2013 rzr 800 will turn over but wonít start - Polaris RZR Forum - RZR Forums.net
 5Likes
post #1 of 19 Old August 9th, 2019, 08:28 PM Thread Starter
Polarisrzr13's Avatar
Member #271936
View Polarisrzr13's Photo Gallery(0)
Hello everyone. I joined this group because it looks like everyone is very helpful with helping figure out problems. I am completely stumped with whatís wrong with my razor. So 2 days ago it would start but and idle fine but when we drove it it would lurch back and forth. We took the injectors out and found out one was plugged so we changed the injectors and when we tried to start it again now it will turn over but wonít start. When we tried to start it and pressed on the gas it acts like it wants to start but it wonít. Prior to changing the injectors we got a new battery, fuel pump, throttle body, throttle position sensor, coil, spark plugs, crank position sensor, solenoid, temp sensor, cooling fan circuit break. Before changing the injectors it would at least start. I just donít understand what happens. We have a friend with a razor and we took our ECU and put it in his machine and it started so thatís not it. We checked the plugs and there sparking but it doesnít seem like the fuel is getting to the spark plugs. PLEASE HELP!!
Polarisrzr13 is offline
post #2 of 19 Old August 9th, 2019, 08:38 PM
sandblster's Avatar
Member #46247
Re: 2013 rzr 800 will turn over but wonít start
Have you checked the fuel pressure at the fuel manifold? Do you have the TSP set correct?
sandblster is online now
post #3 of 19 Old August 9th, 2019, 08:43 PM Thread Starter
Member #271936
Yes itís 39 pounds. We didnít set the sensor because it was already on the new throttle body.
post #4 of 19 Old August 9th, 2019, 08:53 PM
sandblster's Avatar
Member #46247
Still need to check the TSP. Have you checked spec's on the fuel pressure. Think that may be low. To low ago to be sure what it is suppose to be.
RZR_Scott likes this.
post #5 of 19 Old August 9th, 2019, 09:22 PM
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Feedback Score: 15 reviews
just had one with tps wire broke, pull on wires hard where they meet connector, common issue
209-373-5336 DONNY DARTER
dartersracing is offline
post #6 of 19 Old August 9th, 2019, 09:33 PM Thread Starter
Member #271936
If the tsp isnít set right would that cause it to not start?
post #7 of 19 Old August 10th, 2019, 07:14 AM
sandblster's Avatar
Member #46247
Yes
post #8 of 19 Old August 10th, 2019, 08:55 PM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Yes it’s 39 pounds. We didn’t set the sensor because it was already on the new throttle body.
Something is wrong with the fuel pump, it should be 60psi IIRC, I know at least 50.
I don't know if it will run with low pressure but when I checked mine (2014 800)it shot up to 50 or 60 instantly
RZR_Scott is offline
post #9 of 19 Old August 10th, 2019, 09:11 PM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Curious, where did you get the new TB and how much was it?
post #10 of 19 Old August 10th, 2019, 09:44 PM Thread Starter
Member #271936
eBay. Around $75.
post #11 of 19 Old August 11th, 2019, 08:24 AM
timbest
timbest's Avatar
My RZR: 2012 800
Member #250858
View timbest's Photo Gallery(0)
So your heart aches began after you re installed injectors.....I wonder about pulling fuel rail and injectors as a unit and energizing to observe injection and pattern. Be aware fine spray will be highly flammable.
timbest is offline
post #12 of 19 Old August 11th, 2019, 08:33 AM
sandblster's Avatar
Member #46247
Thought it is suppose to be 60 psi. There in lies your problem. 39psi does not have enough pressure to force the fuel through the injectors when they open.
post #13 of 19 Old August 11th, 2019, 08:57 AM
Clothier's Avatar
First Name: Brian
Member #65577
Pretty sure the 2008-2010 fuel pressure should be around 39psi, 2011-2013 fuel pressure should be around 42-45psi and 2014 should be 58psi. In 2014 they went to the xp900 fuel pump that why it is so much higher.
Clothier is offline
post #14 of 19 Old August 11th, 2019, 09:14 AM
sandblster's Avatar
Member #46247
You are correct. According to the service manual it is 39. http://quads.ddns.net/service-manual...e%20Manual.pdf
post #15 of 19 Old August 11th, 2019, 11:08 AM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Thanks for the info, mine is a 14. Soooo being that his 39 is awful close to 42 it should at least start.Well, that ain't it.... I would spray carb cleaner in it and see if it runs to test for if it's fuel for sure, then check for injector pulse and go from there.
It's a used TB so don't know if the T Map and TPS are good I guess. But he has two of each now, hopefully at least one of each are good, maybe like someone said it's the famous broken wire at the plug thing...??
He also said he changed the injectors, I would go back to the originals and see it it at least runs.
