Lift Kit from EPI? - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Gene Bond
post #1 of 13 Old March 28th, 2018, 04:49 AM Thread Starter
JusticeRZR's Avatar
First Name: Miles
My RZR: 2017 900 EPS TRAIL BLUE FIRE/2016 570 EPS TRAIL SUNSET RED - SOLD
Member #130849
View JusticeRZR's Photo Gallery(0)
Question Lift Kit from EPI?
Looking at this lift kit from EPI since it appears to be all brackets and no shock spacers or drilling required - EPILK195 https://epiperformance.com/lift-kit-epilk195/
Anyone have any experience with this kit? I saw someone had recommended their wheel spacers as high quality and made in the USA, so while checking on those, I happened upon the lift too.
JusticeRZR is offline
post #2 of 13 Old April 16th, 2018, 07:12 PM Thread Starter
JusticeRZR's Avatar
First Name: Miles
Member #130849
Bump
2017 RZR 900 Trail EPS
Polaris L&R Sport Roof;Polaris Deluxe Front & Rear Bumpers;Polaris L&R 1/2 Windshield;Polaris Door Lowers;Polaris 3500# Winch;Synthetic Winch Rope;Polaris S Fenders;Tusk Seat Bag;Bad Dawg Rear-view Mirror;Pro Armor 2" 4-point harnesses;Rear cup holder drill for middle prop shaft zerk access;RockSteady Bluetooth Speaker & Mount;STI HD7 14 x 7 Rims - Blue & Black;Tusk Warthogs 29 x 9 x 14 on all four corners; Tusk Quiet Glide 3/8" Skid; Perfex 2" Lift
post #3 of 13 Old April 19th, 2018, 06:21 PM
Gene Bond's Avatar
First Name: Gene
My RZR: 900 EPS Trail
Member #243386
View Gene Bond's Photo Gallery(0)
Re: Lift Kit from EPI?
It looks almost exactly like this one: https://www.ebay.com/itm/PERFEX-LK-1...72.m2749.l2649
I installed mine last weekend, along with 1.5" wheel spacers, and it's a whole new ride!
I'm very pleased with the quality of the materials and the fit of the kit.
Gene Bond is offline
post #4 of 13 Old April 19th, 2018, 06:24 PM Thread Starter
JusticeRZR's Avatar
First Name: Miles
Member #130849
Thanks Gene!
post #5 of 13 Old April 20th, 2018, 08:43 AM Thread Starter
JusticeRZR's Avatar
First Name: Miles
Member #130849
Hey Gene, I just installed 14" wheels with a 4+3 offset, so it moved the tires out a big. Do you think that would be enough offset with the lift or might I need to add spacers too?
post #6 of 13 Old April 20th, 2018, 08:59 AM
ParaQuader's Avatar
My RZR: '16 900 Trail EPS StealthBlack
Member #47120
View ParaQuader's Photo Gallery(0)
Gene,
Is that Perfex the one you got?
$119. US ?
Polaris lock & ride windshield, Polaris canvas roof, SuperATV rear window, Seizmik Pursuit side mirrors,
Viper Elite 3500 winch, Denali 66" Pro Series plow, UTV Giant lower doors, ATV-Guru front brush guard,
14x7 STI HD Beadlocks 4+3 / Tusk Terrabite 28x10Rx14, MudBusters fender flares, RT Pro springs,
Modified Grafix, LED Headlight bulbs, Sirius LED cube floods on A-pillar
ParaQuader is offline
post #7 of 13 Old April 24th, 2018, 07:04 PM
Gene Bond's Avatar
First Name: Gene
Member #243386
Yep, the Perfex.
Since the stock wheels are 5.5/1.5, and I used 1.5" spacers, the 4/3 should be the same...
JusticeRZR likes this.
post #8 of 13 Old April 25th, 2018, 07:48 AM Thread Starter
JusticeRZR's Avatar
First Name: Miles
Member #130849
Yep, the Perfex.
Thank for the info Gene! Taking her out this weekend to see if the increased wheel size gained me the extra ground clearance I need, or if a lift will be necessary. If it is, I am definitely gong with the Perfex - saves a bit of $ for another farckle.
post #9 of 13 Old April 25th, 2018, 11:47 AM
vtprairie's Avatar
Member #70416
View vtprairie's Photo Gallery(0)
Thats a dang good price how you like it so far
2016 RZR 900 Trail EPS
2017 RZR 1000S
vtprairie is offline
post #10 of 13 Old May 13th, 2018, 03:40 PM Thread Starter
JusticeRZR's Avatar
First Name: Miles
Member #130849
Well, I just ordered this lift kit. Took the buggy out on the trails today for the first time with the bigger wheels and tires and holy cow did I have front rub! Not only when doing hard/full lock turns but also when hitting bumps and the suspension compressed. It hurt my soul each time it rubbed, so I ordered the lift as soon as we got back home. Since the Hatfield McCoy trip is in 4 days, planning to put the stock wheels back on in order to enjoy the trails without worrying about rubbing.
post #11 of 13 Old May 13th, 2018, 04:06 PM
Gene Bond's Avatar
First Name: Gene
Member #243386
I really like the new feel. By adding the lift, I was able to back the preload all the way down and still have enough ground clearance for most anything. I'm running 27" tires, 9" all the way around. I didn't have any rubbing before, but I definately needed more clearance to even match my mid-size Ranger, So I wen t up to the next to the top preload. The ride was rough. Much better now.
I get plenty of lean on a fast corner, but not what I consider excessive. I haven't measured the outside width with the spacers and new wheels, but I'm just inside the Nerf Bars. I got the '17 Trail since the '18 and none of the other versions had it. I have Turf Mode on my Ranger, and not on my Sportsman. I know I like it. I also know not to drive stupid in Turf Mode (duh). It's funny how often the guys with the 'junk' equipment are also the ones who use the most fuel on the same ride
post #12 of 13 Old June 16th, 2018, 10:09 AM Thread Starter
JusticeRZR's Avatar
First Name: Miles
Member #130849
I cannot seem to get the back front mounting plate vertical enough to attach to the front. Anyone have a suggestion on fit? I ordered the same kit Gene linked to and it specifically stated it is for the 900 Trail, but I might need to contact the seller anyway. As you can see, the front bracket slid in perfectly. But the back is at an angle blocked by the frame bars.
post #13 of 13 Old June 16th, 2018, 10:32 AM Thread Starter
JusticeRZR's Avatar
First Name: Miles
Member #130849
Cancel that. After playing around with he bracket for a bit, I figured it out.
570 Perfex lift kit install video Cummins Driver RZR 570 Specific Discussion 14 May 1st, 2019 05:50 AM
RT Pro - RZR 900 Trail / XC 2" Lift Kit is IN STOCK! RT PRO RT PRO UTV 66 August 23rd, 2017 05:32 AM
Racer Tech - RZR XP 1000 2-5" Lift Kit RT PRO RT PRO UTV 69 May 26th, 2016 01:58 PM
EPI sand clutch kit SWDoodle RZR 4 Specific Discussion 4 January 19th, 2016 06:54 PM
