RPM with AA tune - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Hunterworks
post #1 of 7 Old September 5th, 2018, 02:15 PM Thread Starter
DWSrzr's Avatar
First Name: Dwight
My RZR: 2017 1000S
Member #64027
View DWSrzr's Photo Gallery(0)
Wrench RPM with AA tune
My 2017 1000s with AA stock tune will only reach 7300 Rpm in high gear. The limiter is set higher.
I am running 30" tires with Dalton clutch kit. Clutches resently inspected and cleaned cleaned.
Should I expect more Rpm in high gear??
Due to recent budget cuts and the rising cost of electricity, gas and oil, as well as current market conditions, the light at the end of the tunnel has been turned off.
DWSrzr is offline
post #2 of 7 Old March 27th, 2019, 12:51 PM Thread Starter
DWSrzr's Avatar
First Name: Dwight
My RZR: 2017 1000S
Member #64027
Re: RPM with AA tune
Any have any replies to this?
DWSrzr is offline
post #3 of 7 Old March 27th, 2019, 03:39 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
I don’t have the answer to why, but yes, it should reach shift phase rpm above 8000 and then basically pull all the way to rev limiter if you stay in it
2018 XPT4 - Bailey
RWB713 is online now
post #4 of 7 Old March 27th, 2019, 05:24 PM
william_04_x's Avatar
Member #16899
View william_04_x's Photo Gallery(0)
Have you made any clutch adjustments since? How is your primary set up now?
2010 800 White LE
2017 S1K Indy Red
william_04_x is offline
post #5 of 7 Old March 28th, 2019, 05:45 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Low RPM at top speed is a power related issue, I would be suspect of the tune or some other issue that popped up.
Very rare that anything clutch related causes low rpm issue at top speed
So the question is what is the last thing you changed before it went lower? If tune then that might be it
DWSrzr likes this.
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #6 of 7 Old April 17th, 2019, 08:25 PM
Rubydoobie's Avatar
My RZR: 2014 RZR S Le
Member #69972
View Rubydoobie's Photo Gallery(0)
Yes...i had the same issue...call dalton. They ended up sending me a new primary spring for a sportsman highlifter 1000 (gold i believe) solved my issue
17 1kS
2014 RZR S Le Stealth Black / Voodoo Blue
Superwinch Terra 35S, Lock-n-ride roof, Dalton clutch / carbon belt, Airraid intake, Pro Armour rock sliders, Custom soft doors, Homebrew windshield, Dfr bash bumper, 2" RT lift, 29" Traxion Grippers, RT chassis brace, 14" blue hd 6's, satv rear bush guard, TA 1/2" UHMW main skid, Biggun eco slip on
Rubydoobie is offline
post #7 of 7 Old May 11th, 2019, 02:13 AM
RZRRcr's Avatar
First Name: Willy
My RZR: 2016 RZR 1000S and Arctic Cat 700 Wildcat Trail
Member #125969
View RZRRcr's Photo Gallery(0)
It is your Primary Clutch Setup. You should get to almost 8300 RPM. The S motor being more a low end motor you might be OK. Point being, you have more HP at 7300 than 8300.
RZRRcr is offline
Clutch discussion, causes of heat/belt failures (long) cwarner Engine and Drivetrain 19 February 4th, 2018 11:36 AM
200 mile belt life 2016 XPT - what to expect / what can I do about it? SandyEggo RZR XP Turbo 56 February 3rd, 2018 01:43 PM
Aftermarket Assissins Powervision CX Level 1 Tune Initial impressions Bullitt427 RZR S 1000 0 July 29th, 2017 06:35 PM
Deeper Explanation of Shift RPM Hunterworks Hunterworks 18 June 13th, 2017 07:55 AM
Fuel Controller or ECU Tune?? notenufftoys RZR 1000 Engine 19 May 27th, 2016 11:30 AM
