rzr won't start - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 18 Old September 12th, 2019, 02:55 PM Thread Starter
rzrlyfe's Avatar
Member #267928
View rzrlyfe's Photo Gallery(0)
rzr won't start
I had to put a new set of batteries in my 2012 rzr 800. it started right up, all connections are tight, but when I turned it off, that was it. now it won't even turn on when I turn the key, no noise, no lights, nothing. I double checked the batteries and they are fully charged. I don't know where to even start to look for the problem.
rzrlyfe is offline
post #2 of 18 Old September 12th, 2019, 04:09 PM
slant911's Avatar
My RZR: 2019 XP Turbo
Member #269992
View slant911's Photo Gallery(0)
Re: rzr won't start
fuses?
slant911 is offline
post #3 of 18 Old September 12th, 2019, 04:27 PM Thread Starter
rzrlyfe's Avatar
Member #267928
Re: rzr won't start
Fuses and relays are all good.
rzrlyfe is offline
post #4 of 18 Old September 12th, 2019, 04:35 PM
Larryg82's Avatar
First Name: Larry
My RZR: 2018 Turbo S
Member #80871
View Larryg82's Photo Gallery(0)
Re: rzr won't start
Check the ignition switch, had one come apart (in the back) on my 2015 XP1000. Was able to reach up behind dash and push in on it and got power. Small plastic clip on switch had broken off.
Larryg82 is offline
post #5 of 18 Old September 12th, 2019, 04:49 PM Thread Starter
rzrlyfe's Avatar
Member #267928
Re: rzr won't start
I checked the ignition switch, and everything seems to be good. it ran fine, everything worked for all of 3 minutes after I replaced the batteries, now nothing.
rzrlyfe is offline
post #6 of 18 Old September 12th, 2019, 04:58 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: rzr won't start
You say batteries....are you running two batteries with an isolater? Or what kind of setup do you have for the batteries?
I would suspect battery cables or the ground at the battery, or something came unplugged inadvertently during the switch...
RZR_Scott likes this.
2018 XPT4 - Bailey
RWB713 is online now
post #7 of 18 Old September 12th, 2019, 05:37 PM Thread Starter
rzrlyfe's Avatar
Member #267928
Re: rzr won't start
here is a picture of my gauges with the key on, my amp switch, which is the only thing getting any kind of power, and my battery set up. everything is hooked back up the way it was on the old batteries, all connections are tight. just no power. I even tested the batteries and they are fully charged as well.
ID:	584058   Click image for larger version
ID:	584060   Click image for larger version
rzrlyfe is offline
post #8 of 18 Old September 12th, 2019, 08:01 PM
orange crate's Avatar
My RZR: 2011 RZR S Orange Madness Le
Member #16416
View orange crate's Photo Gallery(0)
Re: rzr won't start
When you press the brake to start, there is a switch which goes bad. I donít know if this keeps it from cranking, but it being bad will keep it from starting. Good luck.
orange crate is offline
post #9 of 18 Old September 12th, 2019, 08:09 PM Thread Starter
rzrlyfe's Avatar
Member #267928
Re: rzr won't start
Where is the switch and how do I check it? will It keep power from getting to the gage panel/ignitionswitch?
rzrlyfe is offline
post #10 of 18 Old September 12th, 2019, 08:25 PM
Member #16416
Re: rzr won't start
YouTube. rzr 570 or 800 wonít start brake sensor
post #11 of 18 Old September 12th, 2019, 09:53 PM
wadewoot's Avatar
First Name: wade
My RZR: 2016 rzr s1000
Member #75338
View wadewoot's Photo Gallery(0)
Re: rzr won't start
The gauge would still come on if it was the switch. Try pulling the fuse I think itís also for headlights and inspect it well or even replace it. I had the same thing happen and the fuse had a hard to see crack. I hope this helps sorry if it doesnít
wadewoot is offline
post #12 of 18 Old September 13th, 2019, 06:41 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Re: rzr won't start
Did you check fuses under drivers seat?
Also check ring terminal (with a bunch of wires) on starter solenoid that supplies power to all the circuits on RZR. They have been known break off.
2014 800 LE w/EPS 50Ē
PRO ARMOR trail doors, RYFAB rear windshield, MotoAlliance Fire Storm cab heater, RYFAB cargo rack, WARN PV4500S wide spool winch, POLARIS front windshield and top, 2008 tail lamp assemblies with backup lights, RACERTECH 2Ē lift, Duraclutch, R2C Air Filter, Garage Products A-arm bushings.
CA 800 is offline
post #13 of 18 Old September 13th, 2019, 09:05 AM Thread Starter
rzrlyfe's Avatar
Member #267928
Re: rzr won't start
Attachment 584102
I don't have a ring terminal with a bunch of wires to it, and have never had. I did try starting it at the solenoid, and still nothing. I checked the fuses under the dash in the firewall, is there another set of fuses under the seat that im not seeing?
rzrlyfe is offline
post #14 of 18 Old September 13th, 2019, 09:11 AM
RWB713's Avatar
First Name: Richard
Member #70552
rzr won't start
Attachment 584102
If you jumped the main terminals at the solenoid and the starter didnít engage... you have a battery cable connection, or battery, problem.
Iíve also never dealt with a 2012 800... but that small two battery setup doesnít look like a factory Polaris setup at all, Everything in there would be the biggest problem suspect to me
2018 XPT4 - Bailey
post #15 of 18 Old September 13th, 2019, 09:51 AM
Sliverflipper's Avatar
Member #48338
View Sliverflipper's Photo Gallery(0)
Check your main ground wire. My brother had the same problem and about tore his machine apart trying to figure it out.
Sliverflipper is offline
Tags
rzr 800s
