Led rear tail/brake light question - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Pullerguy
post #1 of 12 Old September 30th, 2018, 02:04 PM Thread Starter
funvtec's Avatar
Member #240450
View funvtec's Photo Gallery(0)
Purchased a set of these and they only work on the bright setting. No brake light function. Just bright as if the brake was pressed all the time. Doesn’t go dim either when the pedal is depressed
Is there anything odd with our electrical systems that make LED’s not work properly? Is there a resistor needed for brake light to function properly? (Like turn signals on cars).
Or was I possible just sent a bad set?
funvtec is offline
post #2 of 12 Old September 30th, 2018, 08:22 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Re: Led rear tail/brake light question
Take a look at this thread: https://www.rzrforums.net/rzr-800-sp...-question.html
2014 800 LE w/EPS 50”
PRO ARMOR trail doors, RYFAB rear windshield, MotoAlliance Fire Storm cab heater, RYFAB cargo rack, WARN PV4500S wide spool winch, POLARIS front windshield and top, 2008 tail lamp assemblies with backup lights, RACERTECH 2” lift, Duraclutch, R2C Air Filter, Garage Products A-arm bushings.
CA 800 is online now
post #3 of 12 Old October 1st, 2018, 06:40 AM Thread Starter
funvtec's Avatar
Member #240450
Originally Posted by CA 800 View Post
Thanks. Checked it out. The reds seem to be discontinued unfortunately.
funvtec is offline
post #4 of 12 Old October 1st, 2018, 07:21 AM
Clothier's Avatar
First Name: Brian
Member #65577
You can still get the reds in a 27 led version. May not be as bright though.
https://www.superbrightleds.com/more...ens/3556/7523/
Clothier is offline
post #5 of 12 Old October 1st, 2018, 08:09 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
LED taillights come in two versions.
Bulbs for "Standard" wiring, or for "CK" wiring.
You need to check taillamp socket with voltmeter or test lamp to determine how yours is wired.
Some of the cheaper LED lamps do not have separate negative contact for the dual filaments and may not behave properly.
My 2014 RZR 800 needed NON-CK bulbs.
post #6 of 12 Old October 1st, 2018, 08:25 AM Thread Starter
funvtec's Avatar
Member #240450
Thanks. I’ll give these a try!
funvtec is offline
post #7 of 12 Old October 1st, 2018, 08:26 AM Thread Starter
funvtec's Avatar
Member #240450
Attachment 561436
Attachment 561438
Wow!! Great information. Thanks a ton.
funvtec is offline
post #8 of 12 Old October 1st, 2018, 08:40 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Funvtec,
LED bulbs are polarity sensitive.
Try rotating the bulbs you have 180 degrees in the socket.
You may also be able to bend the LED contact pins from one side to the other and get the bulbs to work.
post #9 of 12 Old October 1st, 2018, 09:25 AM Thread Starter
funvtec's Avatar
Member #240450
Funvtec,
I did indeed try that. Also tried putting both in at the same time. Then one incandescent and one led. No luck.
funvtec is offline
post #10 of 12 Old October 1st, 2018, 02:52 PM
Pullerguy's Avatar
First Name: Les
My RZR: 2012 800 50"
Member #61901
View Pullerguy's Photo Gallery(0)
I ordered the 3157-CW27-T-CK LED for our 2012 800, they work fine. I ordered them from Super Bright LEDS.
That is the same place that Brian posted.
Les
funvtec likes this.
Pullerguy is offline
post #11 of 12 Old October 1st, 2018, 03:11 PM
Clothier's Avatar
First Name: Brian
Member #65577
Les
Good to know Les! I wasn't sure how bright they would be. Mine are the 45 led count, but they have discontinued them.
Clothier is offline
post #12 of 12 Old October 1st, 2018, 04:00 PM
Pullerguy's Avatar
First Name: Les
Member #61901
Here is a link for a 45 LED unit, looks like it is available in Amber.
https://www.superbrightleds.com/more...rvb/2436/2227/
Converting factory Headlight to LED Day time / fog light/ flood light Robert0 RZR 570 Specific Discussion 9 July 31st, 2018 07:24 AM
Rear LED light huskerfan General RZR Discussion 2 May 17th, 2018 10:59 PM
900 S Axle / Rear End Question Euromike General RZR Discussion 3 April 22nd, 2018 06:41 AM
LED light bar whistle Scott M General RZR Discussion 10 October 3rd, 2016 09:39 AM
