Bypassing speedo for 4x4 - Polaris RZR Forum - RZR Forums.net
 8Likes
  • 1 Post By Clothier
  • 1 Post By madsonp
  • 1 Post By madsonp
post #1 of 13 Old May 12th, 2019, 09:13 AM Thread Starter
tekrsq's Avatar
First Name: Tommy
My RZR: '08 800 RZR
Member #70129
View tekrsq's Photo Gallery(8)
I know this has bound to have been asked at some point, but damn if I can find the answer.
The 4x4 on my 08 stopped working the other week. It was working fine, turned off the switch for awhile (didn't need 4x4), but when I turned it back on, I had nothing. No indicator on the dash, and no light on the dash switch. All the gear indicators are present on the dash, no blown fuses, and as far as I can tell, there's no broken wires.
Anyway, can I just put a toggle switch in and wire it straight to the diff ?
I'd prefer to have it fixed like it should be, but for now, I need it to work until I have time to start ripping out the wiring harness.
08 RZR 800- SATV +6 High Clearance LT kit, Rhino axles, 900 XP shocks, 900XP front bearing carriers, dual core radiator, QSC clutch, 30" Carnivores/STI HD6 wheels, 3500lb Polaris winch, LED headlights, 30" lightbar, 7" LED driving lights, EMP 1/2 windshield, Air box relocation w/ custom snorkels, SATV EPS, CycleWorx 65amp VR, BoeschBuilt parking brake, dual Venom whips
tekrsq is offline
post #2 of 13 Old May 12th, 2019, 11:20 AM
Clothier's Avatar
First Name: Brian
Member #65577
Re: Bypassing speedo for 4x4
Technically yes you can run a toggle to the front diff by-passing the computer rpm safety overrides. What you should do first is see if you have voltage at the diff. The awd switch controls a ground, not a 12v source. So it could be a bad ground or a bad 12v wire. Also I think the computer wont let the diff engage above 3000rpm to start with, only after the rpm has falling below 3000 will the computer send the signal( again I believe it a ground signal) to the front diff.
tekrsq likes this.
Clothier is offline
post #3 of 13 Old May 12th, 2019, 11:31 AM
Clothier's Avatar
First Name: Brian
Member #65577
Not sure if the wire colors will be the same, but kn the 2011 wire schematics it shows a Red wire with dark green trace as the hot 12v wire going into the front diff. The brown wire with white trace should be the ground going into the fromt diff. As I said I think the ground is the switched wire though. So my thinking is if the key is on the red should have no less than 11v, if it has less then there's your problem.
tekrsq likes this.
Clothier is offline
post #4 of 13 Old May 12th, 2019, 11:37 AM Thread Starter
tekrsq's Avatar
First Name: Tommy
My RZR: '08 800 RZR
Member #70129
Thanks, brother. I'm not worried about the RPM safety issue. I'm usually pretty in tune with my machine, and don't do crap like that anyway. I just wanted to make sure it was really as easy as it seemed.
tekrsq is offline
post #5 of 13 Old May 12th, 2019, 11:42 AM
Clothier's Avatar
First Name: Brian
Member #65577
Yes it should be that simple honestly.
tekrsq likes this.
Clothier is offline
post #6 of 13 Old May 26th, 2019, 03:12 PM Thread Starter
tekrsq's Avatar
First Name: Tommy
My RZR: '08 800 RZR
Member #70129
Well, finally got a chance to do some serious troubleshooting. Screwed around with it for 3 hrs, just to find out I have a bad switch...lol.
I wish I knew how to make a standard Carling switch work with the stock wiring. I don't mind moving the wires around in the plug, I just don't know what needs to be moved. Either way, I got another stock switch coming, so at least it will work.
Thanks for all the help !!!!!
tekrsq is offline
post #7 of 13 Old May 26th, 2019, 04:25 PM
Clothier's Avatar
First Name: Brian
Member #65577
This should help.
tekrsq likes this.
Clothier is offline
post #8 of 13 Old May 26th, 2019, 04:51 PM Thread Starter
tekrsq's Avatar
First Name: Tommy
My RZR: '08 800 RZR
Member #70129
This should help.
WOW....Seriously ?? No wonder I couldn't figure it out. I assume the "Ign Power" wires are the stock red/white wires ?
THANKS !!!!!!
tekrsq is offline
post #9 of 13 Old May 26th, 2019, 05:15 PM
Clothier's Avatar
First Name: Brian
Member #65577
Here is a really good thread that I found that pic in. https://www.rzrforums.net/lighting-s...-switches.html
Mad props to rzrxpdude for the write up.
tekrsq likes this.
Clothier is offline
post #10 of 13 Old May 26th, 2019, 05:16 PM
Clothier's Avatar
First Name: Brian
Member #65577
I used it to do,my headlight and awd switch replacements.
tekrsq likes this.
Clothier is offline
post #11 of 13 Old May 27th, 2019, 09:31 AM
madsonp's Avatar
My RZR: 2017 XP 1000
Member #189721
View madsonp's Photo Gallery(0)
See the write up I did on this on post 14 https://www.rzrforums.net/rzr-xp-100...lp-needed.html
tekrsq likes this.
madsonp is offline
post #12 of 13 Old May 27th, 2019, 04:31 PM Thread Starter
tekrsq's Avatar
First Name: Tommy
My RZR: '08 800 RZR
Member #70129
That's awesome, thanks !!!!! I have a few 5 pin switches I am going to try.
tekrsq is offline
post #13 of 13 Old May 27th, 2019, 04:55 PM
madsonp's Avatar
Member #189721
Glad to help, let me know how things turn out for you, or if you have any questions.
tekrsq likes this.
madsonp is offline
2010 speedo needle Brad McGrath General RZR Discussion 0 June 2nd, 2018 08:43 AM
smaller speedo cluster???? wildeman70 Lighting, Stereo and Electrical 22 February 23rd, 2016 05:25 PM
Speedo and cel firestroke21 RZR-S Specific Discussion 2 March 22nd, 2015 08:19 PM
1K speedo in a 900????? xplos1 RZR XP 900 0 July 3rd, 2014 10:01 PM
Speedo killing battery. RedMan Lighting, Stereo and Electrical 5 May 12th, 2009 07:18 PM
