800 will not start - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old September 29th, 2018, 01:00 PM Thread Starter
Hillbilly limo's Avatar
Member #260706
View Hillbilly limo's Photo Gallery(0)
800 will not start
I have a 2014 800 4, it has a new battery, new starter solonoid, all dash lights work fuel pump comes on but when I turn the key nothing happens, it will not turn over or anything, I can start it all day long by jumping the solonoid, I have checked the relays and fuses and still nothing, any help would be very much appreciated
Hillbilly limo is offline
post #2 of 7 Old September 29th, 2018, 02:12 PM
Tailgunner's Avatar
My RZR: 900 Trail
Member #230761
View Tailgunner's Photo Gallery(0)
Usa Re: 800 will not start
I would check the ignition switch and the wires going to the solenoid.
Tailgunner is online now
post #3 of 7 Old September 29th, 2018, 02:16 PM
Clothier's Avatar
First Name: Brian
Member #65577
Check to see if your brake lights(not tail lights) are working. If not then check the wires on top of the brake sending unit. It has to work to turn the starter over by the key. It's a simple pressure switch. The wire conector can/will get dirty or even knocked off and then the key wont turn the starter.
Clothier is offline
post #4 of 7 Old September 29th, 2018, 06:39 PM
Olmoggy's Avatar
First Name: Brian
My RZR: 2013 rzr s 800LE
Member #59058
View Olmoggy's Photo Gallery(0)
Those ignition switches have been known to seperate not allowing them to make contact inside. It happened on my wifes 13 800s only way i found out was by reaching under the dash and squeezing it together while turning the key and it started. New switches are 6bucks
Olmoggy is offline
post #5 of 7 Old September 29th, 2018, 08:02 PM Thread Starter
Member #260706
thanks for the ideas, I will try those out tomorrow and will let you know
post #6 of 7 Old October 9th, 2018, 08:55 PM
Pirate's Avatar
First Name: Stuart
Member #3677
After the machine has set overnight...get in and turn the switch to "ON". Do you hear the whine of the electric fuel pump bringing the fuel rail up to pressure? If not the pump can be failing. That will cause you fits.
Check the point where the ground cable from the battery is bolted to the frame. make sure the face of the frame and the end of the cable are clean and bright shiny metal. It's often a problem.
There is a MAP sensor in the intake tract. It can get dirty and cause you starting problems. Clean it with CNC Mass Air Flow Sensor Cleaning Spray. Got mine thru Amazon. But some parts stores carry it.
Pirate
Pirate is offline
post #7 of 7 Old October 10th, 2018, 11:40 AM
retired electrician's Avatar
Member #261864
View retired electrician's Photo Gallery(0)
Angry Re: 800 will not start
My 2014 RZR 800 ran perfect all weekend. Put on trailer and hauled home, tried to start to take off of trailer and lights on speedometer come on and engine light stays on. Just has dotted lines where it shows gear location and shows 32 degrees for a few seconds then dotted lines on the other side. checked out break sensor and it is working properly and jumped across solenoid, motor will crank but will not start. also can not here fuel pump come on when I turn the key on. Any suggestions would be appreciated. Now if turn the key all the way to start, I can hear the fuel pump but still nothing to engine.
Last edited by retired electrician; October 20th, 2018 at 07:44 AM. Reason: Still having trouble finding problem. Plus RZR Forum was down
retired electrician is offline
[UPDATED 2018] UTV INC RZR Wheel Bearing Greasing Tool UTV Inc. UTV Inc 142 July 12th, 2018 12:05 PM
RZR 800 Polished Billet Bed Rails !! UTV Inc. UTV Inc 2 April 23rd, 2018 11:51 AM
2014 rzr 800 LE wont start HELP! ndavin RZR 800 Specific Discussion 3 April 13th, 2017 08:16 PM
My 800 SLE WONT START BBeaty Member Introductions 6 February 26th, 2017 08:34 PM
