So I have been doing some homework here and what I'm finding is the turbo s upper a arms, lower a arms, radius rods, and trailing arms Should fit on a rs1. You would need to have a custom heim tie rod setup since the rack and pinion threads are different. You would also need the turbo s rear main aluminum spindles as well as axles from a turbo s. I'm also finding that the shock length is the same between the turbo s and rs1. Does anyone know if this has been done yet to get a longer travel 72" wide rs1? Seems like it could be very doable
The geometry of the rear radius rods I am 90% sure is different. Look at a turbo s and measure the distance between the radius rod bolts where they bolt to the frame and I think it’s wider that the rs1. Possibly get adjustable radius rods to make up for this but not sure what it would do through suspension travel. I have also been considering this and that is the biggest unknown for me. Front a arm tabs would have to be drilled out as the turbo s uses bigger hardware. Easy fix.
As for rear components the bolt pattern for the aluminum bearing housing that actually bolts to the trailing arm is different. I was at atvfourplay last night comparing things and did confirm that. I just put a call in too my friend that builds cages locally about frane side radius rod bolt hole location. Here is what I have found d I know is different.
*Rs1 inner tie rod threads 12mm and 14mm for turbo (easy fix run kryptonite 12mm inner with custom center tie bar)
*Rs1 a arm bolts are m12 and turbo s m14 (easy fix just drill them out and maybe put some weld washers on for strength)
*Rs1 rear wheel bearing housing bolt pattern different (easy just run turbo s rear bearing housings)
*Obviously s axles are longer but s axles will direct swap
*Shocks are same length but would need full re spring and valve due to leverage change.
I think this swap would be a exelent way to get a solid mid travel suspension setup on a rs1. I think it would take minimal work. So many people ditch the stock suspension components im sure they could be had somewhat reasonable.
Upper radius rod mounting holes are about 2" wider on the Turbo-S frame (compared to other RZR XP1K, Turbo and RS-1). A custom upper radius rod will be required.
