Rs1 turbo project - Polaris RZR Forum - RZR Forums.net
RZR RS1 Discuss the Polaris RZR RS1 here!
 25Likes
post #1 of 28 Old January 28th, 2019, 11:12 PM Thread Starter
DBRs1's Avatar
Member #257810
View DBRs1's Photo Gallery(0)
Rs1 turbo project
Well the time has come for me to start my write up on building my own turbo kit for my rs1. This is one of the things I really wanted to do as well as I am also doing many other winter time upgrades that I have in another posting. I will start by saying that my objective with this turbo kit is low boost, bone stock engine, and reliability. I'm not trying to make 200whp here I'm just trying to put down a safe and reliable power equal to most stock or stage 1 tuned xpt models. So my target whp is in the 140 to 145 whp range. The kit will have a fan fed intercooler, external wastegate, recirculated bov, fabricated intake plenum, reloacated air intake setup, and the entire hot side including the mufflers will be ceramic coated.
Here is my parts list as of now and this may grow a little bit B4 it's all finished
Gtx2860r with billet wheel upgrade, kpa stainless full v band turbine housing, turbo xs rfl recirculating bov, turbo smart 38mm ultra gate, 5psi turbosmart wastegate spring, stock canam x3 intercooler, 9" spal pusher fan, Alba billet intake manifold, five 0 630cc injectors, multiple 2.5" stainless u bends of different radiuses, 2.5" stainless v band, modified stock header, 4" 2.5" turbo flex pipe, tial downpipe flange with v band, tial turbine inlet flange with v band, 2 MagnaFlow Mufflers, 8' of 1" .120 Dom tubing, 4' of 1/2" .120 Dom tubing, multiple silicone couplers ( 2 3" 45 degree, 2 2" 90 degree, 1 3" 90 degree, 2.5 to 2.5 hump style coupler, 2 2.25 to 2" couplers, 5" stainless exhaust pipe (used for intake plenum), 1/8 stainless plate steel 1ft x1ft, multiple tabs and universal brackets from allstar performance, innovate mtx wide band, innovate boost gauge, innovate oil temp / oil pressure combo gauge, custom remote mount oil filter setup with turbo oil feed line, 4' 3" stainless exhaust pipe, factory RZR uni filter, pre wrap for uni filter, -10 drain line, -10 billet drain flange, vibrant adjustable billet oil feed restrictor kit, and a dynojet cx for tuning
Now let me also say that so far everything will be bolt on and removable as well as nothing has had to be cut or modified on the chassis or plastics. All the factory storage areas and plastic covers are and will be intact. Here is the progress thus far. Should have some more updates in the coming weeks
ID:	569884   Click image for larger version
ID:	569886   Click image for larger version
ID:	569888   Click image for larger version
ID:	569890   Click image for larger version
ID:	569894   Click image for larger version
ID:	569896   Click image for larger version
ID:	569898   Click image for larger version
DBRs1 is offline
post #2 of 28 Old January 29th, 2019, 03:32 AM
Magnum1's Avatar
First Name: Chuck
My RZR: matching 2018 XPT's
Member #30101
View Magnum1's Photo Gallery(0)
Re: Rs1 turbo project
Looks great so far! I'm pretty excited to see how this works out. Great work so far and keep us posted.
fastbrit likes this.
Magnum1 is offline
post #3 of 28 Old January 29th, 2019, 04:32 AM
fastbrit's Avatar
Member #204345
View fastbrit's Photo Gallery(0)
fastbrit is offline
post #4 of 28 Old January 29th, 2019, 06:30 AM
Contact: 855-743-3427
SuperATV's Avatar
First Name: SuperATV
Member #7943
Sweeeet!! Can't wait to see it DBRs1!
SuperATV Official Website
SuperATV is offline
post #5 of 28 Old January 29th, 2019, 06:32 AM
rdsnake's Avatar
My RZR: 2016 XPT
Member #48735
View rdsnake's Photo Gallery(0)
Very cool. I'm really surprised no one has put a factory turbo engine in one of these yet.
rdsnake is offline
post #6 of 28 Old January 29th, 2019, 07:20 AM Thread Starter
DBRs1's Avatar
Member #257810
Well I actually have a friend that bought his 17 turbo back from the insurance company after he wrecked it. My original plan was to use his complete engine and turbo setup. But after I started looking at things the only thing I was going to be able to use was the long block itself. At that point I decided it wasn't worth it. My only concern at the moment is tuning and a turbo drain fitting location. It seems the injector scales in the ecu are a bitch to get dialed in. I decided to just have hmf racing do the Dyno tuning once I'm done.
Another thing that Im doing here since the factory air box has been deleted was I am building a setup that has a dual inlet for the belt case. One inlet will have a large belt blower for low speed situations but the nice part is it won't cause high belt temps when running fast due to the factory inlet will still b wide open. I may do a separate write up on that setup itself.
I'm very anxious to get this thing up and rolling. According to the compressor map this should make around 145whp on 4.5-5psi of boost. It seems people like boondocker also use almost the same turbo setup with the same results on xp1k rigs. I know on hmf's Dyno my RZR made 93hp and some change with a full hmf exhaust, dynojet cx and uni filter. If I can pick a full 40-50whp on 5 psi I will b pumped! My other goal here is 93 pump gas. I ride all east coast Tennessee, WV, Kentucky and I don't have time to deal with race gas. I had to do and still do race gas in my quads but I definitely don't want to deal with that in a rzr.
I will update this as I go. I'm about to fully burn everything in once I get my plenum and wastegate finished up then powder coat will have everything about 3 weeks. Doing all ceramic on header, full exhaust and plenum. Then tripple bronze in every else so it matches my machine.
DBRs1 is offline
post #7 of 28 Old January 30th, 2019, 08:03 AM
Magnum1's Avatar
First Name: Chuck
Member #30101
really excited to at least hear it run!!! Tuning it will be the worst of it for sure, and its too bad the complete XPT motor wouldn't just "bolt in" to the RS1 chassis.
Magnum1 is offline
post #8 of 28 Old January 30th, 2019, 08:44 AM Thread Starter
DBRs1's Avatar
Member #257810
Well technically it will bolt in and work with the transmission and chassis. As well as the throttle body and heat exchanger work as well. But I didn't think it was worth it to spend 3000 to 4k on a complete used engine just to use the long block. I can do forged pistons and Carrillo rods in this engine down the road if I want for under a grand in parts. Complete drop out xpt engine pull 3500 to 4k with the turbos and wire harness left on them. This 2860 turbo will support 300 to 325hp on high boost so it's more than I will ever need. This was the main reason I want with a larger turbo was so it will also support future down the road power if I want it. And I can't wait to hear this thing run myself. I'm really hoping it's quiet. I'm not a fan of super load rigs. Our groups sometimes are on the trail for 12+ hours in a day so keeping the noise down is a big one for me. As far as tuning I'm pretty sure I have that covered. Talked to a good friend of mine Hans that own hmf and he said not a problem on the tuning. The originally used my rs1 for rnd for Al the parts hmf sells. So they have already done a custom Dyno tune on it with the dynojet cx last year. And since the injectors I picked will max out at 180 crank hp it should make the tuning a tad more simple
Going to try to get things finish welded up by the weekend so everything can get dropped to powder coat. It's going to be painful to wait 3 weeks till I get everything back lol! But I still have a bunch to do other than this turbo kit and I'm sure I property won't be done with all of that in 3 weeks.
DBRs1 is offline
post #9 of 28 Old January 30th, 2019, 09:53 AM
Magnum1's Avatar
First Name: Chuck
Member #30101
that's awesome.
Magnum1 is offline
post #10 of 28 Old January 31st, 2019, 08:56 PM Thread Starter
DBRs1's Avatar
Member #257810
Made some more progress this evening. Got my I take setup, and wastegate all plumbed on. Also got all my muffler mounts and final muffler turn down done. All the big major fabrication parts are pretty much done. Now it's down to the fit and finish and small things. Once everything is set in stone get it all pulled off and fully welded in. Getting close but still a bunch to do. This process definitely makes you understand why the 3-5 grand for turbo kits. Lots and lots of time go into things like this!
ID:	570034   Click image for larger version
ID:	570036   Click image for larger version
ID:	570038   Click image for larger version
ID:	570040   Click image for larger version
True K30 likes this.
DBRs1 is offline
post #11 of 28 Old March 27th, 2019, 04:58 AM Thread Starter
DBRs1's Avatar
Member #257810
Well after 8 weeks of down time and waiting on things to come back from powder coating and cerakote I finally now have everything to assemble my turbo kit. This took me way way longer than I wanted and I have way more money than anticipated. But I think and hope it will all be worth it. Hope to have some assembly pics coming early next week. It's got a appointment with the Dyno for next Saturday so I gotta get cracking! Hers a couple pics if everything back. Went with black cerakote on all the hat side and tripple bronze and black in a semi gloss finish for everything else.
ID:	573942   Click image for larger version
ID:	573944   Click image for larger version
ID:	573946   Click image for larger version
SuperATV and True K30 like this.
DBRs1 is offline
post #12 of 28 Old March 27th, 2019, 07:03 AM
badbrad1700's Avatar
First Name: Brad
My RZR: XP 1000
Member #261286
View badbrad1700's Photo Gallery(0)
Very nice, I like it.
badbrad1700 is offline
post #13 of 28 Old March 27th, 2019, 11:43 AM
Tonylip1018's Avatar
Member #266592
View Tonylip1018's Photo Gallery(0)
Beautiful work!
Once you have the tune dialed what are your plans for suspension? That thing is going to fly keeping it on the ground will be a neat trick! I have been searching for ideas for improving the stock suspension. I'm under the impression it is inferior so you have got to be the guy with some real ideas since you will be needing it big time!
Tonylip1018 is offline
post #14 of 28 Old March 27th, 2019, 12:13 PM Thread Starter
DBRs1's Avatar
Member #257810
Well the rest of my rs1 is pretty well setup to say the least.
I'm running fox rc2.5 shocks all around with the gold treatment from shock therapy. Atv fourplay Koh upper and lower a arms, atv fourplay Koh trailing arms, atv fourplay radius rods, Keller 300m ball joints, front adjustable limit straps, rhino 2.0 axles, streamline big brake kits, 32" maxxis roxxzilla tires on 14" still beadlocks, 12% trans reduction, upgraded driveshaft and yokes, holz rear sway bar system and a pile of other crap. So this turbo kit was really my last piece of my puzzle.
BWXT likes this.
DBRs1 is offline
post #15 of 28 Old March 27th, 2019, 12:47 PM
Magnum1's Avatar
First Name: Chuck
Member #30101
I cant wait to see it rippin around! Hopefully it makes good power that's dependable and easy to manage. I'm still very shocked no one has a kit to market yet, or if anyone is even seriously working on one. I know several vendors are building their own, but nothing mass produced yet.
Magnum1 is offline
2011 XP900 AEROCHARGER Turbo build PT#1 Hooty222 Forced Induction 71 January 2nd, 2017 11:59 PM
Group Buy - BMP ECU Bully Dog Programmers - All RZR models - Turbo gain 31hp on 91 BigSilly450X RZR ECU Tuning 318 November 27th, 2016 07:26 PM
Can-Am Maverick X ds Turbo takes Doug Siddens Back to Pikes Peak awd4life Other Side by Side Vehicles 0 April 20th, 2015 09:29 AM
FOR SALE Clutch and Turbo STM adj weights kit allcool Polaris RZR Parts For Sale 8 March 30th, 2011 01:42 PM
