Stock seat torture - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 1 Post By flagboy
  • 1 Post By dajo
  • 1 Post By Clothier
post #1 of 11 Old August 25th, 2019, 12:27 PM Thread Starter
flagboy's Avatar
Member #271778
View flagboy's Photo Gallery(0)
Stock seat torture
I had my new-to-me 800 on a couple of 50 mile rides. The second one was over some tougher terrain and the stock seat was less than comfortable. The middle of the back part has a distinct bulge that rubs on my lower back.
I'm considering a few ways to address this situation:
1. After-market seat
2. Have my local upholstery guy reshape the seat back
3. Add some type of cushion or pad on the stock seat
I was wondering what others have done to address the situation. I'm hesitant about the after-market seat since it will be a shot in the dark whether it will be significantly better. Something I won't be able to determine without seat time.
Any thoughts? Suggestions?
flagboy is offline
post #2 of 11 Old August 25th, 2019, 01:48 PM
TeeMPee's Avatar
First Name: Todd
My RZR: 900 xc
Member #265800
View TeeMPee's Photo Gallery(0)
Re: Stock seat torture
I am in the same situation, sat in a guys Beard seat and was nice but so many choices and so many prices! will be following.
TeeMPee is offline
post #3 of 11 Old August 25th, 2019, 02:49 PM
dajo's Avatar
First Name: Dave
Member #19884
View dajo's Photo Gallery(0)
I installed late model seats in my 2010 and 2011. They are much better than the old stock seats. Takes a little adapting but well worth it. Take out seats are available from the owners that bought the aftermarket seats.
dajo is online now
post #4 of 11 Old August 26th, 2019, 02:51 AM
Macs Dad's Avatar
My RZR: 2008 Ranger RZR
Member #8581
I went to an an off road show and sat in a bunch of aftermarket suspension seats to see which ones were most comfortable. Also added long travel with aftermarket shocks. No lower back problems during or after riding since.
Macs Dad is offline
post #5 of 11 Old August 26th, 2019, 03:06 AM
tekrsq's Avatar
First Name: Tommy
My RZR: '08 800 RZR
Member #70129
View tekrsq's Photo Gallery(8)
I'm right there with you. I have back problems as well, and after several hours of riding, I can barely get out/in of the machine. Widening the suspension and adding good shocks makes a HUGE difference, but it's still rough. A lot of people have installed 1000 seats and like them. This seems to be one of the easiest/ cheapest ways to improve the ride. There are several places that make adaptors to make them fit in our 800's. I want to put a set of 1000 seats in mine, but I need to keep the sliders, and as far as I can tell, nobody makes an adaptor with sliders.
08 RZR 800- SATV +6 High Clearance LT kit, Rhino axles, 900 XP shocks, 900XP front bearing carriers, dual core radiator, QSC clutch, 30" Carnivores/STI HD6 wheels, 3500lb Polaris winch, LED headlights, 30" lightbar, 7" LED driving lights, EMP 1/2 windshield, Air box relocation w/ custom snorkels, SATV EPS, CycleWorx 65amp VR, BoeschBuilt parking brake, dual Venom whips
tekrsq is offline
post #6 of 11 Old August 30th, 2019, 04:53 PM Thread Starter
flagboy's Avatar
Member #271778
Like I mentioned, my issue was pretty specific...that raised section of the seat back rubbing on my lower spine area.
I decided to start with the cheapest fix first...doing my own mods. I removed the seat cover and shaved down the raised section that was causing me pain. The cover just slips back on and isn't loose or wrinkled. That was a good start.
As I sat in the modified seat another issue became apparent: The angle and position of the lower part of the seat slid my butt into the opening between the back and seat sections. I'm on the small side, 160lbs, and that is a factor. I modified the lower portion in two ways. I moved the frame of the lower section back 1 3/8". That took drilling holes in the square tubing and adding a tab to the front bolts. I also raised the rear of the lower seat section about 1 1/2". The gap between the lower seat and seat back is reduced. Raising the rear part made me sit up a little taller.
With the three mods I no longer have that pressure point on my back, and I'm not being wedged into the open between the seat back and lower sections.
tekrsq likes this.
flagboy is offline
post #7 of 11 Old August 31st, 2019, 06:05 AM
dajo's Avatar
First Name: Dave
Member #19884
https://longhornfabshop.com/rzr-1000...s-pair-201027/
I have these in my 900xp, don't believe using the sliders (factory) would be a problem. Call them and ask. I made the modification on my 800 by welding square tubing on to existing factory mounts and have the slider on the drivers seat.
tekrsq likes this.
dajo is online now
post #8 of 11 Old August 31st, 2019, 10:36 AM
tekrsq's Avatar
First Name: Tommy
My RZR: '08 800 RZR
Member #70129
Damn, first time I've seen those. That might be the ticket for me !!!
So they just bolt onto a stock 800 base, AND bolt onto a 1000 seat ?? What did you need to add square tubing to ?
tekrsq is offline
post #9 of 11 Old August 31st, 2019, 10:43 AM
dajo's Avatar
First Name: Dave
Member #19884
Nothing else required with the Long Horn adapters.
Square tubing is if you DIY mods on the seat.
Remember if you have and 800 the ride is not very good due to lack of suspension travel. Even the S model still lacks.
dajo is online now
post #10 of 11 Old August 31st, 2019, 12:26 PM
tekrsq's Avatar
First Name: Tommy
My RZR: '08 800 RZR
Member #70129
lol....Trust me, I know. BUT I have made it MUCH better with a long travel kit, and 900 shocks. A friend has one very similar to mine, and he has had some shock work on his 900 shocks. The ride is amazing for an 800. I don't think an 800 can get any better ride than his setup. I just can't justify $1,200 for shock work though.
tekrsq is offline
post #11 of 11 Old August 31st, 2019, 01:07 PM
Clothier's Avatar
First Name: Brian
Member #65577
I've spent $1200 on alot less worthy things! Lol! My comfort and enjoyment is kinda priceless to me. I'm running Racertech springs and Shock Therapy valving on my oem Fox Podiums. I can honestly say the valving made as much or more difference than the springs. However I am having a hard time justifying $1100-1200 for the Duraclutch set-up I really, really want! I will add a good set of suspension seats makes a world of difference also. Not cheap by any means, but what is your comfort and enjoyment worth to you?
tekrsq likes this.
Clothier is offline
