EPS power steering Quit - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old August 2nd, 2019, 11:51 AM Thread Starter
budbon's Avatar
Member #85249
View budbon's Photo Gallery(0)
The power steering quit working this morning on my 2016 900 Trail. I checked the fuse and it is okay. Still get the dash light and no steering assist. Any ideas on where to check next? Other than the dealer.
budbon is offline
post #2 of 8 Old August 2nd, 2019, 12:07 PM
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
Re: EPS power steering Quit
Lift the negative battery terminal and then put it back on and see if the steering works.
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is offline
post #3 of 8 Old August 2nd, 2019, 12:57 PM Thread Starter
budbon's Avatar
Member #85249
I took the negative terminal off for 20 seconds. Did not help.
budbon is offline
post #4 of 8 Old August 18th, 2019, 09:21 AM
2dblo7's Avatar
My RZR: 2019 900 Trail
Member #269432
View 2dblo7's Photo Gallery(0)
Any luck figuring this out? My eps quit this weekend.
2dblo7 is offline
post #5 of 8 Old August 18th, 2019, 09:58 AM Thread Starter
budbon's Avatar
Member #85249
It turns out it was a loose ground wire where the ground connects to the frame. It should be noted, after a few starts, I could not even get power thru the ignition switch. On my RZR, the ground connection to the frame is located in front of the left rear wheel.
budbon is offline
post #6 of 8 Old August 18th, 2019, 02:24 PM
riderX's Avatar
First Name: Vince
My RZR: 2016 RZR 900 S
Member #174225
View riderX's Photo Gallery(0)
Thanks for letting us know the solution.
2016 RZR 900S EPS
riderX is offline
post #7 of 8 Old August 20th, 2019, 09:51 AM
flbluerunner's Avatar
My RZR: 2014 RZR XP 1000
Member #17226
View flbluerunner's Photo Gallery(0)
Weird, I also had my EPS light come on and power steering go out yesterday. I had raised the steering wheel slightly and since that was the only thing I could think of I moved the steering wheel back to it's old position and some how the power steering came back and the light went out.
Any thoughts??
flbluerunner is offline
post #8 of 8 Old August 20th, 2019, 04:41 PM
craigstumph
My RZR: RZR 1000
Member #59177
The steering units get hot and turn off. After they cool they come back on.
www.proutvparts.com
