Purchased Used 2013 800, Maintenance Suggestions - Page 2 - Polaris RZR Forum - RZR Forums.net
 6Likes
post #16 of 21 Old August 20th, 2019, 04:43 PM
ItchinToRide's Avatar
My RZR: 2013 800LE 50"
Member #8600
View ItchinToRide's Photo Gallery(0)
Re: Purchased Used 2013 800, Maintenance Suggestions
Originally Posted by SlickMullet View Post
Just bought a used 2013 Razr 800 with 500 miles on it. Any suggestions of what maintenance I need to perform? Anything I should look out for?
Thanks in advance!
Even though it's low miles check the belt, I just got a new one for mine and carry the old one as a back-up.
Some are suggesting using 75w-90 in the trans and rear axle. Use Polaris Original in the front axle though.
Search the forum for 800 pinion nut and have fun. [IMG class=inlineimg]https://www.rzrforums.net/images/smilies/frown.gif[/IMG]
I just did mine.
here's a link for the nut problem.
https://www.rzrforums.net/rzr-800-sp...pullerguy.html
Yeah, pretty sure I need a new belt. Slips in high, jerky. Fine in reverse or low. Why is that?
I don't like the sounds of slipping, but I can tell you from experience that jerky can be from toasting your belt in Hi range on an obstacle where you should have been in low (sand/mud/steep climb). It's not an obvious flaw when examining the belt, it's a symptom. Blowing the dust out of your clutch on a regular basis is paramount. I use a PTFE lube too, but not near the belt or sheaves.
RZR_Scott likes this.
ItchinToRide is offline
post #17 of 21 Old August 21st, 2019, 12:38 PM Thread Starter
SlickMullet's Avatar
Member #272152
View SlickMullet's Photo Gallery(0)
Definitely the belt. Replaced with a Gates Carbon and the slipping, jerking went away. The belt that was on it was skinny looking with small teeth. The replacement is much beefier.
Going to start working on fluid changes next and then brakes. Brakes work but pretty squeaky.
SlickMullet is offline
post #18 of 21 Old August 21st, 2019, 12:45 PM Thread Starter
Member #272152
I assume these little accordion deals are catches for vent tubes? Where all do the tubes come from?
post #19 of 21 Old August 21st, 2019, 02:28 PM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
front and rear axles and transmission.
RZR_Scott is offline
post #20 of 21 Old August 21st, 2019, 02:42 PM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Originally Posted by 204 AR View Post
I'm not a clutch expert by any stretch of the imagination. I don't think the dust causes belt slippage, but it will surely cause more wear on all the moving parts, and less smooth operation in general.
I just know that my first 800 was a bit jerky with 1000 miles on it, and blowing out the clutches smoothed it up. I knew the previous owner well, he's big on maintenance but had no idea that was something that needed done.
Well, I took compressed air to the clutch and OMG it was a mess! Couldn't tell by looking at it but it was full of dust. Blew it out and gave it a test. Big difference, way smoother at takeoff and slow crawling.
Thanks for the info!
post #21 of 21 Old August 21st, 2019, 05:27 PM
204 AR's Avatar
First Name: Russ
My RZR: 08 rzr
Member #189561
View 204 AR's Photo Gallery(0)
Glad it helped. I was a skeptic at first too. I don't know where all that dust hides lol but you sure can't see it.
204 AR is offline
