Under seat storage container? - Polaris RZR Forum - RZR Forums.net
post #1 of 16 Old February 29th, 2016, 04:32 PM Thread Starter
300winmag's Avatar
My RZR: 2015 XC
Member #83248
View 300winmag's Photo Gallery(0)
I have a 2015 XC and under the driver seat is the battery, fuse box and storage area. My 22lb tool set which includes sockets, ratchets and a tow strap fit in it perfectly however there are holes all over the place to let water drain out(and in). I've looked at every container in my house and then went to a couple dollar stores looking at Rubbermaid containers but nothing comes close to a good tight fit. I am thinking of putting down 2 sheets of thick vapor barrier plastic with a towel inside then put my tools in and curl the top up like you would a dry bag.
I could put it all in the cargo box but I'm carrying a lot back there and 22lbs nice and low will help as a counter weight. Going to be a pain in the a$$ to get to the bottom for specific sockets and all together not very functional so what are you guys using? Is the 900 Trail designed the same way under the seat?
You all probably just put something that water won't damage under there and think i'm crazy but.... yes I am LoL
300winmag is offline
post #2 of 16 Old February 29th, 2016, 06:44 PM
"Oath Keeper"
The Texan's Avatar
First Name: Bob
My RZR: 2017 Rzr 900-4 ..... 2016 Rzr 900 Trail (sold) ..... 2013 Rzr 570 (sold) .... 2010 Rzr 800 (sold)
Member #16224
Location: Summer - Cascade, Idaho ...... Winter - Wellton, Arizona .. Home is Toquerville, UT all year long
View The Texan's Photo Gallery(0)
Re: Under seat storage container?
Actually, that is a battery box for a second battery, or so I have been told.
Bob & Betsy - USN Ret'd '78 & LEO Ret'd '03 & "Oath Keeper till I die"
'11 Chevrolet Silverado LT, Ex Cab, 6.2L NHT Max tow, with '17 Rzr 900-4 in the enclosed C&B Big 10 trailer behind.
Where the wheels are stopped
The Texan is offline
post #3 of 16 Old February 29th, 2016, 09:45 PM Thread Starter
300winmag's Avatar
My RZR: 2015 XC
Member #83248
Possibly but I doubt it, The XC already has a car battery in it LoL, the "storage area" is only 5x7 and there is no supports to keep an extra battery from flying around like the original battery has. Maybe they mention it in the manual, I will have a look.
EDIT: I stand corrected! In this video they install a little battery in the compartment with custom mounting hardware.
http://https://www.youtube.com/watch?v=n5ahHtd5XOk
post #4 of 16 Old March 1st, 2016, 07:37 AM
pwgsx's Avatar
My RZR: 2015 RZR 900 XC
Member #69977
View pwgsx's Photo Gallery(0)
I have a 2015 XC and that spot is for a second battery. However you can do whatever you want with that area. In my opinion that area is too low and will get wet A LOT. I have a storage box in the back and some tools in the glove box. They do make a storage box/bracket for under the hood. You might want to look into that instead.
pwgsx is offline
post #5 of 16 Old March 1st, 2016, 10:25 AM Thread Starter
300winmag's Avatar
My RZR: 2015 XC
Member #83248
Never seen or heard of the under the hood storage before but sounds like a hell of an idea. Thanks for the tip!
post #6 of 16 Old March 1st, 2016, 10:54 AM
pwgsx's Avatar
Member #69977
pwgsx is offline
post #7 of 16 Old September 10th, 2016, 08:41 AM
polaris bear's Avatar
First Name: Craig
My RZR: Not Yet
Member #26773
View polaris bear's Photo Gallery(0)
I have the under hood storage container on my 900 trail and that is where I keep my tools and winching accessories. I have the tools in storage bags meant for Polaris Sportsman XP under front rack storage. You could use just about any type of waterproof bag to store the tools. I like have the tools and winch stuff under the hood as it is easy to get too unlike having to remove the seat to get to the space under the drivers seat.
2016 900 EPS Trail. 2012 Sportsman 550 EPS. 2006 Hawkeye 300 4x4. 2005 Eton Viper 90. 2012 Ford F350 crew cab 6.7 Power Stroke 4x4. 2014 Arctic Fox 29.5 5th wheel with Idaho Tote to haul machines.
polaris bear is offline
post #8 of 16 Old September 11th, 2016, 06:29 AM
Jasonv's Avatar
Member #154033
View Jasonv's Photo Gallery(1)
I use the under seat bin for tools.
I put the tools in a gallon ziplock. Have some rags in a gallon ziplock also and the are stuffed around the tools to keep them from rattling around.
I also don't mind if the tools get wet.
Jasonv is offline
post #9 of 16 Old June 24th, 2019, 09:07 PM
GPS GURU
702youngbergs's Avatar
My RZR: 2019 XP1000 RC
Member #269632
View 702youngbergs's Photo Gallery(0)
I have this same question for my Xp1k4, I was thinking of using a heat gun to mold a pretzel container into shape for a waterproof seal and a wide screw on lid https://images-na.ssl-images-amazon....18iQ2C-vvL.jpg
702youngbergs is offline
post #10 of 16 Old June 26th, 2019, 04:52 AM
Gene Bond's Avatar
First Name: Gene
My RZR: 900 EPS Trail
Member #243386
View Gene Bond's Photo Gallery(0)
Neither link worked for me, try this: https://www.rockymountainatvmc.com/p...hood-storage-p
Gene Bond is offline
post #11 of 16 Old June 26th, 2019, 04:55 AM
Gene Bond's Avatar
First Name: Gene
Member #243386
Unfortunately, I have the Polaris L&R glass windshield and wiper. The washer tank is in that area, so the under-hood storage won't fit.
I stored some tools in the under-seat (2nd battery?) area 1 time, and after having to wash all the mud off my tools, I moved them to the glove box
I like the pretzel jar solution! I think I have one of those in my junk pile for just such a reason... I may try it!
post #12 of 16 Old June 26th, 2019, 12:22 PM
GPS GURU
Member #269632
Just been checking misc containers around the house, and found that the 64oz mayo jars fit in that space with just a little play as well. They offer a wide mouth and enough room for wrenches, tire kits. air gauges, and whatever else you may need. Just stuff it with rags to keep the noise at bay and fill the void in the space remaining with a price of foam.
post #13 of 16 Old June 26th, 2019, 03:21 PM
GPS GURU
Member #269632
Well. With the help of a food saver, I got a full 3/8 set of metric sockets, wrenches, multi bit screwdriver, tire kit with plugs, air gauge, pliers, Allen wrenches, crescent wrench and a rag stuffed inside the mayo jar. With a tiny bit of room to spare for something down the line. Hope that helps someone keep their tools dry and safe !
post #14 of 16 Old August 3rd, 2019, 06:29 PM
mstef66's Avatar
Member #124241
View mstef66's Photo Gallery(0)
I use the small area under the seat to put my empty crushed water bottles. Makes a good trash can. Just empty it out when I get back.
I find it gets too much water in there from water crossings.
Mike
mstef66 is offline
post #15 of 16 Old August 4th, 2019, 05:50 AM
Jasonv's Avatar
Member #154033
Canít you move the windshield washer tank?
I relocated my battery to that area to make room for the extra gas tank so had to relocate the coolant overflow tank. There was still room for the Underwood storage tray.
Jasonv is offline
Twisted Stitch & PRP Seats In Stock ! UTV Inc. UTV Inc 33 August 8th, 2017 11:35 AM
Seat storage box Bagger2011 RZR XP 4 1000 8 February 7th, 2016 02:49 PM
