whizzing noise in high gear - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old October 5th, 2019, 05:31 PM Thread Starter
bgulsvig's Avatar
Member #273264
View bgulsvig's Photo Gallery(0)
2008 RZR 800 with 1000 miles makes a whizzing noise when in high gear at around 4000 rpm took secondary clutch apart everything looked correct drained trans fluid looked correct no metal filings I've been told this is common with this model year also tried to change transfer case fluid but drain plug needs a special tool? looks difficult.....have a video but this site won't let me upload
bgulsvig is offline
post #2 of 4 Old October 5th, 2019, 07:24 PM
rijoh2000's Avatar
First Name: Rick
My RZR: 2014 Rzr 4 800
Member #79919
View rijoh2000's Photo Gallery(0)
Re: whizzing noise in high gear
Could be a vibration resonating something loose like a heat shield etc. Another alternative is that it could be belt whine. https://www.rzrforums.net/rzr-800-sp...t-whine-2.html
rijoh2000 is offline
post #3 of 4 Old October 21st, 2019, 11:01 AM
New B with a stock RZR
Double B's Avatar
My RZR: 2011 Polaris 800 EFI
Member #266860
View Double B's Photo Gallery(0)
Had a similar problem. The transfer case was dry on mine and the prop shaft u-joints where dry and deteriorated. Changed the transfer fluid (no special tools required) and installed grease-able u-joints and the noise went away.
Hope this helps.
Double B
Canadian Suburb or Detroit
2011 RZR 800 EFI
2004-1/2 Sportsman 400
2002 Sportsman 700
2001 Sportsman 400
Double B is offline
post #4 of 4 Old October 27th, 2019, 11:27 AM Thread Starter
bgulsvig's Avatar
Member #273264
I checked the transfer case and mine was dry as well. It took the full 14 ounces. How is that possible? What happened to the fluid????
bgulsvig is offline
