Clutch problems - Polaris RZR Forum - RZR Forums.net
RZR Pro-XP Discuss the Polaris RZR Pro-XP here!
 10Likes
post #1 of 16 Old October 3rd, 2019, 04:56 PM Thread Starter
jacksonjack's Avatar
Member #130473
View jacksonjack's Photo Gallery(0)
Clutch problems
Ok, Iíve seen a bunch of gossip about clutch problems in the pro. I think that itís over blown, that one guy posts up a clutch problem on different sites, then other guys start talking about all the clutch problems theyíve heard about.
If you yourself have had clutch problems or you know someone that you have actually seen their clutch problems postup. Please donít postup stuff you have seen on the internet. If you have had a problem say what it is, and what it took to get it fixed.
I've spent most of my money on women, guns, and Harleys. The rest I just wasted.
jacksonjack is offline
post #2 of 16 Old October 6th, 2019, 09:00 PM
Night Rdr's Avatar
First Name: Clayton
My RZR: S 1000
Member #124449
View Night Rdr's Photo Gallery(0)
Re: Clutch problems
Just took mine out for the first run, followed the two tank break in instruction. All was good, about 150 miles in on the second day the belt started slipping. At first I thought I was just spinning the wheels on gravel or hard pack, but after testing on pavement with full traction I get the same result. As soon as the boost builds it slips and instantly you smell a strong burning smell. I’m pretty upset with how expensive this unit was, dropped it off at the dealer today so we will see what they say.
Night Rdr is offline
post #3 of 16 Old October 7th, 2019, 07:57 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: Clutch problems
Not a PXP Owner ( yet... ).... but I follow a lot of media platforms about RZRs..... my current count is 6 different cases of clutch failure that Iíve seen.
Also at least 20 with the intake tube collapsing problem.
That being said, I have one friend with a new ultimate, heís at 300 miles, zero issues, and Iíve seen countless people posting with no issues as well... to me thatís normal Polaris.... thereís just some bad ones that come off the line.... gotta keep your fingers crossed when you buy one... but I still feel that at least 95% are no issue machines.
2018 XPT4 - Bailey
RWB713 is online now
post #4 of 16 Old October 7th, 2019, 08:07 AM
BajaP1's Avatar
Member #271362
View BajaP1's Photo Gallery(0)
Personally I believe it comes down to dealer prep. Bought my 2018 xpt4 from ivan stewart motorsports...zero issues
BajaP1 is offline
post #5 of 16 Old October 7th, 2019, 08:38 AM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
Re: Clutch problems
What? That makes no sense. It has nothing to do with dealers. Dealers don't prep the clutches. Dealers receive a rzr that is like 98% ready. They have to install the cage, check to make sure everything is properly torqued and properly lubed. Make sure your seat belts, lights, etc are working correctly. Not much beyond that. All they really are doing is a safety check.
When someone gets a rzr with issues it is because of quality control at the factory. A given part slipped through QC that shouldn't have. Just bad luck on the buyer's end that they are the one who happened to purchase the rzr with the given bad component. Absolutely nothing to do with what dealer you bought from.
Now where a good dealer does come in is when you do have an issue. They have a competent team who can fix it and fight Polaris on your behalf to resolve the issue in a quick and timely manner on Polaris's dime and not yours.
sand shark, RWB713 and stevo505 like this.
Dstew619 is online now
post #6 of 16 Old October 7th, 2019, 09:43 PM
White Lightning 19's Avatar
Member #271322
View White Lightning 19's Photo Gallery(0)
That's how it works... Now if we could just get more of those good dealers. There are too many of them out there that once you sign the check it's on to the next fish.
RWB713 likes this.
White Lightning 19 is offline
post #7 of 16 Old October 8th, 2019, 07:44 AM
95glide's Avatar
Member #261838
View 95glide's Photo Gallery(0)
Was at sxsblog race last weekend, aftermarket assassin's pro xp primary clutch exploded. Took out inner and outer cover and secondary as well. Wish I would have taken a picture.
95glide is offline
post #8 of 16 Old October 8th, 2019, 10:35 PM
Twistedsteel's Avatar
First Name: Brent
My RZR: 2020 Pro XP Ultimate White Lightning
Member #10088
View Twistedsteel's Photo Gallery(0)
Arizona Flag Re: Clutch problems
I have about 200 miles on mine now and haven't had any clutch problems. I have the AA stage II installed and like the power bump. Guess my real test will be when I drop it in the Glamis dunes on the 25th. I hope I didn't drink the Kool Aid and put too much faith in Polaris that they really addressed the clutch issues. They claim double the belt life.....
Twistedsteel is online now
post #9 of 16 Old October 10th, 2019, 03:54 AM
Mayorduck's Avatar
My RZR: 2020 xp pro ultimate. 2018 rzr 1000s. 2016 rzr 170
Member #273450
View Mayorduck's Photo Gallery(0)
Re: Clutch problems
Iíve got about 100 miles on mine with no clutch problems. I broke it in real easy for first 3 hrs. Only issue is airbox intake tube was collapsing under hard acceleration. Bent some wire into a spring and put it in intake tube where it comes around shock and solved the problem. Had called 2 different shops and they had not heard of that problem.
Mayorduck is offline
post #10 of 16 Old October 10th, 2019, 05:55 PM
ljheptig's Avatar
First Name: Larry
My RZR: 2015 XP1000 Voodoo Blue
Member #12879
View ljheptig's Photo Gallery(0)
Re: Clutch problems
Hey Brent, just curious, with 200 miles and no problems why have you already put in a aftermarket clutch? What is the power bump you mentioned?
ljheptig
ljheptig is online now
post #11 of 16 Old October 10th, 2019, 06:12 PM
RWB713's Avatar
First Name: Richard
Member #70552
Re: Clutch problems
Pretty sure heís referring to a stage II tune, & running the stock clutching
2018 XPT4 - Bailey
post #12 of 16 Old October 10th, 2019, 07:21 PM
ljheptig's Avatar
First Name: Larry
Member #12879
Re: Clutch problems
Duh! Got it, Thanks!
RWB713 likes this.
ljheptig
post #13 of 16 Old October 12th, 2019, 07:41 AM
First Name: Brent
Member #10088
Re: Clutch problems
Yes I'm running the stock clutch with the AA (Aftermarket Assassins) Stage II ECU flash 10-12 HP bump.
post #14 of 16 Old October 13th, 2019, 10:29 PM
Coleville's Avatar
My RZR: Pro XP Ultimate
Member #273780
View Coleville's Photo Gallery(0)
Re: Clutch problems
Thatís great news. I donít have to be limited to 84 mph (86 mph downhill). Fan comes on sooner too.
Coleville is offline
post #15 of 16 Old Yesterday, 07:24 PM
Wheels25's Avatar
Member #219194
View Wheels25's Photo Gallery(0)
Mine did this exact same thing I waited till about 80 miles before I got on it, not all the way to the floor it took of like a rocket in comparison to my 17xp1k. Then I waited for a while and the next day I figured the belt had probably had enough miles on it to start getting after it a little harder and it did the exact same thing the boost would start building and then it would slip and smell like thick burning rubber. Continued riding being more gentle later in the evening going from a dead stop gently accelerating to around 20 mph as to not roost the guys that were stopped next to me I laid in to the throttle again and when it got in to high boost it started to slip again followed by a loud slap/ break noise thought it was the belt. Gently applied throttle and it still accelerates but wasn't going to chance it any longer final belt episode was about 112miles. Got home pulled the clutch cover of for a quick inspection of the belt and belt still looks great no missing pieces and nothing laying in the clutch cover. Talked with my dealer and he told me to just monitor it for a while and see if it gets worse and he would reach out to Polaris when he opens tomorrow.
Wheels25 is offline
