Front diff issues - Polaris RZR Forum - RZR Forums.net
RZR RS1 Discuss the Polaris RZR RS1 here!
post #1 of 7 Old July 18th, 2019, 11:48 AM Thread Starter
Johnsmack's Avatar
Member #265374
View Johnsmack's Photo Gallery(0)
Canada Front diff issues
Anybody have any issues with their front diff making a lot of noise?
In 2wd and on the throttle there is a jingling/rattling sound comming from the front end, very load and annoying, almost like bolts in a mason jar. When I put it in 4wd the sound goes away but there is a loud drone that I can feel and hear that comes from the front diff only under power.
Took my unit to Polaris but they didn't even look at it. Something must be happening as the rear output seal on the transmission had to be replaced and the yolk nut had to be tightened. (This took them almost 40 days to do)
They would not look into the front end noise, just stated that they tested it and my complaint is unfounded. I reset my trip odo when I dropped it off. It had .9 of a KM on it.
Has anyone had this problem and actually had it diagnosed, or have any experience with this front diff that may have some ideas before I tear it apart?
Johnsmack is offline
post #2 of 7 Old July 19th, 2019, 11:21 PM
DBRs1's Avatar
Member #257810
View DBRs1's Photo Gallery(0)
These front diffs are pretty tough and hard to hurt. Only thing that will hurt them quickly is water on the fluid or a bad seal. As for the noise check the front drive shaft yoke and u joint at the front diff. I have went through 2 of them. The u joints are also a problem area as well as carrier bearing. Any of these can cause front drive line noise when not under load.
DBRs1 is offline
post #3 of 7 Old July 26th, 2019, 06:00 AM
Demon_Powersports's Avatar
First Name: Demon Powersports
Member #168049
View Demon_Powersports's Photo Gallery(0)
Re: Front diff issues
Front axle inboard spline could be worn out, you can grab the center shaft bar try to move it and see if there is any play on the inboard joint.
Follow Us on Instagram : @DemonPowersports
Like Us on Facebook : @DemonPowersports
Demon_Powersports is offline
post #4 of 7 Old July 26th, 2019, 11:21 AM
XMARGH's Avatar
Member #241850
Its very odd that the noise goes away in 4WD. Generally I would suspect the pinon bearing or carrier bearing but since it goes away in 4wd it has me thinking something to do with sprague cage. Possibly broken H Clips for the rollers.
Shawn
2018 Polaris RZR XP 1000 EPS Highlifter Edition
XMARGH YouTube Channel
XMARGH is online now
post #5 of 7 Old July 26th, 2019, 06:14 PM Thread Starter
Johnsmack's Avatar
Member #265374
Long story short, the dealership wanted to take a 2nd look. Dropped it off wednsday and they called today and said the prop shaft was the issue. When i get back to town next week i will see if that was it
post #6 of 7 Old August 3rd, 2019, 05:07 AM
DBRs1's Avatar
Member #257810
The drive shafts are a big issue in the rs1. Normally the front shaft yoke on the drive shaft spreads and will bust or the yoke that goes into the front diff gets all wallowed. My dealership I use has had to actually replace 2 frames under extended warranty because when the drive shafts broke up by the diff it beat the hell out of the frames.
DBRs1 is offline
post #7 of 7 Old Today, 01:25 PM
XMARGH's Avatar
Member #241850
That's very possible, I had my front prop shaft bend right at the yoke and it created quite a vibration and tore up a couple Pinon bearings before I caught it.
Shawn
