Just purchase rzr 800 3500 miles help - Polaris RZR Forum - RZR Forums.net
 1Likes
post #1 of 19 Old September 20th, 2019, 02:18 AM Thread Starter
Rochealbert's Avatar
Member #273152
View Rochealbert's Photo Gallery(0)
Hey guys just purchased rzr 800 3500 miles . She is a 2014 le model. She has 26 inch tires I don't like how low the machine is. Wondering it's ok to put a 2 inch lift in and bigger tires.what are your suggestions.
Rochealbert is offline
post #2 of 19 Old September 20th, 2019, 06:06 AM
nibroc's Avatar
First Name: Charlie
My RZR: 2012 570
Member #228657
View nibroc's Photo Gallery(0)
Re: Just purchase rzr 800 3500 miles help
......go for it----you will like it....
nibroc is offline
post #3 of 19 Old September 20th, 2019, 09:43 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Replacing stock (sagging) springs will give you more clearance than a 2" lift kit will.
I did both.
2014 800 LE w/EPS 50
CA 800 is offline
post #4 of 19 Old September 20th, 2019, 10:24 AM
Mick6R's Avatar
My RZR: '14 800-S
Member #62825
View Mick6R's Photo Gallery(0)
Did 2" lift, as well as spring kit. Spring kit is still best mod to date. Rides so much better.
Still have the factory 26" Big Horns, although I've had my eyes on a new set of wheels with 28" tires for a new look and little more ground clearance.
You should never underestimate the predictability of stupidity.
Mick6R is offline
post #5 of 19 Old September 20th, 2019, 11:15 AM Thread Starter
Member #273152
[Q
How much is spring kit where can I get it? Is it hard to install?
UOTE=Mick6R;5942454]Did 2" lift, as well as spring kit. Spring kit is still best mod to date. Rides so much better.
Still have the factory 26" Big Horns, although I've had my eyes on a new set of wheels with 28" tires for a new look and little more ground clearance.[/QUOTE]
post #6 of 19 Old September 20th, 2019, 11:28 AM
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
Welcome!
https://rtproutv.com/shop-by-model/rzr-800.html
link to installation instruction pdf is in description.
Just one spring option. multiple spring suppliers along with opinions are here on the forum.
ntrsandman is online now
post #7 of 19 Old September 20th, 2019, 11:38 AM Thread Starter
Member #273152
I've seen cheap ones for like 50 bucks on ebay those any good? Are the spring kitsch expensive?
post #8 of 19 Old September 20th, 2019, 11:50 AM
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
Google RZR 800 springs. Results will return you to lots of info including here on the RZR forum. check out the link I left in my previous post.
As for Ebay springs, you get what you pay for.
PhilCod likes this.
post #9 of 19 Old September 20th, 2019, 01:10 PM
Mick6R's Avatar
My RZR: '14 800-S
Member #62825
I have the RTPro lift and dual rate spring kit on mine. I forget what I paid 3 yrs back. Looks like springs are $465 now. Spring kit was not difficult to install. Lift kit was a little more work, as holes had to be drilled in rear frame for mounting.
Mick6R is offline
post #10 of 19 Old September 23rd, 2019, 04:01 PM Thread Starter
Member #273152
Does the holes always have to be drilled for lift kit? Can u just get spacers? And how do I know what weight to get springs?
post #11 of 19 Old September 23rd, 2019, 04:08 PM Thread Starter
Member #273152
Also the highest point of clearance is about 10 or 11 inches what's that's like compared to stock ?
post #12 of 19 Old September 23rd, 2019, 04:22 PM Thread Starter
Member #273152
Anyone understand why the high lifter spring don't work on 2015, also I have adjustment on shock can I just that instead of new springs?
Name:	Screenshot_20190923-205046_Samsung Internet_1569280913358.jpg
post #13 of 19 Old September 23rd, 2019, 04:51 PM Thread Starter
Member #273152
I just tighten up adjustment on shocks bike raised up a nice little bit , looks alot better . Will be a rough ride now ?
post #14 of 19 Old September 24th, 2019, 06:07 AM
Mick6R's Avatar
My RZR: '14 800-S
Member #62825
The way I read the mounting instructions, certain frames needed holes drilled and certain other frames did not. Luck of the draw, mine needed drilling.
Mick6R is offline
post #15 of 19 Old September 24th, 2019, 06:10 AM
Mick6R's Avatar
My RZR: '14 800-S
Member #62825
That'll get ya some height, but it's gonna beat your kidneys to death down a rough stretch of trail.
Spring kit will get some height, as well as better ride. At least that's my experience. I'll back it out of garage after work and take a pic and measure ground clearance for you.
Link to springs. Come in two different rates. I got the medium.
https://rtproutv.com/shop-by-model/r...t-springs.html
Mick6R is offline
