Snow plowing (Yup winters coming) - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Puddle
post #1 of 12 Old September 15th, 2019, 08:55 PM Thread Starter
Puddle's Avatar
First Name: Kris
My RZR: 900
Member #268022
View Puddle's Photo Gallery(0)
I have a Kubota BX22370 tractor with a blade and have used it the past two winters for plowing. I have about 1/4-1/2 mile of plowing. Now that I have a RZR, I am looking for feedback from those that plow with their RZR's, I'm trying to decide if I should stick with the tractor, or buy a blade for the RZR.
The tractor is stout, has a solid heavy duty blade, but no roof & slow going. I'm thinking I could cut the plow time in half with the RZR, but I don't know if the blades available are much more than snow shovel thickness. Also I don't know if the locked rear end will be troublesome in Ice & snow.
Any real world experience would be appreciated
Puddle is offline
post #2 of 12 Old September 16th, 2019, 08:53 AM
WB800BLASTER's Avatar
My RZR: 2016 XPT
Member #161889
View WB800BLASTER's Photo Gallery(0)
Re: Snow plowing (Yup winters coming)
stick with the BX, I have a BX 25 with a blade and snow blower. I added a cab and heater and led light bars. Nothing like cleaning up snow in a heated cab. Look around as i picked up the snow blower and cab for short money.
WB800BLASTER is offline
post #3 of 12 Old September 22nd, 2019, 07:50 AM
fishmagnet1's Avatar
My RZR: 900 EPS Trail
Member #215281
View fishmagnet1's Photo Gallery(0)
I have used the ATV for plowing for years in Eastern and Western Wa with great success. Haven't tried it yet with my UTV but I think it would be even better than my ATV.
Fastest way to do it. I also have had to plow over a 1/4 mile.
My neighbors used their tractors and after they saw me, every one switched to using their ATV or UTV.
No wrong answer, just a difference in time and or money and convenience.
fishmagnet1 is offline
post #4 of 12 Old September 23rd, 2019, 03:23 AM
andwes03's Avatar
First Name: Andy
My RZR: 2015 RXR 900 XC
Member #257568
View andwes03's Photo Gallery(0)
my 900 XC plows great, no complaints at all with it. The Denali plow I have is very thick and heavy duty so it should last a while. That being said, if i had a tractor to plow with i would stick with that. I found out the hard way you cant ride with the plow mount bolted to the machine unless you want to replace it. It didn't fair well at all to even one trail ride. The Polaris mount seems to be much more tucked in but overall I would stick with the tractor. Personal opinion
andwes03
andwes03 is offline
post #5 of 12 Old September 23rd, 2019, 03:40 AM
Loose Bolts's Avatar
Member #250882
View Loose Bolts's Photo Gallery(0)
I bought a rear mount snow blower (52Ē wide and over 24Ē tall) for my Kubota bx2360. Way too much snow in West Michigan for plowing with the rzr.
Loose Bolts is offline
post #6 of 12 Old September 25th, 2019, 07:59 PM
driver66's Avatar
Member #273358
View driver66's Photo Gallery(0)
This might be a little off topic because I don't have a tractor and I just got my first RZR, but I think I have some useful input that might help you decide. I plowed snow with 2 wheel drive small displacement ATV's for years but always on asphalt. I have a neighbor who has a bobcat and he used that to plow. We live in a residential neighborhood, so no 1/2 mile long driveways, but I plowed a lot of 60- 100 foot driveways and a little 48 inch plow usually worked fantastic. I could easily do 3 driveways to his one. My plow was nothing fancy, it was an old cycle country from the 90's and not made of any super thick steel. Just recently sold it, and while it didn't look great It always worked great. That being said I was so confident in my ATV plowing experiences that I immediately purchased a 66 plow kit for my 900,(which I haven't even mounted yet) and I have no doubt it will work and hold up well for our usually mild NJ winters. In your case if your on gravel or get regular amounts of heavy (12+) snow I don't thing a plow on the RZR is the way to go, I too would suggest staying with the much more solid set up a tractor will give you.
driver66 is offline
post #7 of 12 Old September 28th, 2019, 03:40 AM
Gene Bond's Avatar
First Name: Gene
Member #243386
View Gene Bond's Photo Gallery(0)
I plow with my little Yamaha Bruin on gravel. Even with the limited suspension travel it has, it's a pain to keep from plowing the gravel itself, or leaving snow. The suspension causes the plow to move up and down too much for my liking. On pavement, it wouldn't be a big deal, that's what the bottom buttons/feet are for. They don't work in gravel.
I couldn't imagine trying to plow with my RZR, having 2x or more suspension travel I know it can and is done, but I think a tractor w/o a suspension would be easier.
Gene Bond is offline
post #8 of 12 Old September 28th, 2019, 05:15 AM
Jasonv's Avatar
Member #154033
View Jasonv's Photo Gallery(1)
I have a John Deere 2030 that I used for years to clean my driveway and parking areas. My driveway is 100 yards long and gravel.
5 years ago I bought a blade for my Honda Forman and never looked back.
The only time I need the tractor is for big drifts or deep snow maybe once or twice a year.
The atv is so much more quicker and maneuverable. Does a better job than the tractor as well.
Jasonv is offline
post #9 of 12 Old September 28th, 2019, 06:53 AM
Gene Bond's Avatar
First Name: Gene
Member #243386
Maybe I should add...
My problem is the hills and dips in the drive and road at my place are the reason I have problems...
Since I haven't tried it with a tractor, maybe it's just the old, 'The grass is always greener on the other side of the fence'.
post #10 of 12 Old September 28th, 2019, 10:37 AM Thread Starter
Puddle's Avatar
First Name: Kris
My RZR: 900
Member #268022
Thank you all for the feed back. Probably not gonna spend the money on a blade & winch for the RZR and just keep using the tractor (at least this winter). On that note, it's snowing right now, we had a nice 4 days of Fall though.....
driver66 likes this.
Puddle is offline
post #11 of 12 Old September 28th, 2019, 10:11 PM
madsonp's Avatar
My RZR: 2017 XP 1000
Member #189721
View madsonp's Photo Gallery(0)
Here's mine, works great, fully enclosed my cab and have the Motoalliance heater. Built my own dual electric windshield wiper setup also.
madsonp is offline
post #12 of 12 Old September 29th, 2019, 07:25 AM
CP-06's Avatar
Member #141217
View CP-06's Photo Gallery(0)
I am starting my third season of plowing with my RZR Trail. I have about a 1/4mile of road to plow and it works just fine for the job.
CP-06 is offline
