Confirmation on pinion nut status - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old August 21st, 2019, 04:03 PM Thread Starter
flagboy's Avatar
Member #271778
View flagboy's Photo Gallery(0)
I just picked up a 2008 RZR 800 with 2600 miles and 250 hours.
I've confirmed that no work has been done on the differential.
Here are the unfortunate particulars:
Build date of 6/12/08...right in the gray area for the nut switch.
Differential serial number: 1425017.
Did I miss anything, or as I believe, I'm in line for some wrenching?
flagboy is offline
post #2 of 4 Old August 21st, 2019, 05:03 PM
204 AR's Avatar
First Name: Russ
My RZR: 08 rzr
Member #189561
View 204 AR's Photo Gallery(0)
Everything I've read here about it would indicate that you are right in the gray area also. Pullerguy will chime in I'm sure. I got lucky not once, but twice in that my 2 800 were built late summer of 07.
Once you get the pinion nut done, you might look into moving the voltage regulator up front where it will stay cool. That's my current project as I've lost 2 so far. I do think they were both original, so that's not really too bad.
But congrats on the new machine! For as much as I read on here about how bad the 800 are, I sure love mine.
204 AR is offline
post #3 of 4 Old August 22nd, 2019, 05:33 PM
Pullerguy's Avatar
First Name: Les
My RZR: 2012 800 50"
Member #61901
View Pullerguy's Photo Gallery(0)
Re: Confirmation on pinion nut status
Ed:
You are right on the cusp. the information we have shows:
Build date 6/11/08 Sn # 1426622
Yours being 6/12/08 Sn # 1425017 I'm thinking you are on the good side of the numbers. The build date is for the diff or the RZR?
I will contact Stuart aka Pirate and get his thoughts on it but we both the same information. You are right near the break point of information we have.
PM us with your e-mail address and I will contact you with anymore information we get.
Les
Pullerguy is offline
post #4 of 4 Old August 22nd, 2019, 06:02 PM Thread Starter
flagboy's Avatar
Member #271778
Thanks for the reply and follow up. The build date, 06/12/08, was for the RZR.
PM on the way.
flagboy is offline
