900 XP Cam Installation Question - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old March 30th, 2017, 11:01 AM Thread Starter
Bush Pilot's Avatar
First Name: Les
My RZR: 2012 900 XP
Member #175017
View Bush Pilot's Photo Gallery(0)
In the service manual for the cam installation part, I don't believe it requires me to have the pistons in any particular location prior to cam installation and subsequent valve clearance check. During the valve clearance check the cams are rotated without the timing chain connected. I'm concerned that if the engine is an interference engine I could push the valves into the pistons when rotating the cams. Is my concern valid? Is the engine an interference engine?
Bush Pilot is offline
post #2 of 5 Old March 30th, 2017, 06:57 PM
Maniacdriver's Avatar
First Name: Rodney
My RZR: 11 XP 900
Member #28958
View Maniacdriver's Photo Gallery(0)
Re: 900 XP Cam Installation Question
Pull the plugs out and roll the pistons to a position where neither one is at TDC. Now you can roll the cams without any interference.
Maniacdriver is offline
post #3 of 5 Old March 31st, 2017, 06:48 AM Thread Starter
Bush Pilot's Avatar
First Name: Les
My RZR: 2012 900 XP
Member #175017
The timing mark on the flywheel only tells you when piston#1 is at TDC so I'm not sure I could tell where #2 is at. Maybe look thru the spark plug hole? Strange that the manual would be silent if this were an issue.
post #4 of 5 Old March 31st, 2017, 09:44 AM
muddnut2's Avatar
Member #71703
View muddnut2's Photo Gallery(0)
#2 will be opposite of Piston #1. My 2012 with 11.5:1 pistons does not hit the valves. Just put the head back on and timed it last night.
2012 XP 900 - UTV Inc. Nuke Cage, Doors, Fire Ext. & Mirrors, Crow Harnesses, 40" Totron Light Bar, Factory UTV Skidplate
muddnut2 is offline
post #5 of 5 Old March 31st, 2017, 09:45 AM Thread Starter
Bush Pilot's Avatar
First Name: Les
My RZR: 2012 900 XP
Member #175017
It's not an issue. If I install the cams with lobes in the position described in the manual I can the rotate the cams to proper position for measuring valve clearance without having to move the valves. Answered my own question. :-)
RT Pro - RZR XP 900 Replacement Arms - IN STOCK [email protected] RT PRO UTV 104 November 9th, 2016 06:15 AM
Stage 2 Alba 900 cams in a 1000? my375hp302 RZR 1000 Engine 9 June 13th, 2016 12:45 PM
900 Rear Fender on 2014 and Earlier Vettestir RZR-S Specific Discussion 1 January 18th, 2016 02:23 PM
Mechanical cam chain tensioner question Matt900S RZR S 900 3 January 13th, 2016 11:12 AM
Mechanical cam chain tensioner question Matt900S General RZR Discussion 0 January 12th, 2016 05:48 PM
