 700 Wildcat Trail
Member #125969
View RZRRcr's Photo Gallery(0)
Re: Power upgrade
Check out PowerTune, they have some great Stage Packages, Bikeman also very good. Some people on the Forum have done the XP updates on their S's.
kleake likes this.
RZRRcr is offline
UTV INC RZR Under Hood 12V Power Terminal Kit UTV Inc. UTV Inc 129 December 6th, 2017 08:12 AM
Loss of power of power while driving, 2014 RZR S, stop and restart it power back Fay Dog RZR-S Specific Discussion 6 December 19th, 2015 07:39 PM
Best power upgrade for my 2010 rzr? Turbo? Big bore? jcbowtie General RZR Discussion 11 September 17th, 2012 07:05 AM
Alba Stage II cam and Power Commander V results. Kinda long... roguedriver RZR XP 900 38 August 27th, 2012 04:12 PM
safest power upgrade for the buck hawaiirzrs RZR-S Specific Discussion 1 July 8th, 2010 10:06 AM
