Purchased Used 2013 800, Maintenance Suggestions - Polaris RZR Forum - RZR Forums.net
 6Likes
post #1 of 21 Old August 17th, 2019, 05:55 PM Thread Starter
SlickMullet's Avatar
Member #272152
View SlickMullet's Photo Gallery(0)
Just bought a used 2013 Razr 800 with 500 miles on it. Any suggestions of what maintenance I need to perform? Anything I should look out for?
Thanks in advance!
SlickMullet is offline
post #2 of 21 Old August 17th, 2019, 06:16 PM
Mr Pickles's Avatar
My RZR: 2019 RZR 1000S
Member #269256
View Mr Pickles's Photo Gallery(0)
Re: Purchased Used 2013 800, Maintenance Suggestions
Im sure I wouldnt be the first to tell you change all the fluids, oil, demand and trans. Might as well put a new air filter in there and grease all the fittings. Id check the bearings, pull the wheels, have a look at the brake pads and clean everything up. Then get spending on all the extras you need to make it yours! That is a fun machine! Enjoy and ride safe!
Fastone110 likes this.
Mr Pickles is offline
post #3 of 21 Old August 17th, 2019, 06:27 PM
ReedsportRZR's Avatar
First Name: Richard
My RZR: 2012 RZR 800
Member #270188
View ReedsportRZR's Photo Gallery(0)
I purchased a 2012 800 a few months ago and did pretty much what Mr. Pickles suggested. Forgot to mention the oil filter. Mine had 3100 miles and so I changed the drive belt also. Not familiar with the life expectancy of the belt but I'd at least check it if I were you. He's right, they are a fun machine.
RZR_Scott likes this.
ReedsportRZR is offline
post #4 of 21 Old August 18th, 2019, 12:11 AM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Thanks in advance!
Even though it's low miles check the belt, I just got a new one for mine and carry the old one as a back-up.
Some are suggesting using 75w-90 in the trans and rear axle. Use Polaris Original in the front axle though.
Search the forum for 800 pinion nut and have fun.
I just did mine.
here's a link for the nut problem.
https://www.rzrforums.net/rzr-800-sp...pullerguy.html
RZR_Scott is offline
post #5 of 21 Old August 18th, 2019, 07:03 PM Thread Starter
Member #272152
Thanks in advance!
Search the forum for 800 pinion nut and have fun. [IMG class=inlineimg]https://www.rzrforums.net/images/smilies/frown.gif[/IMG]
I just did mine.
Yeah, pretty sure I need a new belt. Slips in high, jerky. Fine in reverse or low. Why is that?
post #6 of 21 Old August 18th, 2019, 07:04 PM Thread Starter
Member #272152
Mobile One 75-90 or what do y'all suggest?
post #7 of 21 Old August 18th, 2019, 08:30 PM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Yeah, I did Delo full syn 75w-90. Any synthetic 75-90 would be good I think including mobile 1.
I've read here some guys like to run 75-140 in the summer in the dunes or high speed desert running. I'm more of a cruiser and hill climber so I went with 75-90 in the rear axle. I already put Polaris lube in the trans but next time I'll do the 75-90 there too.
As for the belt, I would guess it's glazed. Not sure cause I'm new to these things too. Also check the faces of the clutch to be sure they are perfectly clean when you change the belt.
Post up a pic of the belt if you can, I'm curious what a slipping belt looks like.
post #8 of 21 Old August 18th, 2019, 08:50 PM
204 AR's Avatar
First Name: Russ
My RZR: 08 rzr
Member #189561
View 204 AR's Photo Gallery(0)
You might try blowing the clutches out before you bother changing the belt. It's a safe bet that's never been done, and you'd be amazed at the dust that will come out of what looks like a clean clutch.
204 AR is offline
post #9 of 21 Old August 18th, 2019, 09:00 PM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Does the dust cause the clutch to stick and the belt slip? Or?
I need to do this just because I guess.
post #10 of 21 Old August 18th, 2019, 09:17 PM
204 AR's Avatar
First Name: Russ
My RZR: 08 rzr
Member #189561
I'm not a clutch expert by any stretch of the imagination. I don't think the dust causes belt slippage, but it will surely cause more wear on all the moving parts, and less smooth operation in general.
I just know that my first 800 was a bit jerky with 1000 miles on it, and blowing out the clutches smoothed it up. I knew the previous owner well, he's big on maintenance but had no idea that was something that needed done.
204 AR is offline
post #11 of 21 Old August 19th, 2019, 11:22 AM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
I'll have to try that. Mine seems a bit jerky when you try and go slow like when loading on the trailer. When I changed the belt everything was very clean looking. I was surprised by how little dirt was inside the cover but I didn't try compressed air on anything either. Thanks.
post #12 of 21 Old August 19th, 2019, 11:40 AM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Thanks in advance!
Mine is a 2014 with 400 miles on it. While adjusting the front shocks I found a small tear in the steering rack boot ALREADY. jeeez. It was clearly not torn or damaged by anything, just splitting open. Guess you should look those over all the time.
$17 on Ebay for a pair. By the price they must be cheap parts, I can't imagine worse than the originals though....
post #13 of 21 Old August 19th, 2019, 11:53 AM Thread Starter
Member #272152
So the Razr has been snorkeled, I know a tube comes from the intake and then one from the clutch cover. Where does the 3rd come from? There are little accessories accordion stops on the vent tubes? I assume that is for water proofing collect whatever comes out?
post #14 of 21 Old August 19th, 2019, 02:16 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
There is most likely an air in & out for the clutch, and air in for engine.
2014 800 LE w/EPS 50
CA 800 is offline
post #15 of 21 Old August 19th, 2019, 03:37 PM
CanuckRzrS's Avatar
First Name: Greg
My RZR: 2009 Rzr S
Member #16469
View CanuckRzrS's Photo Gallery(9)
If you're going to blow out your clutches, you might as well use a cleaner and 3M scotch pad on the sheaves in a crosshatch pattern. This will remove the burnishing from the belt and give it better bite.
Good vid on cleaning the clutch from Hunterworks....
'09 Rzr-S Dalton Clutch Kit / Cummins OptiAir Intake / Snorkels By guy48065 / Remote Viper Winch / Makin Trax Progressive Springs / EMP A-arm Guards / Pro Armor Doors / Pro Armor 5pt Harnesses / J Strong Roof With Stereo / HID's By DDM / Bush Guard / Shoulder Bag
CanuckRzrS is offline
