Gates drive belt - Polaris RZR Forum - RZR Forums.net
 7Likes
post #1 of 22 Old March 17th, 2019, 08:49 AM Thread Starter
Sledman's Avatar
First Name: Kevin
My RZR: 2018 1000 S
Member #136473
View Sledman's Photo Gallery(0)
Gates drive belt
After 1700 miles of abuse I finally killed my gates 27C4159 drive belt. Is this part number still the preferred gates replacement belt?
2018 RzR S 1000
2016 Polaris 800 Pro RMK Axys 163/3
2011 KTM 990 Adventure
2008 KTM 300 XC-w(e)
2006 HD Softail Deuce 98"
Sledman is offline
post #2 of 22 Old March 17th, 2019, 09:05 AM
BWXT's Avatar
My RZR: 2018 XP1000 Black
Member #241858
View BWXT's Photo Gallery(0)
Re: Gates drive belt
While I carry a gates belt as a spare to my stock belt because it was rated high, doesn't string apart on failure, and the price is great; If I were buying a new belt today I would get the Hunterworks belt. Look it up on here. Todd knows his stuff on the clutching and belts on the RZRs like no one else, and he had his belts specially designed based on all of his experience and research.
GimpyRZR likes this.
BWXT is online now
post #3 of 22 Old March 17th, 2019, 12:32 PM Thread Starter
Sledman's Avatar
First Name: Kevin
My RZR: 2018 1000 S
Member #136473
Iím really glad you mentioned Hunterworks as I forgot about their belts. I have their roller kit in my secondary. Iíll give their belt a try this time, thank you!
AZ_TR0Y and BWXT like this.
2018 RzR S 1000
Sledman is offline
post #4 of 22 Old March 18th, 2019, 05:02 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Thanks for the comments
On that belt, the inside teeth are gone because it is too short. You must do random high speed runs not a lot of high speed stuff. It has too much belt travel since it is too short.
Todd
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #5 of 22 Old March 18th, 2019, 06:41 AM Thread Starter
Sledman's Avatar
First Name: Kevin
My RZR: 2018 1000 S
Member #136473
Todd
We ride a good mix, some high speed, some slow technical trails. In this case we were making some high speed runs through sand washes. When the belt came apart I had mistakenly left the RzR in low range and was hitting some pretty high rpms, like 8700 according to my navigator. 8300 to 8350 in high range after I put the OEM Polaris belt on. All this with a Dalton clutch kit and your secondary rollers installed and 30” tires, at about 3500’ ASL. In a few months we’ll be at much higher elevations.
I placed an order online with you for one of your replacement belts yesterday.
2018 RzR S 1000
Sledman is offline
post #6 of 22 Old March 18th, 2019, 07:35 AM
Sierracj5's Avatar
My RZR: 2017 XP4 1000
Member #197265
View Sierracj5's Photo Gallery(0)
Todd
Would you please elaborate on this?
Sierracj5 is offline
post #7 of 22 Old March 19th, 2019, 04:57 AM
First Name: Todd
Member #47437
Todd
I found out it is 1/8" too short and at full travel it pulls into the center of the secondary and pulls teeth out, only does it at high rpm in low or high
This video explains clutch travel and the use of a washer so watch it then at the end a link for the first version of this video has more info on the gates too
Todd
www.hunterworks.com
Todd
post #8 of 22 Old March 19th, 2019, 07:01 AM Thread Starter
Sledman's Avatar
First Name: Kevin
My RZR: 2018 1000 S
Member #136473
Todd
Todd
For my application, I don't need the added washer, correct? 2018 RzR S 1000.
Sledman is offline
post #9 of 22 Old March 19th, 2019, 07:05 AM
First Name: Todd
Member #47437
Oh yeah, applies to anything 1000 in my book.
If you are running a gates that is too short or even the stock belt, overtravel needs to be checked. No reason this does not apply to any 1000, same distance between shafts, pulleys are the same etc
www.hunterworks.com
Todd
post #10 of 22 Old March 20th, 2019, 07:03 PM Thread Starter
Sledman's Avatar
First Name: Kevin
My RZR: 2018 1000 S
Member #136473
Look what showed up today, that was quick....thank you Todd!
AZ_TR0Y likes this.
2018 RzR S 1000
Sledman is offline
post #11 of 22 Old March 20th, 2019, 07:54 PM
HNDARDR's Avatar
First Name: Steve
My RZR: 2016 XP 4 1000
Member #19112
View HNDARDR's Photo Gallery(0)
My gates belt I got from Todd just started doing that this past weekend. What do I need to do to fix this? My rzr is a 2016 xp4 1000.
Sent from my SM-J700P using Tapatalk
Enjoy playing in the dirt or water.
HNDARDR is offline
post #12 of 22 Old March 20th, 2019, 08:20 PM
AZ_TR0Y's Avatar
First Name: Troy
My RZR: 14 RZR1000 2 seater
Member #47129
View AZ_TR0Y's Photo Gallery(0)
Look into doing the spacer in your primary when replacing your belt.
It is worth a try to use one of the new Hunterworks thin belts and judge for yourself on how it performs.
The spacer can be installed with the primary on the car if you donít have the removal tool.
Donít over tighten your bolts.
Clean everything with a scotch bright pad and air.
HNDARDR and BWXT like this.
2014 rzr1000 2 seater.
AZ_TR0Y is offline
post #13 of 22 Old March 21st, 2019, 03:59 AM
First Name: Todd
Member #47437
Thank you!!!
Todd
www.hunterworks.com
Todd
post #14 of 22 Old March 21st, 2019, 04:00 AM
First Name: Todd
Member #47437
After we started making our own belts we stopped selling the gates then later on after slight change in our belt, I was doing a belt travel test on it, thought we had an issue and checked the gates and OE and that is when I found out it was 1/8" too short and will cause this at high speed.
www.hunterworks.com
Todd
post #15 of 22 Old March 21st, 2019, 04:24 AM Thread Starter
Sledman's Avatar
First Name: Kevin
My RZR: 2018 1000 S
Member #136473
So Todd, I ordered the thick primary spacer this morning, I should mark the bearing in my primary prior to installing the belt (and the spacer) then make a couple of high speed runs to see if the marker is worn off, if not don’t install the spacer, if the mark is worn off then install the spacer?
2018 RzR S 1000
Sledman is offline
BRAND NEW XP1000 DRIVE BELT -BRAND NEW 900- 900 S DRIVE BELT FOR SALE BLOODY BILL Parts For Sale - Southwest / Arizona 1 November 18th, 2017 12:04 PM
Gates RZR Belt Part number confusion Hunterworks Hunterworks 1 March 12th, 2017 06:26 AM
Gates xp 1000 new drive belt hellrazor Polaris RZR Parts For Sale 3 April 3rd, 2016 10:56 AM
Belt Drive Failure and maintance hondabob RZR 570 Specific Discussion 12 August 31st, 2013 07:18 AM
BELT HELP!!!!! SUMTROUBLE RZR-S Specific Discussion 11 June 13th, 2011 05:45 PM
