Rear window? And belt ? - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old March 13th, 2019, 04:41 PM Thread Starter
RZRMOMMY's Avatar
Member #263710
View RZRMOMMY's Photo Gallery(0)
Hi just wanted to see what rear window you guys are running with harnesses, I was hoping to find one that somehow mounted behind the rear roll bar, also wanted an extra belt, are most running OEM? Thanks Michelle
RZRMOMMY is offline
post #2 of 4 Old March 13th, 2019, 05:52 PM
SportHO's Avatar
First Name: David
My RZR: '09 Green, 2018 XPT
Member #3707
View SportHO's Photo Gallery(0)
Re: Rear window? And belt ?
I run the Polaris lock & ride rear windshield along with click-six harnesses
Hunterworks for the drive belt.
Geaux Tigers!
SportHO is online now
post #3 of 4 Old March 13th, 2019, 06:38 PM
superjunior's Avatar
First Name: Dan
My RZR: 2015 900S
Member #74479
I run the same set up, the combo works excellent. Be careful if you go that route though, they dont make the rear poly panal with the harness pass throughs anymore. I just replaced mine but had to do some digging with the original part #, which the dealers don't even have in their system anymore
superjunior is offline
post #4 of 4 Old March 14th, 2019, 05:17 AM Thread Starter
RZRMOMMY's Avatar
Member #263710
Thanks for the info
RZRMOMMY is offline
SuperATV rear window install chiefcheese General RZR Discussion 2 October 8th, 2018 10:00 AM
Clutch discussion, causes of heat/belt failures (long) cwarner Engine and Drivetrain 19 February 4th, 2018 10:36 AM
200 mile belt life 2016 XPT - what to expect / what can I do about it? SandyEggo RZR XP Turbo 56 February 3rd, 2018 12:43 PM
September 2014 RZR of the Month Voting is Open! Wreckless123 RZR Of The Month Contest! 11 September 2nd, 2014 07:05 PM
Rear Window Compatibility Question. JEFF150 Extreme Metal Products 0 March 14th, 2012 07:07 PM
