AEM infinity help - Polaris RZR Forum - RZR Forums.net
RZR ECU Tuning Discussions related to tuning the Polaris RZR ECU, piggybacks, Powercommander, Fuel Maps, etc.
post #1 of 7 Old March 8th, 2017, 07:24 AM Thread Starter
Skinnypedalfab's Avatar
First Name: Jonathan
My RZR: 1000 turbo tube chassis
Member #186689
View Skinnypedalfab's Photo Gallery(0)
AEM infinity help
I have a 1000 with a OSP turbo kit. Started tunning last night and I'm having a issue with it pulling timing on the big end. I'm running e85, areomotive pump ID 2000 injectors, with the AEM infinity Ecu. Was wondering if there is any base maps out there? Or if anyone has had the same issue.
Skinnypedalfab is offline
post #2 of 7 Old March 27th, 2017, 12:08 PM
AllianceMMA's Avatar
First Name: Eric
My RZR: 2014 RZR 1000 XP4 2015 RZR XP1k
Member #65175
View AllianceMMA's Photo Gallery(6)
Re: AEM infinity help
follow Lance on Instagram and on his youtube channel he is currently working on my infinity AEM ecu , guy that did turbo couldnt tune or figure out ecu. So I took it to Lance he is a sandrail high performance tuner this is his first RZR that he is trouble shooting for me. on instagram page he goes over what changes they have done to fuel pump to run E85
https://www.instagram.com/dunehoon/?hl=en
https://www.youtube.com/dunehoon
AllianceMMA is offline
post #3 of 7 Old March 27th, 2017, 05:16 PM
TFR Engineering's Avatar
Member #141865
View TFR Engineering's Photo Gallery(0)
See post #52 here. https://www.rzrforums.net/forced-indu...blowout-4.html
Linger mentioned having a base map for a turbo XP that could be used as a starting point. I'm interested in how it is working out for you. I have the same system, but I haven't done anything with it, yet. I'm still up in the air if it is worth adding a turbo to the XP. It can end up being comparable cost wise to starting with a factory turbo if you end up doing internal modifications as well.
TFR Engineering is offline
post #4 of 7 Old March 29th, 2017, 09:29 AM
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
I get this call a lot and thought I would share what the usual problem is here so that others can benefit from it...
Some of the AEM infinity units being sold have an ignition retard based off of RPM setup in the base map. You need to go to do the following to check and correct:
Connect to Infinity unit and open tuner software
Select Wizards
Select setup Wizard
Select the down arrow on Advanced Setup
Select Main Rev limiter
Verify timing retard value and RPM that you want it to pull at...
I have attached a few photos to help. Hope this helps some of you and saves us all some time. LOL.
Nate
Alba Racing
ID:	405497   Click image for larger version
ID:	405505   Click image for larger version
[email protected]
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline
post #5 of 7 Old April 2nd, 2017, 07:22 PM
First Name: Eric
Member #65175
Thanks for the info Nate . I havent had a chance to check on progress of Tuning due to have been too busy finding a new bldg. I will hopefully go by and check on RZR this week. I know we got a basic tune from Matt Ling over at NSX designs. I have heard great things about the AEM from different people and others cant figure it out at all.. guy that build my motor gave up on tuning the AEM infinity. LOL
post #6 of 7 Old April 4th, 2017, 02:05 PM
AlbaNate's Avatar
Member #24131
LOL, I am assuming it was Mikey?
Nate
Alba Racing
[email protected]
LIKE ME AND ALBA!!!
AlbaNate is offline
post #7 of 7 Old April 5th, 2017, 05:49 PM
First Name: Eric
Member #65175
Yeah Mikey,
He has done engine stuff for me before on both of my machines. We talked about the AEM but I guess once he couldnt get it to save the base tune, he got super frustrated and just gave up.
AEM INFINITY gauge displays Riddler6.7 Forced Induction 7 February 21st, 2018 01:03 PM
AEM Infinity Standalone ECU and Harness Blowout!!!!!!!! linger Forced Induction 43 January 1st, 2018 09:02 AM
AEM Infinity XP1K with interactive dash2.0 XPRT General RZR Discussion 3 November 12th, 2016 03:59 PM
Private labeled AEM Infinity ECU & PNP Harness for sale!!!!!! linger RZR ECU Tuning 3 November 8th, 2016 01:02 PM
Private labeled AEM Infinity ECU & PNP Harness for sale!!!!!! linger RZR XP 1000 0 October 8th, 2016 07:38 PM
