BMP Stage 1 hitting rev limiter - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old March 31st, 2019, 04:44 PM Thread Starter
matthewpaler's Avatar
My RZR: 2018 RZR 900 EPS Trail
Member #241090
View matthewpaler's Photo Gallery(0)
She flies! at 71mph it hits the rev limiter, not that I really need more top end, but if I wanted more top end what do I do? Everything is stock besides the BMP Stage 1 tune.
matthewpaler is offline
post #2 of 8 Old April 13th, 2019, 03:55 PM
chevihemi's Avatar
Member #200993
View chevihemi's Photo Gallery(0)
Re: BMP Stage 1 hitting rev limiter
I have bmp stage 3 on mine but hit the limiter about the same time. If I back off and slowly get into it again I can get up to over 80 before I puss out and let off again. Stock primary and team tied secondary. Give that a shot perhaps.
chevihemi is offline
post #3 of 8 Old April 15th, 2019, 06:12 AM
squirly's Avatar
My RZR: '11 red XP
Member #21991
View squirly's Photo Gallery(0)
You need a clutch kit to compliment your tune, if you had adjustable arms right now you need more tip weight!
'19 trail
squirly is offline
post #4 of 8 Old April 15th, 2019, 06:43 AM
RickRou56's Avatar
My RZR: 2017 XPT Velocity Blue
Member #28887
View RickRou56's Photo Gallery(0)
Yes like stated. More tip weight.
Wasting power to the ground without the clutch kit.
RickRou56 is offline
post #5 of 8 Old April 15th, 2019, 09:07 AM
Joey Strub Bmp's Avatar
First Name: Joey
My RZR: All models
Member #208601
View Joey Strub Bmp's Photo Gallery(0)
Great that means you are making power!
Yes I agree with the above at the bare minimum adjustable primary weight set up. Ideally you would get the full front and rear set to get all the added power to the ground - find that and all of our Clutch kits here!
Name:	rzr headquarters.jpg
I welcome any comments or questions regarding Bikeman Performance Products. I am the guy behind the scenes at Bikeman that can answer just about any question you have. Please contact our sales department if you are looking to buy products. I am not online as much as I would like to be but I will try to be when I have time. You can also email me for support.
[email protected]
Joey Strub Bmp is offline
post #6 of 8 Old May 6th, 2019, 04:41 PM Thread Starter
Member #241090
Well it appears my issue was more tires than anything. I had 25x8 and 25x10 tires on from my RZR 800. Today I received my 27x9 all the way around Tusk Terrabite's on Tusk 12" rims. Hitting the REV limiter is gone and GPS registered 72mph, a 4mph gain over the 25" tires I had on there!
post #7 of 8 Old May 6th, 2019, 05:05 PM
squirly's Avatar
My RZR: '11 red XP
Member #21991
You'll still get more with a clutch kit!
'19 trail
squirly is offline
post #8 of 8 Old May 7th, 2019, 04:58 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
As a general rule clutch kits do not change top speed, as long as the clutch is able to close up and that normally happens anywhere between 45-60 depending on vehicle then changes in weight of weight does not affect top speed.
If you put heavier weights in and gained speed then your clutch was not closing up all the way before and it was wrong before.
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
2018 XPT with BMP stage 2 ..is stage 3 worth it?? Max H RZR XP Turbo 7 July 14th, 2018 09:08 AM
Hitting rev limiter right after going WOT- new owner needing help MadMike900 RZR XP 900 9 August 26th, 2015 10:57 AM
hitting the rev limiter under hard acceleration craigb44 RZR XP 900 65 February 26th, 2014 07:45 AM
Hitting REV Limiter at 50-52 MPH Polaris 900 RZR XP 900 14 June 23rd, 2011 03:50 PM
hitting rev limiter bhamilton1 General RZR Discussion 2 January 29th, 2011 04:56 AM
