2017 1000S - Cranking Springs for Clearance? - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By kleake
  • 1 Post By toclcl
post #1 of 10 Old May 2nd, 2017, 02:37 PM Thread Starter
toclcl's Avatar
First Name: Todd
My RZR: 2017 RZR 100S
Member #144729
View toclcl's Photo Gallery(0)
Hey guys. Picked up a 17 1000S the other day. Quite a step up from my 800S! I'm wondering about cranking the springs for a bit more clearance. A buddy of mine cranked his all the way up for lift. Anyone have any insight on pros and cons to this? Looking to get 2 inches out of it, if it can be safely done while still ride decent.
Todd
Sent from my SM-G935W8 using Tapatalk
2017 RZR 1KS Spectra Orange - UTVGiant Orange Roof, UTVGiant Doors, Rear Mesh, Warn 4K Winch, Stock XP Wheel/Tires, SATV Arched A-Arms, LED Light Bar & Pods.
2012 RZR S 800 - SATV 3" Lift, 28s on 14" STI's, Snorkelled, Clutched, Big Gun Exhaust, Too Much Invested. [SOLD]
2017 GMC Denali Dmax 3500HD
2013 Keystone Hideout 26'
toclcl is offline
post #2 of 10 Old May 2nd, 2017, 06:56 PM
william_04_x's Avatar
Member #16899
View william_04_x's Photo Gallery(0)
Re: 2017 1000S - Cranking Springs for Clearance?
Give it a try, and see how it goes. If it's brand new, it will settle a bit. XP take off tires will gain you an inch, and put Big Horns under your wheels.
There are quite a few S1K spring threads. Great reading.
Congrats on the new ride!
2010 800 White LE
2017 S1K Indy Red
william_04_x is offline
post #3 of 10 Old May 10th, 2017, 12:50 PM Thread Starter
toclcl's Avatar
First Name: Todd
Member #144729
Thanks man! Took it out this weekend, and yes it did settle a bit. I will for sure take a look and see what I can find online for factory takeoffs, there are a ton of guys selling rims and tires off new machines up here. Factory Dirt commanders don't do too well in the deep mud, I feel the Bighorns will be better.
Will post an update in about a weeks time when I crank the springs. She sits low right now due to the settling.
toclcl is offline
post #4 of 10 Old May 11th, 2017, 10:59 AM Thread Starter
toclcl's Avatar
First Name: Todd
Member #144729
Also,
One more question. I haul the thing on a rack on my truck and tow a bumper pull camper. So the front end is on top of my truck. I use the winch to snug it up, is there any issue with that and the springs? I was told to snug it down with the winch so that there is no suspension movement so the unit won't move. I'm wondering if this may be wrong and may lead to spring failure. Any thoughts?
toclcl is offline
post #5 of 10 Old May 11th, 2017, 11:47 AM
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
View kleake's Photo Gallery(0)
I haul mine on my bed cover similar to your setup and strap it down so it's suspension can move. It absorbes a lot of the road that way and isn't an issue. If yours is above the cab, total height may be an issue. Shouldn't hurt the springs either way unless it's really compressed far for long periods.
Sent from my SM-G950U using Tapatalk
toclcl likes this.
2017 RZR 1000 S EPS with some goodies
2015 Grizzly 700 Special Edition
2013 Grizzly 700 Special Edition
2006 Kawasaki Prairie 360
kleake is offline
post #6 of 10 Old May 11th, 2017, 12:03 PM Thread Starter
toclcl's Avatar
First Name: Todd
Member #144729
Thanks for the insight. I am good for total height, was more or less wondering about the springs. Next trip out I will try just winching it a bit and not until the suspension doesn't move.
I'm sure it will be fine I just do not want to wear the springs out by doing this!
kleake likes this.
toclcl is offline
post #7 of 10 Old May 12th, 2017, 03:48 PM
Ron.S's Avatar
First Name: Ron
My RZR: 2019 XP 1000 Ride Command
Member #160905
View Ron.S's Photo Gallery(0)
You will lose ride quality by increasing spring preload past the factory spec for 13.5" clearance. If you ride smooth trails or don't mind a little extra jolt in bumps then go for it. My 17 rode so much better than prior model that I liked the stock setting until I rode one with aftermarket springs. Save your spine now you will appreciate it later!
Ron.S is offline
post #8 of 10 Old May 12th, 2017, 04:04 PM Thread Starter
toclcl's Avatar
First Name: Todd
Member #144729
Good to know, I will crank a little bit and see what I end up with. Only looking for an inch or two.. Looking at getting the RTpro Heavy dual Rate Springs down the road. Seem to be able to get a bit of lift just on springs alone!
toclcl is offline
post #9 of 10 Old May 12th, 2017, 07:47 PM
Metki's Avatar
Member #164697
View Metki's Photo Gallery(0)
You can gain a 1.5 by cranking it up and if you remove the front sway bar it will help take some of the roughness out but we also ride a lot of dirt bikes and four wheelers so I don't complain about the ride as much as sxs only riders do
Metki is offline
post #10 of 10 Old May 13th, 2017, 06:11 AM Thread Starter
toclcl's Avatar
First Name: Todd
Member #144729
Awesome to hear, I will give it a try without the front swaybar as well!
toclcl is offline
Ordered some racertech springs bPrice51 RZR S 1000 40 August 16th, 2016 11:30 AM
What brand dual rate springs should i get rkkoeb RZR S 900 25 July 31st, 2016 05:02 PM
2016 rzr xp1000 springs compared to 2015 gunner00 Suspension 0 July 16th, 2016 10:51 AM
4 Seater Shock Therapy Springs for sale quadr8cer12 Polaris RZR Parts For Sale 17 April 25th, 2016 10:49 PM
Best upgrade shock Springs for 1000s bPrice51 RZR S 1000 12 April 20th, 2016 06:22 PM
