Slapping Noise Front & Rear - Polaris RZR Forum - RZR Forums.net
RZR RS1 Discuss the Polaris RZR RS1 here!
post #1 of 6 Old July 8th, 2019, 01:39 PM Thread Starter
johndog's Avatar
First Name: Ray
My RZR: 2018 RS-1
Member #167865
View johndog's Photo Gallery(0)
  Hi guys,      I have a 2018 RS-1 with a few mods 32" tires on 15 " bead locks.  When I go over studder bumps  or down rocky trails I hear what sound like cables slapping on a pan or plate. Its really loud and sounds  like the thing is going to fall apart.   No vibration felt, does it under power ( going slow) or coasting  down hills   over the bumps.  The only thing I find is the axles are REALLY sloppy at the diff's front and rear.  My  nephews turbo axles are loose but nothing like mine.  Do you guys think the axles are the cause??
johndog is offline
post #2 of 6 Old July 8th, 2019, 02:27 PM
Westernmvp3's Avatar
Member #266280
View Westernmvp3's Photo Gallery(0)
I have a 2019 XP 1000 and under short choppy bumps in rocky conditions at higher speeds awls I hear is like a Slappy rattle noise underneath mine TooIt drives me freaking crazy but I have 1000 hard miles on it and I can’t figure out what it was at first I thought it might’ve been the radiator lines but they’re fine
Westernmvp3 is offline
post #3 of 6 Old July 10th, 2019, 09:58 AM
jodyfj40's Avatar
First Name: Jody
My RZR: 2015 900s
Member #21879
View jodyfj40's Photo Gallery(0)
Re: Slapping Noise Front & Rear
The trans and clutches in the RS1 and the turbos make a lot of noise. I thought mine had issues at first until speaking with other owners. Just seems to be a normal noise on these units.
jodyfj40 is offline
post #4 of 6 Old July 10th, 2019, 10:36 AM
ktl5005's Avatar
First Name: Keith
My RZR: 2018 1000XP Ride Command
Member #215297
View ktl5005's Photo Gallery(0)
Pull your clutch cover and check the inside box above the belt. If you see marks then its belt slap.
ktl5005 is offline
post #5 of 6 Old July 10th, 2019, 06:34 PM Thread Starter
johndog's Avatar
First Name: Ray
My RZR: 2018 RS-1
Member #167865
Belt is new, that's what I first thought also checked out cover, no marks.
johndog is offline
post #6 of 6 Old July 14th, 2019, 08:08 AM
DBRs1's Avatar
Member #257810
View DBRs1's Photo Gallery(0)
Sounds like normal rs1 and turbo s clutch noise. These clutches make some serious rattling, banging, clicking if you start to push you car and or under heavy braking. It's very common and nothing to be alarmed about. My rs1 and my 3 buddies with turbo s rigs all do it.
DBRs1 is offline
